Old 02-24-2013, 06:20 PM   #33361
UtahFox
UtahFox's Avatar
Oddometer: 421
Originally Posted by skierd View Post
Short of cutting off the top of the airbox and making a new floor/top, or wholesale rewiring the bike, not much. What are you trying to fit?
I'm putting a rally fairing on with a GPS mount and some kind of a power connector for the dash, and I'm getting a Juicebox.. I'm pretty sure I can use the battery tender for a vest? I think that'll cover it.
UtahFox is offline   Reply With Quote
Old 02-24-2013, 07:35 PM   #33362
henrymartin
Mr. Tourguide
henrymartin's Avatar
Oddometer: 2,558
This is a follow up on my seal guard issue at 5k, where I stated my opinion that the OP did not do proper maintenance. Some here disagreed with me. So, let's see if the last pic changes your mind.
I got the swingarm and linkage complete off, cleaned everything well, took the bearings apart and lubed them with Maxima blue waterproof grease.
The stock bearings had some weird plastic lube sticks in there (there is a name for it) that appeared almost dry, so in went the pick and out came the plastic lube thingy.
Once everything was nice and clean, I got ready for reassembly.
Than is, until I decided that it would be good to repack the wheel bearings while I have it apart.
Surprise!
henrymartin is offline   Reply With Quote
Old 02-24-2013, 08:23 PM   #33363
isaac004
isaac004's Avatar
Oddometer: 402
ADV Monster Lights and Giant Loop Mounting Point
Just wanted to share a few mods I had done recently.
First off, I installed some of these eye bolts where the rear foot pegs used to go. They work great for a tie down point for Giant Loop bags (I use a Mojave and a Coyote on mine). Yes, they can hit your ankles a little, but they do not bother me, especially since I ride in big MX boots (Sidi Flex Force).
For reference, I ordered M8x1.25 thread, 13mm thread length. The eye bolt hole inner diameter, while not critical since it's just a nylon strap that passes through, is 20mm.
I also mounted a pair of ADV Monster Model 60 LED lights. One of my buddies install his onto the fork reflector bracket that bolts to the lower triple clamp, but I could not get mine to clear my 2.7 gal Safari gas tank, even after flipping the brackets around. So I decided it would be best to bolt them up to my handlebar guards. This will keep the lights up high, allow them to turn with the steering, and also have a good spread apart so oncoming traffic can see them easier.
The lights come with a heavy duty bracket ($10 extra for heavy duty over normal), and I just had to drill one hole and supply one bolt/nut per side. Wired these up to a relay/fuse to come and and off with the bike.
I have not ridden off road yet with these lights, but when my buddy used them on his WR250R at LAB2V, he said it was incredible. I have used these on my F800GS at night, and I LOVE them. A very bright set of lights indeed.
A Father and Son Trip Down the Great Divide: http://www.advrider.com/forums/showthread.php?t=606301
A Father and Son Trip Through Death Valley: http://www.advrider.com/forums/showthread.php?t=869090
BMW F800GS, Yamaha WR250R, Suzuki DR650
isaac004 screwed with this post 02-25-2013 at 08:52 AM
isaac004 is offline   Reply With Quote
Old 02-24-2013, 09:19 PM   #33364
UtahFox
UtahFox's Avatar
Oddometer: 421
Nice lights, those look pretty cool and I'm sure they'll be bright as hell. I like the eyebolt idea as well, gonna bank that one. :)
Old 02-24-2013, 09:47 PM   #33365
pfy50
Professional nOOb
pfy50's Avatar
Oddometer: 350
Surprise!
HM,
It's called MPL a polylube that could have been left in. Read this article it explains it: http://www.thumperfaq.com/swingarm.htm
My Odyssey: http://www.advrider.com/forums/showthread.php?t=566875
2011 WR250R,2008 KTM 990 ADV,2004 KAWA Concours
May the Lord bless you and keep you in all the Dark places you must travel
pfy50 is offline   Reply With Quote
Old 02-24-2013, 10:00 PM   #33366
Scott_PDX
Scott_PDX's Avatar
Oddometer: 1,086
Good tips. I have my lights mounted low on the reflector mount. It's less than idea, snags on branches and gets too dirty. Think I'll try the barkbuster mount.
2011 WR250R
2009 KLR650
2004 KTM 450 EXC
2000 R1150GS
"The older I get, the faster I was"
Scott_PDX is online now   Reply With Quote
Old 02-25-2013, 05:24 AM   #33367
henrymartin
Mr. Tourguide
Oddometer: 2,558
Originally Posted by pfy50 View Post
HM,
I did see that before I opened her up, but the lube had some dirt in it, the bushings had a little rust pitting, and there was dirt behind the seals, so I dug it out to clean it properly. Solvent and all
Thanks for the suggestion though.
Old 02-25-2013, 06:15 AM   #33368
rjnutt
Desert tortoise
rjnutt's Avatar
Oddometer: 192
Wiring option
Eastern Beaver makes a really nice three circuit loom that with a little finesse fits into our available space nicely. He provides a couple of switched and unswitched
Variations.
http://easternbeaver.com/Main/Wiring...3_circuit.html
QUOTE=UtahFox;20802605]I'm putting a rally fairing on with a GPS mount and some kind of a power connector for the dash, and I'm getting a Juicebox.. I'm pretty sure I can use the battery tender for a vest? I think that'll cover it.[/QUOTE]
rjnutt is offline   Reply With Quote
Old 02-25-2013, 07:06 AM   #33369
shep546
shep546's Avatar
Oddometer: 194
Hey guys, I'm looking at doing an exhaust mod before spring.
My bike is stock performance wise. I don't really have the money or desire to do a full exhaust,header,chip system I'd just like a decent slip on so my bike doesn't sound like an electric lawn mower.
If I throw a slip on and header on my bike and do the flapper mod do I need a new programmer? What if I don't do a flapper mod?
What about just a slip on plus flapper mod, would it still need to be programmed?
edit: also has anyone heard of the "Bazzaz Z-FI Fuel Fuel Management System" ?
Is it the same as fmf?
shep546 is offline   Reply With Quote
Old 02-25-2013, 07:17 AM   #33370
GSBS
FunHog
GSBS's Avatar
Oddometer: 3,455
Use the bike's computer...
You can adjust the rich/lean mix with the built-in CO mode on the bike's computer. I removed AIS, EXUP, opened air box, and simultaneously installed an FMF slip-on pipe (no header) and changed to a K&N air filter
Once I accessed the CO mode in the bike's computer menu (you hold down this button, then that, then another on the instrument cluster - details are somewhere in this thread) it was set on minus 4 and I changed to a plus 2 or plus 3. That was 18K miles ago and bike runs strong and I've had no issues. It's never made any sense to me to pay for a programmer when my bike runs great without one!
YRMV
GSBS is offline   Reply With Quote
Old 02-25-2013, 07:24 AM   #33371
shep546
shep546's Avatar
Oddometer: 194
YRMV
So you just assumed that was a good mix? How do you know if your mix is good? Just listen to the bike and see how it pulls?
Old 02-25-2013, 07:26 AM   #33372
swimmer
armchair asshole
swimmer's Avatar
Oddometer: 2,568
Do you recall the thread size for the eyelets? I don't have my WR with me at work and I'd like to get a couple of these ordered. Thanks
swimmer is offline   Reply With Quote
Old 02-25-2013, 07:51 AM   #33373
DougZ73
Lacks Freetime
DougZ73's Avatar
Oddometer: 4,922
^^^^^ M8 X 1.25 IIRC. You can check fiche for the rear peg mounts to know for sure.
DougZ73 is offline   Reply With Quote
Old 02-25-2013, 08:03 AM   #33374
swimmer
armchair asshole
swimmer's Avatar
Oddometer: 2,568
Thanks. McMaster has these in 304 SS for $5.17. Item 3100T11.
Old 02-25-2013, 08:31 AM   #33375
GSBS
FunHog
GSBS's Avatar
Oddometer: 3,455
No, you can ride the bike and adjust on the fly. Then whenever you've got it like you want it saves the last setting when you turn off the ignition. I checked the spark plug to make sure it wasn't too rich or lean.
Not rocket science.
Bike runs strong and I haven't had any maintenance issues resulting in many thousands of miles. Works for me.
But if you'd feel better spending $200-300 for a programmer, by all means do so. Just relating my experience.
Times are GMT -7.   It's 12:14 AM.
