Old 02-24-2013, 02:01 PM   #5581
IronSpadeCycles
Button Pusher
IronSpadeCycles's Avatar
Oddometer: 160
I ran the IMS 4.0 gallon tank. You have to have either really small hands or don't be afraid to burn yourself if you think your going to adjust the idle with that tank. I could do road side jetting changes without removing the tank, but several times I thought about making some kind of quick release as you have to forget about pulling a plug without pulling the tank.
When I first started the trip I was getting between 55 to 65 MPG on super unleaded in most road/off road conditions, but I noticed depending on the state I was in a 15% to 20% loss of mileage due to older or unregulated ethanol blends. Arizona fuel was absolute crap! In northern AZ going toward New Mexico my mileage dropped off to about 43 MPG. I almost ran out of gas a couple times between stops. Also the 4.0 IMS tank will run out of gas with as much as 2/3rd a gallon still in the tank. I had to stop and lay the bike completely on its side to get the fuel from the right side to the left. That totally sucked with a bike loaded with gear pushing 350lbs.
I imagine if I didn't have all that gear, (I did realize after the trip was over I could have left half of it at home) and I could have carried an extra chain and sprockets for the off road days I did in Moab UT and central Oregon I would have set up a more Hwy friendly 16/38 and then run a 14/44 for off road. I learned the hard way that although my almost stock XR400 was an alright DS at Hwy speeds its really a low speed forest bike. I imagine the new 440 11:1 kit and the stage 2 cam, CRF cam chain and prepped carb will change my thoughts a bit when I finally get to ride her.
I have several other bigger touring and bigger dirt bikes in my collection but I really love my little XR4 and will keep riding her till the wheels fall off.
Good luck with yours.
www.theroadmuchlesstraveled.com
____________________________________
I'm a collector of fine crap!
IronSpadeCycles is offline   Reply With Quote
Old 02-24-2013, 02:21 PM   #5582
IronSpadeCycles
Button Pusher
Oddometer: 160
Also I might add, after doing 5000+ miles, do yourself a favor and go ahead and change the wheel bearing and seals now before you take her out on another long ride. Those are not as readily available in remote areas as you might think and waiting in some hick town for a week for All Balls to rush you a $20 set of bearing is anti productive.
As far as the electrics are concerned, I followed a thread on this forum on hand winding your own stock stator and I wound mine for about 200w with 18G copper, hooked it to a $50 generic Reg/Rec and built my own new wiring harness with really high end silicone covered marine grade wires. I could run my 65/100w KTM Adventure headlight all night long and never once did it drain the tiny 1000 mah SLA battery I added. I also had my Garmin GPS, a Trailtech speedo/tach/temp gauge, 2 charging jacks for phone and computer battery chargers running, again never killed the battery. I left the light on for about 30 minutes setting up camp one night in the middle of no where with not even moon light to help. The battery was low when I shut it off but she fired right up thanks to the CDI ignition.
I do love this bike.
Old 02-24-2013, 03:12 PM   #5583
Clem Kevin
Nude With Boots
Clem Kevin's Avatar
Oddometer: 495
Send a message via AIM to Clem Kevin Send a message via MSN to Clem Kevin Send a message via Skype™ to Clem Kevin
Where did you place the battery? I'd love to see a photo; I've been considering a similar upgrade.
Clem Kevin is offline   Reply With Quote
Old 02-24-2013, 06:51 PM   #5584
cbig
Rift- Raft, SCooter Trash
cbig's Avatar
Oddometer: 800
Fork question
I have a set of $50 forks I am running on my 2000 xr. I believe the forks are 1997. Yesterday I tore the forks down and replaced the seals . One had been leaking pretty bad. Replacing seals is easy enough. I was looking at the valve bolt and wondering just how effective the removal of 6 shims is. I hear a lot about it. . Thought that might be a bit much. It appears to me the oil flows up from below and the 12 shims act as a limit on how much can flow thru the valve body. By removing shims, more oil can flow as the stack can rise higher to the stop, creating a larger passage.
I might want to try it, tho I am not unhappy at all with the forks. After going thru the hassle of taking off the fork caps, using the cartridge grabbing tool I made and either using a socket wrench or gently impact wrenching off the bottom bolt, I wonder... I know I can gun it off, but if I leave the fork cap on, cartridge all intact, can the bolt be put back on? This way I could turn clean forks upside down, screw with what I need without messing with oil levels, etc?
Seems there's a reason it can't be put back on this way; I was just in it and should remember but I got crs! (Can't remember shit)
Cbig
cbig is offline   Reply With Quote
Old 02-24-2013, 07:31 PM   #5585
Stretch67
Mad Scientist
Stretch67's Avatar
Oddometer: 3,168
For more info on the Shim Stack Mod, czech out Posts 4159-64, 4180-82, 5374, 5467 of this thread.
Stretch67 is online now   Reply With Quote
Old 02-24-2013, 09:03 PM   #5586
IronSpadeCycles
Button Pusher
Oddometer: 160
Clem, I folded up a little tray from some scrap aluminum that fit the battery just right and mounted in the top of the airbox where the snorkel goes. I then cut the five 1-1/4" holes along the top right side to let the airbox breath better. As long as I stay out of deep water, the holes work fine. I mounted the Reg/Recon the frame backbone near the coil. I don't have any good pictures of it but it worked well.
I hope this helps. Later Travis
Old 02-25-2013, 06:17 AM   #5587
tonusmaximus
maximus
tonusmaximus's Avatar
Oddometer: 159
Looking for choke plate return spring and cover for my cb125. Have been up since 4am searching net and parts. Looks to be the same as one on my xr400 so I posted here. Keihin pd carby.
tonusmaximus is offline   Reply With Quote
Old 02-25-2013, 08:55 AM   #5588
RideFreak
Torque Junkie
RideFreak's Avatar
Oddometer: 3,561
The 6 shim mod is really for enduro style technical riding, roots, ledges etc... if you ride allot of whoops it's probably going to be a little soft on compression. In technical terrain it will soak up bumps allot better with less deflection.
I don't see why the method you described shouldn't work. I popped mine off with an air gun, I use that method on allot of forks and haven't jacked one up yet. I purposly use an airwrench that isn't real strong and I'm used to it, crankin the compression valves off with a honkin gun you're not used to could definately cause some issues.
Chris
VIDEOS
RideFreak is offline   Reply With Quote
Old 02-25-2013, 09:31 AM   #5589
cbig
cbig's Avatar
Oddometer: 800
Getting the bolt off was not
An issue, I want to be able to put it back on without disassembly. I think all the stuff should stay in place....but no cartridge holding tool. What I'm asking is if the friction from the spring with the forks upside down will hold the cartridge enough to get to the 34 Nm specified?
I took the forks apart Saturday with the air gun, easy. Putting it all back together required a tool I made out of a piece of pipe. If spring tension is all I need, when I go out camping I can screw with the shim removal and not have to mess with pouring back in my already clean oil. I can screw around with the shimming I like. Having an air gun camping will be more trouble than its worth as I wouldn't want to put it on that way and risk stripping it and running the motorhome engine for the air supply is a pain.
Should be a major improvement on rocks? Seems ok now but more is better!
Cbig
cbig screwed with this post 02-25-2013 at 09:52 AM
Old 02-25-2013, 11:10 AM   #5590
G600
Oddometer: 314
.... What I'm asking is if the friction from the spring with the forks upside down will hold the cartridge enough to get to the 34 Nm specified?...
No. You will need to assemble with a air gun. You can mess up if you don't know what you are doing.
G600 is offline   Reply With Quote
Old 02-25-2013, 05:29 PM   #5591
RideFreak
Torque Junkie
RideFreak's Avatar
Oddometer: 3,561
I dodn't have oil in it at the time but I threaded on the top cap, turned it upside down, started the compression unit by hand then compressed the forks and hit it with the gun. I was able to line up the lower end of the dampening rod with my pinkie prior to starting the compression stack, I don't even own one of those tools.
Chris
VIDEOS
Old 02-26-2013, 09:05 AM   #5592
cbig
cbig's Avatar
Oddometer: 800
Chris
THanks, I got it. I see I may need the impactor to turn it enough to get the friction to 34 Nm. I can do that easily without the other tool. Might screw with that next time out. Thanks, btw your videos are interesting, especially the Moab stuff. New Mex like that? Might have to put that on my to see list.
Chuck
Cbig
Old 02-26-2013, 02:30 PM   #5593
Stretch67
Mad Scientist
Stretch67's Avatar
Oddometer: 3,168
My swingarm bolt came out!
No muss, no fuss. Some gloriously appreciated previous owner removed it and greased it years ago, and it came out this afternoon with minimum hassle.
Old 02-26-2013, 02:32 PM   #5594
tonusmaximus
maximus
Oddometer: 159
go immediately and get a lottery tickey u lucky @#%$¥¢:-X:-[:-D:-(:-/
Old 02-26-2013, 03:19 PM   #5595
DrLewall
DrLewall's Avatar
Oddometer: 23,840
you lucky bastid!
DrLewall is offline   Reply With Quote
Times are GMT -7.   It's 08:59 PM.
