Old 02-23-2013, 06:23 AM   #2791
aadal
Oddometer: 23
Originally Posted by Bell driver View Post
You have to look at the 91 model, that's the ...540...
Doh ... oh yes he sold it to me as a 92 model when in fact it was a 91
ok so model is good 32kw then i will have to check main jet thanks again :-)
I probarbly need a new jet anyways..
aadal is offline   Reply With Quote
Old 02-23-2013, 06:36 AM   #2792
Bell driver
Bell driver's Avatar
Oddometer: 332
Well, to his defense, Germany does not go by model year but by the date the vehicle was first registered/plated for traffic.
You'll find the exact date "Tag der ersten Zulassung" in the papers you hopefully got.
1988 Honda XLV750R
1989 KLR650A
1991 NX650
2007 XR650L
2008 KLR650E
Bell driver is offline   Reply With Quote
Old 02-23-2013, 03:31 PM   #2793
dstriffler
Oddometer: 373
Originally Posted by Bounder View Post
The sprocket is the same for the XR600R to 1990 and all the XL600
Sprocket specialists make one 5033 is the part number.
I don't think the 7 spline one wears as badly as the later 14 spline version.
Ok. So should I buy one for an XR600 or XL600, or get the Sunstar version for an 88 NX?
dstriffler is offline   Reply With Quote
Old 02-23-2013, 03:35 PM   #2794
dstriffler
Oddometer: 373
Whoops, never mind. They're listed as obsolete for the XR600 and XL600! I guess Honda is one step ahead of me
Old 02-24-2013, 05:18 AM   #2795
slowhatch
Oddometer: 22
Hepco and Becker question. From everything I read the crash bars are less than a perfect fit when you go to put them on and require some manuvering to get them to align properly. I'm install my new set of engine bars and the right side bar has a problem hitting the right air deflector on the inside once everything is tight. Has anyone else had the same problem or do I need to just slot the holes a little more on the bars and make it work?
slowhatch is offline   Reply With Quote
Old 02-24-2013, 11:33 AM   #2796
McVick
McVick's Avatar
Oddometer: 234
Need help - can someone take a picture?
Hi gang!
'88 NX650 in the US.
I am making some repars to the mounting tabs on the front fairings and I need some help.
On both front side fairings there is a mounting point that is missing.
It looks like it should line up and mount to the two metal nipples that are coming off of the front side of the fuel tank.
I have no idea what this mounting point is supposed to look like but I would like to recreate it.
Can someone post up a picture of what it looks like?
Brian
Brian McVickers
'88 Honda NX650, '05 KTM 950Adventure, '01 Land Rover DII
www.overlandjournal.com, www.expeditionportal.com, www.overlandrally.com
McVick is offline   Reply With Quote
Old 02-24-2013, 11:57 AM   #2797
Honda Scoot
My First Gold Chain
Honda Scoot's Avatar
Oddometer: 362
I have not test fit my guard. Been fixing body cracks and making tabs for TWO WEEKS!
Slight re-forming, using washers as spacers, and slotting holes could remedy your clearance issues.
McVick, I am intimate with the 1988 body! Point out which ones and could possibly cast some for you.
Honda Scoot is offline   Reply With Quote
Old 02-24-2013, 01:38 PM   #2798
McVick
McVick's Avatar
Oddometer: 234
On your's, do you see the whit dot just behind the "vent".
This spot lines up nicely with the two nipples coming off the tank on each side, one on each side.
I believe something should go where the white dot is and secure to the metal nipple on the front of the fuel tank.
If I am wrong, does any one know what the metal nipples ar on the front of the fuel tank?
Brian
Brian McVickers
Old 02-24-2013, 01:53 PM   #2799
Honda Scoot
My First Gold Chain
Oddometer: 362
Sorry. Every parts fiche I saw said those little connector bits are obsolete. I wanted them as well. The broken point of attachment to the fairing is tiny. I am willing to go with out them.
Made push connectors
Filled in panels
Made tabs
Honda Scoot screwed with this post 02-24-2013 at 02:47 PM
Old 02-24-2013, 11:20 PM   #2800
Bounder
ExternallyDisplaced
Oddometer: 837
Originally Posted by McVick View Post
Brian
The metal ears on the tank are meant to have rubber grommets in them.
The towers on the fairing that are slightly forward and below the duct have a teardrop shaped end, this pushes into the rubber grommet on the tank to secure the fairing.
The same system is used for the sidepanels to hold them to the frame.
Bounder is offline   Reply With Quote
Old 02-25-2013, 06:27 AM   #2801
dstriffler
Oddometer: 373
I took a pic of what the mounting bracket looks like. I can measure if anyone needs.
Old 02-25-2013, 10:32 AM   #2802
Pablo83
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,809
Nice work, Scoot. Looks time-consuming.
Originally Posted by Honda Scoot View Post
Pablo83 is offline   Reply With Quote
Old 02-25-2013, 10:48 AM   #2803
Honda Scoot
My First Gold Chain
Oddometer: 362
Yes to time consuming. Not to mention stinky and plastic chips from the dremel going everywhere. Wife of 32 years puts up with it. 17 places needed attention and the rear fender has not been touched. That PlastiFix REALLY WORKS. Long term will tell how well.
It has been slow and tedious, but I came home for lunch today to find a package from MMOTOPARTS. Needless to say my enthusiasm for this project got a giant boost!
Old 02-25-2013, 12:32 PM   #2804
Bounder
ExternallyDisplaced
Oddometer: 837
Thats a very tidy looking rack, great work on the fairings. Time consuming but rewarding I guess?
Old 02-25-2013, 03:14 PM   #2805
dstriffler
Oddometer: 373
I just received an email back from Sunstar about the sprocket size. This is it:
HI Dave,
This has turned into an interesting question actually.
I’ve been researching it and it looks like this may be mis-listed in our catalog. We show our 320xx front sprocket for the NX but I’ve checked a couple of our competitors and compared the specifications and it looks like the total height, with the embossed side of the sprocket should be 10mm and our 320 is only 7.8mm.
Do you have the OE part that you pulled off where we can check the measurement with a set of calipers? I’m guessing its supposed to be 10mm and ours is listed in error but would need to check against the OE part to be certain.
Thanks,
Mike Ivers
937-743-9049 x1334
Sunstar E.A.
www.sunstar-mc.com
700 Watkins Glen Dr, Franklin , OH 45005
Times are GMT -7.   It's 09:56 AM.
