02-23-2013, 11:31 AM
#3346 |
Grip and rip since 1983
Oddometer: 609
You'll be fine
I did the TAT last year on a DRZ400 and I met inmate Backlash on the last day on his '13 500EXC. He did the entire trip and changed the oil a few times. No big thing. Three drain plugs (all 13mm), easy air filter access.
I bought his EXC a few weeks ago and maintenance isn't a big deal. Go for it! This bike is special.
I coulda been an actor, but I wound up here. |
02-23-2013, 04:43 PM
#3347 |
Oddometer: 67
Got it wrong, the correct torque is 44NM for the sprocket bolt. The rest of what I said still applies.
02-24-2013, 11:04 AM
#3348 | |
Befuddled Adventurer
Oddometer: 1,210
Quick question. What is the 90 degree plastic elbow to the right of the above Golan?
Cheers, Team FTB ------------------ Team "Fingering The Bean" Looking for the woman that takes the wheel when I'm seeing double. |
02-24-2013, 11:49 AM
#3349 | |
Migration to offroad
Oddometer: 36
Impact of lost spark arrestor screen
I just lost my first screen...should have read this thread earlier!
It certainly makes a difference in the sound, but I also noticed a simultaneous and considerable increase in backfire upon decel. Is that typical when you lose the screen? Bike has 6 hrs on it, and backfired a small amount up until the change in exhaust note, which I am attributing to the lost screen, although I don't know if the screen departed at exactly the same time as the exhaust note changed. The backfire now also occurs slightly when closing throttle to shift up. I can't get a replacement part for a week or so. Is it dangerous for the engine to run it with that much backfire? Is there another possible cause for sudden change in exhaust note and increase in backfire. This occured while accelerating hard up a hill, coming out of a turn. Quote:
Notaduke screwed with this post 02-24-2013 at 02:35 PM |
02-24-2013, 12:57 PM
#3350 |
USMC Veteran
Oddometer: 13
02-24-2013, 04:46 PM
#3351 |
Adrenaline Junkie
Oddometer: 77
Im not trying to tell anyone how to do anything but wouldnt you want that filter down stream of the quick disconnect? Whenever I take the tank off even after taking extra care to clean that area Im super aware that Im opening the fuel system and I always find some dirt directly on that fitting. Guess Im going to learn my lesson the hard way because Im leaving the stock filter system. Ive replaced the filter once already which hasnt been much trouble to do during a valve check when the tank is off. |
02-24-2013, 05:03 PM
#3352 | |
USMC Veteran
Oddometer: 13
#3353 | |
Oddometer: 36
What am I missing?
Miraculously, I returned to where I recall detecting the change in exhaust note to search for the screen/screw retainer, and actually found both!
I suspect there must be something missing still, although I have both parts, since the the diameter of the screen (shaped like a bottle cap) is considerably smaller than the screw retainer. Does the proper screen have some sort of ring that the perforated bottle cap attaches to? Hopefully I finally figured out how to post a picture image! Quote:
Notaduke screwed with this post 02-24-2013 at 05:40 PM Reason: image posting problems |
02-24-2013, 08:14 PM
#3354 | |
Oddometer: 67
02-24-2013, 09:21 PM
#3355 |
Oddometer: 36
Great, thanks. That solves that part of the puzzle, although this pie pan with a pie in it seems like a pretty bizarre piece of engineering.
I guess I can't say with 100% certainty until I get a new screen installed, but it seems to me that losing that screen has an amazingly big impact on the backfire situation. Must be right on the edge with it installed. |
02-25-2013, 05:40 AM
#3356 | |
Oddometer: 977
More than twice as many Americans died in British concentration camps during the Revolutionary War as died in combat. Don't believe it? Google prison ship martyrs monument. 350EXC-F |
02-25-2013, 07:16 AM
#3357 | |
Oddometer: 281
Does this alway happen?
This might be the answer to a question I asked a while back. I was trying to figure out how to make sure I had the Euro map installed. TIA Unkgd screwed with this post 02-25-2013 at 07:25 AM |
02-25-2013, 01:44 PM
#3358 |
Oddometer: 21
Screen is removed from mine & I have Euro map with switch & blocked SAS, etc. It doesn't backfire now on decel.
02-25-2013, 02:13 PM
#3359 | |
Oddometer: 8
02-25-2013, 03:06 PM
#3360 | |
Oddometer: 122
Exact same experience here as Boostracer.
-Fortunately still working on my Bucket List- 2013 KTM 500EXC 2012 Triumph 800XC 2011 KTM 300 XC 2010 KTM 990 SMT |
