02-19-2013, 06:03 AM
#1426 | ||
Oddometer: 1,832
klunks bad enough to sound like the front is just about to fall out if you run over some very moderate potholes not sure about the funktion, did not even try to put in any real riding the sound is too gut wrenching so far no feedback from the dealer |
02-19-2013, 04:46 PM
#1427 | |
Oddometer: 19
http://shop.touratech.co.uk/gps-moun...n-systems.html |
02-20-2013, 02:48 AM
#1428 |
Stinky Pinky
Oddometer: 314
I talked with them again yesterday and he said I do not have to use the adjustable windshield mount. I can simply twist the gps in it's dock down enough to open it. That works for me
02-20-2013, 09:59 AM
#1429 |
Oddometer: 76
I received my TT adjustable windscreen bracket today and I can't figure out how to get the stock windscreen off. Whenever I turn the 4 bolts holding the windscreen on they just spin and spin like the nut on the other end isn't attached to anything. Anyone have any experience with this?
02-20-2013, 10:10 AM
#1430 |
Oddometer: 26
Nuts twisting
ZBone I had the same problem. I had to take the black bracket cover off behind the screen (in front of you as you are sitting on the bike) and then use a pair of needle nose to hold the back of the nuts to keep them from turning. Once they brake loose then they will come on out without having to hold them. There are some small screws holding the cover on with a star type head.
02-20-2013, 10:16 AM
#1431 | |
Oddometer: 76
02-22-2013, 03:36 PM
#1432 |
U lie&yo'breff stank
does anyone know if the stock heated grips work with MX bars ?
... just looked. took the left grip off. there are two small screws that thread into the handle bars. the rubber part of the grip is on top of a plastic piece (the part that is screwed into the handle bars). not sure how i could use the stock heaters with a beefier handlebar. guess i would have to drill and tap the new bars to accept the stock screws? any other ideas? also, someone posted a picture of their relocated regulator rectifier earlier. did you just buy longer bolts ? swamp screwed with this post 02-22-2013 at 03:51 PM |
02-22-2013, 04:36 PM
#1433 |
Oddometer: 198
Fender extender
Anyone know if Sertao beak extender will fit an '05 F650gs beak? They do look the same to me but just to make sure. If so anyone is willing to sell one?
02-23-2013, 02:14 AM
#1434 |
Oddometer: 13
rack wolman and remus
Hello
excuse me for my language i have small information : The wolfman rack does not adapt with a silencer remus. It is necessary to cut and to lengthen a fixation(binding). I have contact wolfman. Their answer Thank you for your email. I can now see the problem. But, I do not know what Wolfman can do. It is not possible to make racks and know every exhaust manufacturer. It is only possible to manufacture to BMW original system. Dammage ! Wolfman is good farkles ! See the photo. ![]() Uploaded with ImageShack.us here it's just possible (3/5 mm) ![]() Uploaded with ImageShack.us but not here ! I have cut ![]() Uploaded with ImageShack.us Mr. GREEN screwed with this post 02-23-2013 at 05:09 AM |
02-24-2013, 05:47 AM
#1435 | |
Oddometer: 1,832
the dealer just put the forks back together and the 'klunk' is gone next question is it normal for the Sertao to consume considerable more gas than the Dakar did? thought the new engine was supposed to be a little more economic than the old one |
02-24-2013, 06:11 AM
#1436 |
Oddometer: 13
02-24-2013, 07:21 AM
#1437 |
Oddometer: 1,832
the Dakar always got 60mpg, on a good day 65 that's between 3.9 and 3.6L/100km
the Sertao gets around 50mpg = 4.7L |
02-24-2013, 07:48 AM
#1438 |
Oddometer: 76
I'm not sure where you got your information, but according to BMW the Sertao gets 74mpg at a constant 55mph and my experience with my bike has been spot on with this. Riding slab in the mountains at 65-70mph I'd average around 65-70mpg and riding the bike off-road and hard on the throttle I'd still get 55mpg.
02-24-2013, 08:02 AM
#1439 |
Oddometer: 76
Has anyone added some sort of soft tank panniers to their ride? I'm thinking it'd be a great way to carry some extra tubes, tire spoons, and levers. Looking at the bike I'm a little concerned that they'd cover the vents on fairing, but I'm unsure whether those vents have any sort of function or if they're just there for looks. All the hot air leaving the bike exits below the fairing onto my knee so I can't imagine what other purpose they would serve.
02-24-2013, 08:43 AM
#1440 | |
Oddometer: 99
