02-22-2013, 11:25 PM
#16156 |
Exhiled
Oddometer: 187
I'll add one more recomendation for the carb work. Verify that your disassembly screwdriver is "JIS" head, not just "Phillips" head. They do fit slightly differently. May not be a problem in AUS. Not sure what your local standard is.
I second completely removing the flapper plate. Sent from my DROIDX using Tapatalk 2 |
02-23-2013, 11:21 AM
#16157 |
Gone Riding
Oddometer: 389
carbs
Replace the carb phillips screw head with stainless cap/hex head stews and you'll be set for life. The stock "phillips" are way to soft and easily strip the heads.... IMHO
PIGPEN Ride more, write less, work when !!! ![]() Having fun is not a sport! It's a full time job for some of us! |
02-23-2013, 11:29 AM
#16158 | |
Chickenfat dirtbiker
Oddometer: 1,126
1 Clean counter 2 Organized parts in dish/tray if need be-in order and even in groupings 3 Dont strip threads/heads! If ya cant get it any other way, stop! Go drink coffee/beer/etc Find another way! 4 Tighten it back together evenly- if it has multiple bolts/screws-tighten them down evenly together- it takes a lil longer but things seal/seat better. If youve taken something apart a 1000 times over the years, and it still has the same screws/bolts- yer prolly a pretty good mechanic. Tony |
02-23-2013, 11:30 AM
#16159 |
Oddometer: 1,126
02-23-2013, 07:47 PM
#16160 |
Soil Sampler
Oddometer: 85
Anyone Looking for A Fat Sumo Pig
02-23-2013, 08:02 PM
#16161 |
Oddometer: 185
Swingarm maintenance
Finally got the motivation to grease the swingarm on my XRR today. My bike has around 1000 miles on it. Here's what the bolt looked like...
![]() Luckily it came out easy. Lots of water, little grease in the bearings... ![]() Couple hours later... ![]() Back end is ready to go! Waiting for shims and seals to finish the forks. |
02-23-2013, 11:29 PM
#16162 | |
Oddometer: 16
02-24-2013, 12:13 AM
#16163 |
Oddometer: 243
02-24-2013, 02:32 AM
#16164 | |
Keep On Keeping On!
Oddometer: 1,852
“Do not be afraid; only believe.” |
02-24-2013, 04:57 AM
#16165 |
ADV in ADK
Oddometer: 922
02-24-2013, 08:05 AM
#16166 |
Oddometer: 185
Agree. Nice work xmoto!
02-24-2013, 09:42 AM
#16167 |
Oddometer: 45
02-24-2013, 10:07 AM
#16168 | |
aka Birdkilla
Oddometer: 2,351
Sounds like someone's been reading their latest issue of MCN...
Cpt. Ron Sack-O-Tomato, CA '05.5 950 Adventure S "Bad Mutha F@&ker" '04 R1150RTP "cop motor, cop suspension.." '00 XR650R Dual Sport "Lil' Mule" '75 RL250 '01 TTR90 '01 PW50 Conti TKC80 tire swing "I don't know what you do, but I know what I do, and I don't do that." --Uncle Doug, R.I.P. "Without the possibility of death, adventure is not possible"--Reinhold Messner |
02-24-2013, 10:20 AM
#16169 |
Exhiled
Oddometer: 187
MCN?
No, I've just worked on enough Japanese bikes to have learned the difference. I've also learned that JIS screws are made of a material similar in consistency to swiss cheese. Sent from my DROIDX using Tapatalk 2 |
02-24-2013, 12:35 PM
#16170 |
AKA DoctorXRR
Oddometer: 645
XRR Fender Wobble
Hi, the ManRacks has a small sheet metal support under the fender. It bolts to the end of the subframe, and comes up with a large tab that supports the rack. It helps stabilize the fender somewhat......I dont run turnsignals so cant say about the extra weight that signals may add. Overall I think the rack works real good!
