Old 02-23-2013, 04:32 PM   #33346
KansasBob
KansasBob's Avatar
Oddometer: 515
Quote: What's recommended to clean the old bearings prior to regreasing if they are not replaced?
I later found this link that explains quit a bit about that "plastic stuff" http://www.thumperfaq.com/swingarm.htm
WOW! That is exactly the information I wanted.
Permanent Lubricant..... OK If you say so.
I'm comfortable with my decision to go old school, and pack her tight with water proof grease.
I'm back together, and torqued now. 47 rear, new seal guard, (third one from new) and a new chain is on. New Gel battery, a little fuel, and actually started
KansasBob screwed with this post 02-23-2013 at 04:49 PM
KansasBob is offline   Reply With Quote
Old 02-23-2013, 04:44 PM   #33347
KansasBob
KansasBob's Avatar
Oddometer: 515
Originally Posted by viper770 View Post
well i have more bad news for you kansasbob we are suposed to get another 8 inches of snow tomorow but i got my klr650 back with the new progressive shock the bike does so much better now so im playing in the snow alittle bit with the klr but i think its going to be a few days befor i get my wr250r back out :(
I'm supposed to drive an over loaded E150 Ford van to Western Kansas on Monday morning, but is sounds like I'll be getting another day off.
Old 02-23-2013, 08:13 PM   #33348
TwilightZone
Oddometer: 3,184
Warp 9 Wheels...
Hmmm... so are they any good?
Dammit. I've dented my DID rim from running too low a pressure in the front tire.
Looks like I'm either going to get an Excel rim and re-spoke or maybe a new Warp 9.
Thoughts on the above ?
"I don't really know, I've been too busy falling down."
TwilightZone is online now   Reply With Quote
Old 02-24-2013, 07:32 AM   #33349
swimmer
armchair asshole
swimmer's Avatar
Oddometer: 4,956
For any of you So Cal guys I noticed there was an IMS 4.7 on the SD CL for $300. Apparently new. Wish it was closer to me.
swimmer is offline   Reply With Quote
Old 02-24-2013, 08:19 AM   #33350
EEKAMOUSE
EEKAMOUSE's Avatar
Oddometer: 364
Run it dented if it isn't too bad dents are gonna happen I would only replace after the rim is thoroughly shot.
EEKAMOUSE is offline   Reply With Quote
Old 02-24-2013, 09:31 AM   #33351
TwilightZone
Oddometer: 3,184
<"Run it dented if it isn't too bad dents are gonna happen..."
Yeah, I am monitoring spoke tension in the dented areas.
Trying to put the bike in good shape for some long runs this summer.
Old 02-24-2013, 01:05 PM   #33352
Rapid Dog
bikes, booze, broads...
Rapid Dog's Avatar
Oddometer: 9,654
...puttin' around the block
'91 R100GSPD Derelict Deux , '81 R100RS Rattlecandy Red/'06 950 ADV Orangeboom/91 R100GSPD Derelict etc.
Rapid Dog is offline   Reply With Quote
Old 02-24-2013, 02:13 PM   #33353
avgas
amateur
avgas's Avatar
Oddometer: 83
Hey rapid dog, what kind of nav tower do you have? Or if you built it yourself, could we see some more pictures?
2012 Yamaha WR250R
avgas is offline   Reply With Quote
Old 02-24-2013, 02:59 PM   #33354
ecarnell
ecarnell's Avatar
Oddometer: 414
X2. Interested to see pics also...
2014 KTM 500 EXC
2011 KLR
2012 Dacre Challenge -Team Explore the Bruce - 8th (i.e last) Place. 17:59
ecarnell is online now   Reply With Quote
Old 02-24-2013, 05:47 PM   #33355
UtahFox
UtahFox's Avatar
Oddometer: 446
What can be done to clean up the area under the seat in order to make more space? There seems to be so little room for new electrics. Anyone have any pics?
UtahFox is offline   Reply With Quote
Old 02-24-2013, 06:05 PM   #33356
skierd
Wannabe Far-Rider
Oddometer: 2,988
Short of cutting off the top of the airbox and making a new floor/top, or wholesale rewiring the bike, not much. What are you trying to fit?
"We wish your trail a long one" - Darlene "Sid" Dowd ~ Never run out of traction, ideas, and real estate at the same time.
2008 Yamaha WR250X
Eastern TAT 8/2009 ~MD-Key West-Oklahoma 4/2011~Maryland to Alaska 3/2012
skierd is offline   Reply With Quote
Old 02-24-2013, 06:20 PM   #33357
UtahFox
UtahFox's Avatar
Oddometer: 446
I'm putting a rally fairing on with a GPS mount and some kind of a power connector for the dash, and I'm getting a Juicebox.. I'm pretty sure I can use the battery tender for a vest? I think that'll cover it.
Old 02-24-2013, 07:35 PM   #33358
henrymartin
Mr. Tourguide
henrymartin's Avatar
Oddometer: 3,714
This is a follow up on my seal guard issue at 5k, where I stated my opinion that the OP did not do proper maintenance. Some here disagreed with me. So, let's see if the last pic changes your mind.
I got the swingarm and linkage complete off, cleaned everything well, took the bearings apart and lubed them with Maxima blue waterproof grease.
The stock bearings had some weird plastic lube sticks in there (there is a name for it) that appeared almost dry, so in went the pick and out came the plastic lube thingy.
Once everything was nice and clean, I got ready for reassembly.
Than is, until I decided that it would be good to repack the wheel bearings while I have it apart.
Surprise!
henrymartin is offline   Reply With Quote
Old 02-24-2013, 08:23 PM   #33359
isaac004
isaac004's Avatar
Oddometer: 862
ADV Monster Lights and Giant Loop Mounting Point
Just wanted to share a few mods I had done recently.
First off, I installed some of these eye bolts where the rear foot pegs used to go. They work great for a tie down point for Giant Loop bags (I use a Mojave and a Coyote on mine). Yes, they can hit your ankles a little, but they do not bother me, especially since I ride in big MX boots (Sidi Flex Force).
For reference, I ordered M8x1.25 thread, 13mm thread length. The eye bolt hole inner diameter, while not critical since it's just a nylon strap that passes through, is 20mm.
I also mounted a pair of ADV Monster Model 60 LED lights. One of my buddies install his onto the fork reflector bracket that bolts to the lower triple clamp, but I could not get mine to clear my 2.7 gal Safari gas tank, even after flipping the brackets around. So I decided it would be best to bolt them up to my handlebar guards. This will keep the lights up high, allow them to turn with the steering, and also have a good spread apart so oncoming traffic can see them easier.
The lights come with a heavy duty bracket ($10 extra for heavy duty over normal), and I just had to drill one hole and supply one bolt/nut per side. Wired these up to a relay/fuse to come and and off with the bike.
I have not ridden off road yet with these lights, but when my buddy used them on his WR250R at LAB2V, he said it was incredible. I have used these on my F800GS at night, and I LOVE them. A very bright set of lights indeed.
isaac004 screwed with this post 02-25-2013 at 08:52 AM
isaac004 is offline   Reply With Quote
Old 02-24-2013, 09:19 PM   #33360
UtahFox
UtahFox's Avatar
Oddometer: 446
Nice lights, those look pretty cool and I'm sure they'll be bright as hell. I like the eyebolt idea as well, gonna bank that one. :)
Times are GMT -7.   It's 04:36 PM.
