Old 02-24-2013, 04:37 PM   #1
vice OP
Oddometer: 13
First Oil Change Complete
Just completed my first oil change on my new to me 08 Adventure.
I took my time, so it took a couple of hours. It was a good way to get to know the bike.
One question:
1. Why the heck is the crash bar so hard to put back on?
Thanks in advance!
vice is offline   Reply With Quote
Old 02-24-2013, 06:10 PM   #2
Orangecicle
Quest Adventurer
Orangecicle's Avatar
Oddometer: 2,695
Originally Posted by vice View Post
One question: Why the heck is the crash bar so hard to put back on?
http://www.advrider.com/forums/showthread.php?t=626041
I about went crazy trying to get the bars on correctly the first time. Convert the front mount point to studs, and putting on the crash bars is simple.
Another trick is to just start the top tank bolt but don't tighten at all until you have all the other bolts started.
Orangecicle is online now   Reply With Quote
Old 02-24-2013, 06:21 PM   #3
Katoom119
Mmmm....Orange Kool-aid
Katoom119's Avatar
Oddometer: 1,836
If you plan on keeping the crashbars then do the stud mod. Frig-a-mighty the amount I cussed trying to put those back on. I finally just said "screw it" and bought Safari tanks.
Those who dance are considered crazy by those who do not hear the music.
I am not the same having seen the moon shine on the other side of the world. - Radmacher
5 Cylinders vs. Moab..........My East Tennessee.........Internships may go to Hell and I will go to Alaska
Katoom119 is offline   Reply With Quote
Old 02-24-2013, 06:46 PM   #4
vice OP
Oddometer: 13
Thanks for the info!
Old 02-24-2013, 07:11 PM   #5
nordicbiker
Oddometer: 156
Definetly right!
I damaged the thread of the front screws (which go into soft aluminium motor holder) when I did my first oil change. So glued in some stainless screws, which I had "head amutaded" and that works very nice!
I found it worst to take off and get back the left side tank. You would best need four hands to get all the connections un/redone, while holding the tank. You can have it a bit easier if you drain the fuel first through the shutoff valve on the bottom, 'cause the connection tubing needs to come off there anyway.
The 950/990 is probably one of the worst bikes, when it comes to service friendyness. First oil change took me over two hours. It's so much easier on the 690 I got later!
Everyone with a 990: be VERY careful when reattaching the crash bars to the frame: behind the tube where the crash bar is clamped on, there is a hidden cable going to the lambda sond! If you don't take it out of the way you will very likely cut the cable by accident and that would become very expensive. No problem for 950 owners, since there is no catalytic converter, I guess!
www.nordicbiker.se
nordicbiker is offline   Reply With Quote
Old 02-25-2013, 11:06 AM   #6
gefr
Life is a trip
gefr's Avatar
Oddometer: 3,967
A little trick.
The KTM is designed to get serviced on the side of the road. The top tank bolt can be removed but the tank can still hang there, to give access to hoses and cables. There is no need to lift the tank's weight. Just push it around gently, avoiding to unhook it.
Cheers.
Times are GMT -7.   It's 07:03 PM.
