Old 02-23-2013, 05:15 PM   #1
DocAxeYarYar OP
RideDualSport.com
DocAxeYarYar's Avatar
Oddometer: 784
Beta ALP 200- the DUAL Dual Sport
http://www.motorbikes.be/en/Beta_Alp_4T_200_2003.aspx
2003 Beta ALP 4T 200 RideDualSport.com
[/color][/b]
My XR650R Build:
http://ridedualsport.com/forum/index.php?topic=2748.0
DocAxeYarYar is offline   Reply With Quote
Old 02-24-2013, 01:41 PM   #2
DocAxeYarYar OP
RideDualSport.com
Oddometer: 784
Beta ALP Dual Sport
Been enjoying tooling around on the little bike, its a blast. Totally different from my big beast Honda XR650R.
Hmmm...how come I cant do this.... Its not rocket appliance!
This dude must have made his grade 10.
Notice how the bottom of the motor is protected by the lower frame tubes, nothing extends below the frame.
My XR650R Build:
Old 02-24-2013, 03:56 PM   #3
duxrneet
duxrneet's Avatar
Oddometer: 670
Cool little thing. What's the top speed on it?
Current: 2004 CBR600F4i, 2001 KTM 520EXC - Past: 1995 XR600R, 1993 DR350 (Dirt Model), 1987 CBR600F
duxrneet is offline   Reply With Quote
Old 02-24-2013, 07:03 PM   #4
SRG
SRG
SRG's Avatar
Oddometer: 1,246
Had one exactly like that - an '02 w/ the DR200 motor. It didn't really work as a trials bike (wrong gearbox and limited power), but it was a fun small trail bike. Mine would cruise @ 60 and maybe go 70 w/ me on it (6'-1", 200#)
I was told that the importer brought in a total of 10 in 2002.
Lazy Traveler
SRG is offline   Reply With Quote
Old 02-24-2013, 08:12 PM   #5
DocAxeYarYar OP
RideDualSport.com
Oddometer: 784
Very cool, I am not sure on where it tops out, but the gearing seems quite low. I understand they came with two CS sprockets, and if needed going one up on the CS should be easy.
Cruising at 60 is just fine, but nothing left in reserve. I am looking forward to putting around on some more technical traisl for fun. Its going to be my wife's starter bike, so the stock mirrors and turnsignals are coming off....hoping it does not get TOO beat up.
My XR650R Build:
Old 02-25-2013, 02:50 AM   #6
The Cameraman
Oddometer: 218
Morning Guys n Gals,
I had one of these when they were first launched and it was the worst braked motorcycle I'd ever owned. It head the pads, the discs, the master cylinder replaced and it was no better. In the end I just sold it as I couldn't get it to stop.
And before you say it's a small trail bike so don't expect a lot from the brakes, I have since purchased a number of XT225 & XT250 Serow's and their brakes are way better.
Regards
Reggie
The Cameraman is offline   Reply With Quote
Old 02-25-2013, 06:32 AM   #7
DocAxeYarYar OP
RideDualSport.com
Oddometer: 784
Beta Brakes
Thanks for the tips on the brakes, will keep an eye out for that....not ridden it enough yet to see how they hold up.
Speaking of brakes, the rear master cyl seal leaks, so needs to be rebuilt. Any ideas on a source for parts? The Beta America website has some US dealers, so I will start there.
My XR650R Build:
Old 02-25-2013, 06:56 AM   #8
TobyG
be happy :)
TobyG's Avatar
Oddometer: 544
Well, over here Beta's are pretty much known as a mix between trial and enduro bikes which can also be ridden on the road, if needed.
To me, they sound like a good alternative to the KTM freeride, although being a bit more Enduro-oriented.
I sure would like to try one of those
....so many bikes I'd like to have one day
In case that you can't get the needed parts from a US based dealer and you need help getting the parts from a european seller, let me know.
"a scoot (that wouldn't go more than 28mph if you dropped it out of an airplane)" ~duck
"If loud pipes saved lives, then ambulances would run straight pipes instead of lights and sirens." ~Phlemdog
This is why I always wear gloves. How you gonna wipe your butt with hands covered in bandages? ~MrBob
TobyG is offline   Reply With Quote
Old 02-28-2013, 11:38 AM   #9
DocAxeYarYar OP
RideDualSport.com
Oddometer: 784
Beta ALP
Thanks for the offer on helping to find parts! The rear master cyl needs rebuilding, will see if I can get it from a US dealer.
Soon the bike will sport some fresh Shinko trials/DS tires. Since its a low-powered bike, light weight, and just for casual dirt riding I dont mind putting on some buget rubber.
My XR650R Build:
Old 02-28-2013, 11:56 AM   #10
Antti
Antti's Avatar
Oddometer: 177
They do also produce Beta Alp 4.0 with 400cc engine. Just talkd with friends that it would be quite ideal secondary/winter bike. But theres nothin wrong wirh 200 tough :)
R1100GS, 690 Enduro, R80G/S project bike.
Antti is offline   Reply With Quote
Old 02-28-2013, 12:02 PM   #11
gravityisnotmyfriend
gravityisnotmyfriend's Avatar
Oddometer: 1,349
Maybe you'd better put down the powered wine and pepperoni
- and get out of the trailer park.
gravityisnotmyfriend is online now   Reply With Quote
Old 03-07-2013, 09:49 PM   #12
DocAxeYarYar OP
RideDualSport.com
Oddometer: 784
Beta ALP Dual Sport
Had good luck with getting the back brake working. The rear master cyl has a rubber cap that tends to capture water and cause corrosion on some of the associated hardware. Took it all apart, cleaned well, and its sealed up, not leaking any brake fluid.
Looks like the only part I need to order are the two chain guide rollers, as it looks like they broke apart.
Fresh set of tires are next!
My XR650R Build:
Old 03-25-2013, 08:10 AM   #13
jooNorway
Oddometer: 10
Nearly...
The Alp 4.0 have a Suzuki DR350 engine.
Nice bike, I like mine.
jooNorway is offline   Reply With Quote
Times are GMT -7.   It's 02:27 PM.
