Old 02-25-2013, 08:33 AM   #91
Baja Dad
Baja Dad's Avatar
Oddometer: 1,947
Originally Posted by 640 Armageddon View Post
Remember to check the clearance with the brake caliper. The bolt clearance is very tight. The Touratech magnetic bolt for example would interfere with the break caliper
he is not running a caliper on that side.
We only run 1- front brake.
2015 support: Multitool,GPS IMS Aurora Rally Kriega, Raiden LS2, Helmets,
100Goggles,SIDI,Seat Concepts, Precision Concepts, MX1West,Dunlop
Baja Dad is offline   Reply With Quote
Old 02-25-2013, 08:35 AM   #92
640 Armageddon
-oo-
640 Armageddon's Avatar
Oddometer: 2,597
And we said that a couple of posts ago ...
Goody goody goody
Aurora Rally Equipment
"Do or Do Not. There is No Try" - Yoda
640 Armageddon is offline   Reply With Quote
Old 03-31-2013, 05:47 PM   #93
jrozar
jrozar's Avatar
Oddometer: 618
So how about a update?
jrozar
Las Vegas NV
www.my2wheels.com
jrozar is offline   Reply With Quote
Old 04-01-2013, 11:19 AM   #94
Maineroot OP
Oddometer: 142
Got out with Nate (El Spiderman) on Thurs and rode the SuperTanker Valdez.
The Deathstar is fully functional.
http://www.flickr.com/photos/86168233@N08/8609754961/
Hooked up the roadbook and ICO and a 2 amp USB plug on the dashboard, all run from a dedicated individually fuse protected circuit. Relay runs off the keyed ignition to power up.
Only problem is that when I turn the bike off- the ICO resets to 0. Is that normal? I would think that could be disastrous.
#34 MX1K
TEAM GREENWOOD: Kali Protectives, Hammer Nutrition
Maine Root Handcrafted Beverages, Darco Boot, ATOMIC MOTO,
Klim Riding Gear, Flexx Bars, Seat Concepts Seats, CJ DESIGNS PEGS, FORMA
BOOTS, Tj's Cycle, Austin TX
Maineroot screwed with this post 04-01-2013 at 11:25 AM
Maineroot is offline   Reply With Quote
Old 04-01-2013, 03:38 PM   #95
Baja Dad
Baja Dad's Avatar
Oddometer: 1,947
It should not re-set.
It should not be on the Key power circuit it should be on a 3 amp fuse by it's self
Old 04-01-2013, 07:11 PM   #96
Maineroot OP
Oddometer: 142
So wire it to keep it powered on the entire time? Use a dedicated switch to turn it off at the end of the day?
#34 MX1K
Old 04-01-2013, 07:54 PM   #97
Baja Dad
Baja Dad's Avatar
Oddometer: 1,947
I turns it self off after two hours of no movment.
Or you can hole both buttons on the ICO it will spell OFF and it is turned off
Old 04-02-2013, 06:08 AM   #98
johnson357
Bad Monkey Racing
johnson357's Avatar
Oddometer: 1,251
[QUOTE=
[/QUOTE]
That's no moon, it's a Space Station!
johnson357 is offline   Reply With Quote
Times are GMT -7.   It's 10:01 AM.
