Old 02-06-2013, 07:41 AM   #3286
marco-polo
Oddometer: 90
How easy (or hard) is it to do alterations to a Lombard - specifically the legs?
My body's a misfit, short legs, long arms - a nominal L lower body and 2XL upper body. I'd like to shorten the legs of a 2XL, but don't want to go into alterations hell.
marco-polo is offline   Reply With Quote
Old 02-06-2013, 11:56 AM   #3287
teizms
teizms's Avatar
Oddometer: 1,728
not very easy to alter the suit if you dont go for a custom suit.
the zipper on the legs runs from the neck down to the bottom of the suit - so u r going to mess with that. It wont be easy to replace that zipper in an alterations shop.
order a trial size from and tell us the changes u want. or just send us your measurements. alterations is not going to be an option.
teizms is offline   Reply With Quote
Old 02-13-2013, 01:01 AM   #3288
teizms
teizms's Avatar
Oddometer: 1,728
Specs of the updated Commute Suit:
  • Sas-Tec state of the art elbow, shoulder, hip and knee armor
  • Amazing Sas-Tec CE Level 2 back protector
  • Made entirely from authentic 500 Denier Cordura
  • New comfortable collar design with loop to keep collar open during summer
  • Full array of removable CE approved soft armor including knee, shoulder, elbow and back protectors
  • Reflective stripes all over
  • YKK zippers throughtout
  • Full length front zipper facilitates easy on/off
  • Built-in backpack style pocket
  • Stretch panels on knees, elbows and back
  • Adjustable tabs on the shins, ankles, waist, wrists and arms and cuffs
  • Internal pants access pockets (also useful for heated gear cable pass-through)
  • Built-in waterproof layer
  • Dual front flap for improved waterproofing
  • Updated sleeve cuff design for improved comfort
  • Updated grippy seat
Price: $549 (includes a free trial size). Custom sizing available for $250.
It will only be available in the Hi Viz color scheme. (Hi Viz shell with black accents).
Should be up on our website by this weekend.
Old 02-13-2013, 07:33 AM   #3289
Falconx84
Lurker
Oddometer: 371
My concern with the new suits is that the price is heading up a bit. If it gets much higher, it'll be pit of the range where I can afford new gear instead of used.
Price seems to be getting rather close to some options from the aero brand
V-Strom DL1000k7
Falconx84 is offline   Reply With Quote
Old 02-13-2013, 11:55 AM   #3290
teizms
teizms's Avatar
Oddometer: 1,728
the price has only increased for the CS - which is now full Cordura with Sas-Tec armor (including back protector).
The prices are well below anything with comparable specs..
Old 02-13-2013, 01:52 PM   #3291
Bobmws
Curmudgeon At Large
Bobmws's Avatar
Oddometer: 1,290
Is the waterproof layer a breathable membrane, GoreTex or similar?
Bob Weis 04 K12RS - Hannigan Hack
Everything happens for a reason, but sometimes the reason is you're stupid and make bad decisions.
Photo's: http://s1077.photobucket.com/albums/w464/Bobmws/
www.earplugco.com
Bobmws is offline   Reply With Quote
Old 02-13-2013, 02:45 PM   #3292
teizms
teizms's Avatar
Oddometer: 1,728
yes- its breathable
Old 02-19-2013, 11:48 AM   #3293
teizms
teizms's Avatar
Oddometer: 1,728
The new Commute Suit is now available - updated with an all Cordura construction and Sas-Tec armor
http://store.teizms.com/commute-suit
Old 02-19-2013, 06:59 PM   #3294
AustinP
Oddometer: 34
I was looking forward to your new Commute suit. Am I seeing the right price at 549.00? 150 more than your Lombard suit? That's a big increase over the old Commute suit isn't it? I like your products but that is steep for me, back to Olympia gear I suppose.
AustinP is offline   Reply With Quote
Old 02-20-2013, 02:37 AM   #3295
teizms
teizms's Avatar
Oddometer: 1,728
when compared to the Lombard - the price increase is due to the upgrade in materials and armor .
You always have the option of the Lombard though if you want to stick to that price point.
Old 02-20-2013, 05:10 AM   #3296
Bobmws
Curmudgeon At Large
Bobmws's Avatar
Oddometer: 1,290
Is there no venting in the commute suit?
www.earplugco.com
Old 02-20-2013, 11:22 AM   #3297
teizms
teizms's Avatar
Oddometer: 1,728
there are no vents on the commute suit - to make it more weatherproof.
Old 02-22-2013, 01:29 PM   #3298
wolftrax
wolftrax's Avatar
Oddometer: 422
Hey Mark,
I'm in Fl, a little more heat and humidity than you. I'm usually pretty good with my old Darien set, but it's time for replacement. Any experience with a Darien comparison wise? I've been considering the Roadcrafter lite, but this suit looks good. I'm still kind of torn regarding the water repellency / water proofing discussion. I have the impression this suit will vent better and do fine in our semi normal afternoon showers.Has anyone used a wash in waterproofing on this suit, like Nikwax? I have no problem with adding the liner or donning my FroggTogs if it's going to be an all day rain.
Comments?
The Lombard is definitely not waterproof. I've done the seam seal and Nikwax route and it still leaks. I just don the Frogg Toggs and couldn't be a happier camper. I've ridden in those Florida showers and yes without a top layer of rain gear you will have some leaking. My suit leaks primarily on the arms and the crotch(yuk)!
Sorry cant comment on the Aerostich gear as I have never owned it
Regards
Mark
Mark
2014 Honda CRF250L
2013 Husky TR 650
1990 KLR650
wolftrax is offline   Reply With Quote
Old 02-28-2013, 12:18 PM   #3299
southwade
ΜΟΛΩΝ ΛΑΒΕ
southwade's Avatar
Oddometer: 1,745
Regards
Mark
Mark
Ditto on all accounts.
Also, I just noticed my Lombard has a hood rolled into the collar... I had no idea!
i haz z1000!
southwade is offline   Reply With Quote
Old 03-02-2013, 04:55 AM   #3300
teizms
teizms's Avatar
Oddometer: 1,728
... I just don the Frogg Toggs and couldn't be a happier camper. ....
thats what we recommend as well. cant go wrong with Togs :)
on a different note:
A record number of Revolution & custom suits in the past two months!!! Teiz is now the leading provider of full custom motorcycle clothing. Thanks to our new production process, we are completing custom suits in approx 15 days. Our founders are on their way to China to learn about some new advanced fabrics and technologies so things can only get better from here. Thank you for your support!
Times are GMT -7.   It's 10:22 AM.
