Old 02-24-2013, 09:47 PM   #33361
pfy50
Professional nOOb
pfy50's Avatar
Oddometer: 586
Originally Posted by henrymartin View Post
This is a follow up on my seal guard issue at 5k, where I stated my opinion that the OP did not do proper maintenance. Some here disagreed with me. So, let's see if the last pic changes your mind.
The stock bearings had some weird plastic lube sticks in there (there is a name for it) that appeared almost dry, so in went the pick and out came the plastic lube thingy.
Surprise!
HM,
It's called MPL a polylube that could have been left in. Read this article it explains it: http://www.thumperfaq.com/swingarm.htm
My Odyssey: http://www.advrider.com/forums/showthread.php?t=566875
2013 TEX XC,2011 WR250R,2004 KAWA Concours,1994 BMW K1100RS
May the Lord bless you and keep you in all the Dark places you must travel
pfy50 is offline   Reply With Quote
Old 02-24-2013, 10:00 PM   #33362
Scott_PDX
Leisure Engineer
Scott_PDX's Avatar
Oddometer: 3,438
Originally Posted by isaac004 View Post
Just wanted to share a few mods I had done recently.
Good tips. I have my lights mounted low on the reflector mount. It's less than idea, snags on branches and gets too dirty. Think I'll try the barkbuster mount.
2014 KTM 690R, 2009 KLR650, 2004 KTM 450 EXC, 2000 R1150GS
My MotovLog (Youtube Videos): http://www.youtube.com/user/scottb572/videos
Where Am I via SPOT (Code SCT): http://www.advrider.com/forums/showthread.php?t=719703
Scott_PDX is online now   Reply With Quote
Old 02-25-2013, 05:24 AM   #33363
henrymartin
Mr. Tourguide
henrymartin's Avatar
Oddometer: 3,653
Originally Posted by pfy50 View Post
HM,
I did see that before I opened her up, but the lube had some dirt in it, the bushings had a little rust pitting, and there was dirt behind the seals, so I dug it out to clean it properly. Solvent and all
Thanks for the suggestion though.
henrymartin is offline   Reply With Quote
Old 02-25-2013, 06:15 AM   #33364
rjnutt
Desert tortoise
rjnutt's Avatar
Oddometer: 249
Wiring option
Eastern Beaver makes a really nice three circuit loom that with a little finesse fits into our available space nicely. He provides a couple of switched and unswitched
Variations.
http://easternbeaver.com/Main/Wiring...3_circuit.html
QUOTE=UtahFox;20802605]I'm putting a rally fairing on with a GPS mount and some kind of a power connector for the dash, and I'm getting a Juicebox.. I'm pretty sure I can use the battery tender for a vest? I think that'll cover it.[/QUOTE]
rjnutt is offline   Reply With Quote
Old 02-25-2013, 07:06 AM   #33365
shep546
shep546's Avatar
Oddometer: 215
Hey guys, I'm looking at doing an exhaust mod before spring.
My bike is stock performance wise. I don't really have the money or desire to do a full exhaust,header,chip system I'd just like a decent slip on so my bike doesn't sound like an electric lawn mower.
If I throw a slip on and header on my bike and do the flapper mod do I need a new programmer? What if I don't do a flapper mod?
What about just a slip on plus flapper mod, would it still need to be programmed?
edit: also has anyone heard of the "Bazzaz Z-FI Fuel Fuel Management System" ?
Is it the same as fmf?
shep546 is offline   Reply With Quote
Old 02-25-2013, 07:17 AM   #33366
GSBS
FunHog
GSBS's Avatar
Oddometer: 3,950
Use the bike's computer...
You can adjust the rich/lean mix with the built-in CO mode on the bike's computer. I removed AIS, EXUP, opened air box, and simultaneously installed an FMF slip-on pipe (no header) and changed to a K&N air filter
Once I accessed the CO mode in the bike's computer menu (you hold down this button, then that, then another on the instrument cluster - details are somewhere in this thread) it was set on minus 4 and I changed to a plus 2 or plus 3. That was 18K miles ago and bike runs strong and I've had no issues. It's never made any sense to me to pay for a programmer when my bike runs great without one!
YRMV
GSBS is offline   Reply With Quote
Old 02-25-2013, 07:24 AM   #33367
shep546
shep546's Avatar
Oddometer: 215
YRMV
So you just assumed that was a good mix? How do you know if your mix is good? Just listen to the bike and see how it pulls?
Old 02-25-2013, 07:26 AM   #33368
swimmer
armchair asshole
swimmer's Avatar
Oddometer: 4,706
First off, I installed some of these eye bolts where the rear foot pegs used to go. They work great for a tie down point for Giant Loop bags (I use a Mojave and a Coyote on mine). Yes, they can hit your ankles a little, but they do not bother me, especially since I ride in big MX boots (Sidi Flex Force).
Do you recall the thread size for the eyelets? I don't have my WR with me at work and I'd like to get a couple of these ordered. Thanks
swimmer is offline   Reply With Quote
Old 02-25-2013, 07:51 AM   #33369
DougZ73
Fading off.........
DougZ73's Avatar
Oddometer: 7,109
^^^^^ M8 X 1.25 IIRC. You can check fiche for the rear peg mounts to know for sure.
Skyline Drive 11/2010 , Catskills 2010 trip, Catskills 2011 , Southern TNJT, 2011
DougZ's MTB thread , DZ Moto Photo Bloggin' , (my) Learning photography thread, DougZ vids
- Ryder Joseph Z. , Born 11/26/12-- the next Adventure: Grayson Hunter Z., born 5/3/14
DougZ73 is offline   Reply With Quote
Old 02-25-2013, 08:03 AM   #33370
swimmer
armchair asshole
swimmer's Avatar
Oddometer: 4,706
Thanks. McMaster has these in 304 SS for $5.17. Item 3100T11.
Old 02-25-2013, 08:31 AM   #33371
GSBS
FunHog
GSBS's Avatar
Oddometer: 3,950
No, you can ride the bike and adjust on the fly. Then whenever you've got it like you want it saves the last setting when you turn off the ignition. I checked the spark plug to make sure it wasn't too rich or lean.
Not rocket science.
Bike runs strong and I haven't had any maintenance issues resulting in many thousands of miles. Works for me.
But if you'd feel better spending $200-300 for a programmer, by all means do so. Just relating my experience.
Old 02-25-2013, 08:51 AM   #33372
isaac004
isaac004's Avatar
Oddometer: 849
Yep, I ordered M8x1.25 thread, 13mm thread length. The eye bolt hole inner diameter, while not critical since it's just a nylon strap that passes through, is 20mm.
isaac004 is offline   Reply With Quote
Old 02-25-2013, 09:10 AM   #33373
DougZ73
Fading off.........
DougZ73's Avatar
Oddometer: 7,109
No problem. I had ordered these, to go with my wolfman rack/dirtbagz set up.
Old 02-25-2013, 11:44 AM   #33374
swimmer
armchair asshole
swimmer's Avatar
Oddometer: 4,706
Is anyone using the Wolfman Expedition side bags without the side rack? If so how is it working out?
Old 02-25-2013, 02:35 PM   #33375
UtahFox
UtahFox's Avatar
Oddometer: 446
What is...
...this? Sorry, I'm pretty new at wrenching in general, and the WRR in specific.
UtahFox is offline   Reply With Quote
Times are GMT -7.   It's 08:38 PM.
