Old 02-23-2013, 03:44 PM   #7456
Velociraptor
TrackBum
Oddometer: 1,097
I did not check the valves on my 2009 690r until 6,000 miles-about 10,000Km and they were all tight and just barely in spec.
2014 KTM EXC 500
2014 KTM 1290 Superduke R
2009 KTM 690r Enduro SOLD
2002 RC51 SOLD
2010 KTM 990 Supermoto R SOLD
Velociraptor is offline   Reply With Quote
Old 02-23-2013, 03:47 PM   #7457
BygDaddee
Where do I get a pie
BygDaddee's Avatar
Oddometer: 1,681
Yeah I'm concerned about doing an inspection on Cam Rollers and Cam Roller Bearings rather then the valves
Relax and enjoy the journey, not just the destination.
2013 WR450F(The best bike KTM never built) and BMW G650GS Sertao (The refined mans DR)
Pauls Spot Tracker http://share.findmespot.com/shared/f...mgxmQRRUCqrKiY
BygDaddee is offline   Reply With Quote
Old 02-23-2013, 04:55 PM   #7458
Bumpaman
Location: Foot of the Sangre de Cristos and Music City, TX.
Oddometer: 157
Re: Renazco seat fitment
I have just installed a Safari tank on my 2010 690 and am having trouble fitting my Renazco seat back on the bike with the tank on. The Olympic way to install the seat is to put it on with he tank unbolted and then bolt the tank down. I have the tank installed as high as possible and still be able to bolt it up, so what am I doing wrong? Has anyone else had this problem? Thanks
Bumpaman is offline   Reply With Quote
Old 02-23-2013, 05:00 PM   #7459
Sutherngintelmen
around the bend
Sutherngintelmen's Avatar
Oddometer: 1,196
I'm pretty sure the Rally Raid guard had been sitting around for a year before the Sigutech group buy... check!
Rattle canned the guard and finally got around to it on this dreary southern winter day.
Before:
During:
Done:
There is a pleasure in the pathed woods, There is a rapture in the smoking pipe, There is chaos, where none intrudes, in the deep dell, with its thrills roar; I love not nature less, but bikes the more. Byron riding.
All pics < 6/30/12 deleted by Apple Now with SmugMug supporting ADV
Sutherngintelmen is offline   Reply With Quote
Old 02-23-2013, 06:03 PM   #7460
dad2bike
Cranky Old Fart
dad2bike's Avatar
Oddometer: 3,971
I have a Corbin seat and a Safari tank. The seat fits very tight under the tank. The front mounts on the frame & seat need to be removed. The previous owner also left off the tank bracket up front. No need for it.
Tom
2006 950 Adventure "Big Orange", 2009 690R "Ginger",2003 525 EXC,
To Think is to Create!
My2Wheels
690 WIKI
dad2bike is online now   Reply With Quote
Old 02-23-2013, 08:17 PM   #7461
Bumpaman
Oddometer: 157
Thanks d2d. I will remove the bracket for the seat.
Old 02-23-2013, 09:59 PM   #7462
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,348
Originally Posted by WIsixfitty View Post
simple question (I think).
What is the valve check interval?
I checked the lc4/690 index but nothing jumped out at me.
6K miles. Every time my intakes were tight, When I got about 18K miles on the bike they were always out of spec tight. The 690's definitely a bike you don't want to go past the interval without checking. It's simple to do and cheap to shim when needed.
Old 02-24-2013, 07:11 AM   #7463
dad2bike
Cranky Old Fart
dad2bike's Avatar
Oddometer: 3,971
Yesterday I learned why the rollover sensor exists.
No pics. However, my Ginger threw me to the ground in slow deep sand. The wheels ended up above the handlebars. Rollover kill worked great. I had to cycle the power to start up again.
I've decided that feature will stay on my bike.
I'm totally satisfied with how my forks are working. The shock need TLC bad. Taking it off to give it to the surgeon this week. Forks I can do. Shocks are wayyyy over my head.
Tom
My2Wheels
690 WIKI
Old 02-24-2013, 10:54 AM   #7464
dad2bike
Cranky Old Fart
dad2bike's Avatar
Oddometer: 3,971
Made up a set of these this weekend. Worked good .
Sent from outer space with my Thunderbolt with Tapatalk.
Tom
My2Wheels
690 WIKI
Old 02-24-2013, 11:35 AM   #7465
Bill the Bong
Supern00ba
Bill the Bong's Avatar
Oddometer: 952
Need some ideas
I'm busy fitting the RR Evo 2 kit. After getting the principle bits fitted, I took it for a shake-down run. Everything was fine. Today messed around with getting the headlight aligned, getting fairings to fit and cleaned up the cockpit wiring.
When I wanted to take it for a run this evening, it started and idled fine. When I opened the throttle, it would either bog or flame out. It is possible to pick up revs when I open the throttle very slowly. Wicking it at any RPM causes a flame-out. It has fuel and no errors are display. All fuses OK.
Any ideas? I'm keen not to un-install everything.
KTM 690 R - "Its just a little crush..."
Bill the Bong is offline   Reply With Quote
Old 02-24-2013, 11:38 AM   #7466
Baja Dad
Baja Dad's Avatar
Oddometer: 1,951
what is the offset of a 2011 KTM 690 r
Top clamp part # 765.01.034.031
it has 30 top 32 Bottom stamped on the clamp
Is the adj offset realy 30/32 ?????
what happen to 20/22???
2015 support: Multitool,GPS IMS Aurora Rally Kriega, Raiden LS2, Helmets,
100Goggles,SIDI,Seat Concepts, Precision Concepts, MX1West,Dunlop
Baja Dad is offline   Reply With Quote
Old 02-24-2013, 12:33 PM   #7467
Seth S
Safari Scramble!!!!!
Seth S's Avatar
Oddometer: 4,451
Pinched fuel line?
Seth S
Seth S is offline   Reply With Quote
Old 02-24-2013, 12:41 PM   #7468
Bill the Bong
Supern00ba
Oddometer: 952
I'm also leaning towards low fuel pressure.
Old 02-24-2013, 02:07 PM   #7469
The Letter J
lost in the 690 mega
The Letter J's Avatar
Oddometer: 888
My bike is a 2009 so I can't confirm that, but... 30/32 would make sense being that KTM claimed to have increased the steering lock, as long as the axle clamps were pulled back the same 10mm the rake/trail should be the same right?
The Letter J is offline   Reply With Quote
Old 02-24-2013, 07:12 PM   #7470
thorinoakenshield
ya mo be there
thorinoakenshield's Avatar
Oddometer: 446
Pissed Rear wheel spacer on sprocket side srsly pissing me off!
What's the deal with the rear wheel spacers on the sprocket side?
I had this problem before, and I kind of ignored it. Now, I'm chaning my rear tire again and I was determined to remove the leftmost spacer.
What a pain in the ass! I had to bang it out with a screwdriver and aluminum rod. I marred the spacer all up to holy hell!!
Whoops....not a big deal,really.....
Why was I so determined? I wanted to see how effed my bearing where.
They're ok, thankfully, but I did find some RUST!! Most bike aren't lubed for shit from the factory, and this bike is no exception....
Dammit. Atleast the bearings spin fine....
So then I greased those spacers up with some marine grease and attempted to stick them back into the sprocket hub.
It's a tight fit! What the hell?! I had to tap them in with a mallet kind of hard!!! This seems really weird. The spacers have always slid in and out for every bike I've had, including another KTM.
Is that what everybody else has to do??!!
This means that for the next tire change, I'm going to have to go through all this crap again!!
It's such a tight fit, I'll have to struggle to get the spacers out again (even if I lubed them up)...for rust cleaning/bearing checking and re-lubing.
This is how I feel right now:
thorinoakenshield screwed with this post 02-24-2013 at 07:24 PM
thorinoakenshield is offline   Reply With Quote
Times are GMT -7.   It's 10:21 AM.
