Old 02-26-2013, 04:48 PM   #24856
1 lunger
1 lunger's Avatar
Oddometer: 1,343
Originally Posted by Captain Nice View Post
Can anyone recommend a good on-line overhaul manual???
Look over on CH or if you locate Jtemple he can send you one.
1 lunger is offline   Reply With Quote
Old 02-26-2013, 09:07 PM   #24857
Baroquenride
Oddometer: 993
Originally Posted by 1 lunger View Post
Unhook your battery for 20 min and it will reset.
Thanks for the pic. I'm a bit confused with the pic. Which side is that? Is that the side closest to the pickup sensor or on the opposite side of the disc? Reason I ask is that I've got what looks like the pic on the other side of the disc from the pick up sensor, but the side facing the sensor looks hollow...like a magnet may have been there and fell out. Anyway, I did unhook the battery and.....no luck.
2000 Honda VFR800, 2008 Husqvarna TE-610
Baroquenride is online now   Reply With Quote
Old 02-27-2013, 01:38 AM   #24858
1 lunger
1 lunger's Avatar
Oddometer: 1,343
That's the spoke side off the disc, I took the photo from the throttle side of bike through the wheel.
Old 02-28-2013, 05:12 AM   #24859
ebrew
Motorcycle A.D.D.
ebrew's Avatar
Oddometer: 1,439
A pict please
Can anyone with a 07 610 take me a pict of the clutch cable routing near the tank rad area? Mine seems very close to the rad cap almost to where if it moved just right it might open the cap up
thanx
I have the big IMS tank
ebrew is offline   Reply With Quote
Old 02-28-2013, 06:58 AM   #24860
1 lunger
1 lunger's Avatar
Oddometer: 1,343
thanx
I run it like this as do most others... then one through the loop that bolt to side cover and do on...
Old 02-28-2013, 07:00 AM   #24861
1 lunger
1 lunger's Avatar
Oddometer: 1,343
You would be hard pressed to get the clutch cable to move enough to open rad cap with it routed the proper way.
Old 02-28-2013, 07:31 AM   #24862
ebrew
Motorcycle A.D.D.
ebrew's Avatar
Oddometer: 1,439
Cool
Thanx. That's how mine is set up just very close to the cap.
Old 03-02-2013, 05:18 PM   #24863
ebrew
Motorcycle A.D.D.
ebrew's Avatar
Oddometer: 1,439
Rear disk guard
Does anyone know if there is a good rear disk guard for the 06 610te? Say Scott's or something like that? They make it for other huskys will they cross over to this model?
Old 03-02-2013, 06:33 PM   #24864
Indy Unlimited
Indy Unlimited's Avatar
Oddometer: 1,479
Hey Erik,
Just buy a shark fin for a TE450 and it will fit with a little grinding clearance on the caliper carrier.
http://www.scottsperformance.com/Pro...2&Bike_ID=5192
The other solutions I have seen are to weak.
Current Stable:
2013 Ducati Hypermotard SP, 2011 Husaberg FE570S, 2011 BMW S1000RR, 2010 BMW F800GS
2007 Husqvarna TE610 , 2003 KTM 525 MXC
Indy Unlimited screwed with this post 03-02-2013 at 07:09 PM
Indy Unlimited is offline   Reply With Quote
Old 03-02-2013, 09:01 PM   #24865
JonXX
Infraction Collector
JonXX's Avatar
Oddometer: 389
Pretty sure Kelly makes one
http://www.motosportz.com/HVA-SS/HVA-SS-Home.htm
Hungry? Out of work? Nowhere to ride? Do us all a favor and eat a Sierra Club member.
"They" said we couldn't run the OBDR on supermotos...
JonXX is offline   Reply With Quote
Old 03-02-2013, 10:21 PM   #24866
BiG DoM
African Adventurer
BiG DoM's Avatar
Oddometer: 2,501
I bought the 511etc one from these guys and with slight mod it works great and matches their front unit that is plug and play. They both do the job - I have tested them! I detailed it in Cafe Husky:
http://www.cafehusky.com/threads/shark-fin-soup.22394/
e-mail them as they might have modded it as well now for 610's but if not an easy fix.
BiG DoM
Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in sideways, thoroughly used, totally worn out and loudly proclaiming... 'Fuck, what a trip!'
People are more violently opposed to fur than leather because it's safer to harass rich women than motorcyclists.
BiG DoM is offline   Reply With Quote
Old 03-06-2013, 04:32 PM   #24867
1 lunger
1 lunger's Avatar
Oddometer: 1,343
So I ordered a new RK GB520exw chain for the 49 tooth iron man I got. They sent me the RK GB520xso instead Will that chain be ok to run off road? Or should I send it back?
Old 03-06-2013, 09:33 PM   #24868
dhawker
Oddometer: 49
A cheap alternative that works well on my 2007 TE 610 is this generic one from Moose Racing:
http://www.reddeerpowersports.com/Moose-Racing-SHARK-FIN-DISC-PROTECTORS-detail.htm?productId=9460441
the profile isn't perfect but pretty darn close. If you spend time redrilling the holes you can get it almost perfect and it does a great job. Been through lots of rock gardens and boulder fields and have never wrecked my rear rotor. Shark fin has taken a beating though and never broke so must be doing its job, and cheap to replace about $20,
dhawker is offline   Reply With Quote
Old 03-08-2013, 04:44 PM   #24869
xymotic
xymotic's Avatar
Oddometer: 8,368
Flywheel puller
Anybody got a flywheel puller I can borrow?
Originally Posted by Just_Sean
Oh for ***k's sake Aaron. Please link us to my fascist, racist or homophobic posts.
"Anyone who doesn't take truth seriously in small matters cannot be trusted in large ones either."
Albert Einstein
Baja trip to the tip
6:10 to Yuma
trials and tribulations in the Mojave
Baja Blitz Yard sale
View Current Location via Spot Tracker
xymotic is offline   Reply With Quote
Old 03-08-2013, 07:32 PM   #24870
BarberPole
Short of the Clacker
BarberPole's Avatar
Oddometer: 30
Capacitor installation
Originally Posted by BrandonR View Post
It's a tradeoff, there isn't a lot of space on the TE to stow the capacitor, the 4700uf cap is easy to get (everyone can find Radio Shack) and small enough to stow easily under the computer.. and seems to work fine.
Hello Brandon,
What guage wire should I use as extensions to the capacitor wire?
Finally free......to be a Servant to Thee
BarberPole is offline   Reply With Quote
Times are GMT -7.   It's 08:41 AM.
