Old 02-25-2013, 06:18 PM   #13516
enduro0125
Sticks and Stones™..
enduro0125's Avatar
Oddometer: 13,693
Hi Tracy,
As you are probably aware, tyres have dots on them which mark the light
spot on the tyre. This is then fitted next to the valve which is
potentially the heaviest part of the wheel and thus to a certain degree
the light spot and heavy spot will counteract eachother.
We did not put balance dots on our tyres as we were striving to
eliminate any light and heavy spots on our tyres. We have been asked
this question about dots many times and as we have improved upon, but
not eliminated the light/heavy spots on our tyres, we have decided to
re-introduced the balance dots on certain new tyres over the coming
weeks. Your tyre will not have a mark on it.
Best regards,
Peter J McNally
M/C Technical Product Manager
Avon Tires
AMA 487807A
enduro0125 is offline   Reply With Quote
Old 02-25-2013, 06:25 PM   #13517
LadyDraco
KillerSmileIHazIt !!
LadyDraco's Avatar
Oddometer: 28,814
Thanks for the giggles...
TISE
Life is what you make of it~If it don't fit make alterations
Check it from time to time as I'm always adding to it..
My Rides and life on the Farm
Just because the road is rocky doesn't mean your spirits should get rocky, too.{Crazy Cora}
LadyDraco is offline   Reply With Quote
Old 02-25-2013, 06:36 PM   #13518
BroncoDave
BroncoDave's Avatar
Oddometer: 3,666
My factory tires were not balanced and had no problems. The next two rear tires I did not balance and had no problems. The last set that I put on, had a pretty good vibration so I decided to balance this one so I don't have to take it off later for balancing. I can't put weights in center due to spoke design. So really nobody answered my question. Does it make a difference if weights on one side or both? Assuming it doesn't matter since all my other bikes only had on one side. While I'm here, does anyone have Olympia air glide pants, if so do you like them?
BroncoDave is offline   Reply With Quote
Old 02-25-2013, 06:38 PM   #13519
rockinrog
rockinrog's Avatar
Oddometer: 2,867
yes
rockinrog is offline   Reply With Quote
Old 02-25-2013, 06:53 PM   #13520
enduro0125
enduro0125's Avatar
Oddometer: 13,693
Just weight,some one will give an answer.
Don't pick sides.
Keep your balance.
Ride on.
AMA 487807A
Old 02-25-2013, 07:01 PM   #13521
Jeff B
Socially Awkward
Jeff B's Avatar
Oddometer: 5,655
These seem pretty balanced......
Jeff B is offline   Reply With Quote
Old 02-25-2013, 07:06 PM   #13522
BroncoDave
BroncoDave's Avatar
Oddometer: 3,666
Don't pick sides.
Keep your balance.
Ride on.
Well done sir
Old 02-25-2013, 07:16 PM   #13523
GearedUp
GearedUp's Avatar
Oddometer: 819
If you are doing the static weight balancing there would be no way of knowing which side was out. I generally just put weights on one side unless I need alot. I've got spoke weights on the KLR and KTM, stickon on the ST. The KTM bounced quite violently on the road as it had only one wheel lock and no weights. After balancing, 3 oz front and 4 rear, its been fine.
08 KLR 650
10 KTM 530 EXC
14 KTM Adventure 1190R
GearedUp is offline   Reply With Quote
Old 02-25-2013, 07:39 PM   #13524
Rich667
Rich667's Avatar
Oddometer: 177
It shouldnt make any difference where you put the weights whether they are in the center or side.
You could also try doing a huge burnout using all sides of the tire and see if that helps with vibration
Rich667 is offline   Reply With Quote
Old 02-25-2013, 08:05 PM   #13525
TowPro
Lets ride
Oddometer: 3,106
I change tires, then put it on the balance before I bead them up. I spin the tire on the rim until I find the best balance, bead them up and ride with no weights.
2015 KTM 690 Enduro R
2014 R1200GS - My Naked Street Touring Bike
2000 KTM LC4 640 E - currently up for adoption with 3200 miles
TowPro is offline   Reply With Quote
Old 02-25-2013, 10:57 PM   #13526
RandoCommando
Wannabe
RandoCommando's Avatar
Oddometer: 1,394
What about buying REUSABLE spoke weights?
A few different places sell them.
http://www.nomartirechanger.com/Spok...wt-spoke14.htm
http://www.aerostich.com/re-usable-w...ts-8-pack.html
1999 KLR 650 (her name is KLaRissa) DOOHICKEY DONE!
2013 BMW F800GS (her name is FranGelicaS)
Please. Ride careful, ride safe, ride defensively! This thread should be mandatory reading!
MySPOT
RandoCommando is offline   Reply With Quote
Old 02-26-2013, 04:27 AM   #13527
beantop
Remember, Safty Forced
beantop's Avatar
Oddometer: 3,979
Just put the effin weights anywhere on the wheel, inside,outside,upside, downside already,,,,,
or use some type of balancing agent inside the wheel (dynabeeds or whatever)
Dan B.
Thanx for your Tyme, Have a Great Day
'00 KTM 640 LC4(yugo) '05 BMW R1200GS(cadillac)
Hi Connie
Peaceful Valley MY ASS (Eddie Bolted)
beantop is online now   Reply With Quote
Old 02-26-2013, 04:41 AM   #13528
BroncoDave
BroncoDave's Avatar
Oddometer: 3,666
Like James bond ?
We had a fox in the yard at1am I love to see them but the crys are blood Awful I think it's mating session
Old 02-26-2013, 05:16 AM   #13529
Mark_O
Drain Bamaged
Mark_O's Avatar
Oddometer: 16,090
For you or the fox?
Sarcasm, just one more free service I provide.
Mark_O is offline   Reply With Quote
Old 02-26-2013, 05:50 AM   #13530
BroncoDave
BroncoDave's Avatar
Oddometer: 3,666
The fox I've not had a mating season in a long tyme
Times are GMT -7.   It's 03:40 AM.
