Old 12-07-2012, 10:58 AM   #331
JohnGS1100
JohnGS1100's Avatar
Oddometer: 128
The ecu from 1100 rs is MA 2.2 (1993 model). But i think that the rs has not catalytic.
Can i use it for my catalytic gs1100 ?
JohnGS1100 is offline   Reply With Quote
Old 12-07-2012, 05:28 PM   #332
Poolside
Syndicated
Poolside's Avatar
Oddometer: 11,887
Originally Posted by JohnGS1100 View Post
Can i use monotronic MA 2.4 (from 1100s) on my gs 1100 ? The original one is monotronic 2.2
Not as a plug-n-play swap, the connector pinouts are different. It's possible though. Some number of the 35 pins in the 1100 ECU connector must be relocated to match the 1150 ECU.
IICE Air Hotrod your GS  Fuel Injection  Tech Info  Buy  Order List  Installation
Poolside is offline   Reply With Quote
Old 12-07-2012, 09:25 PM   #333
JohnGS1100
JohnGS1100's Avatar
Oddometer: 128
Thanks. Anyone who has the SCHEMATICS diagram from both ECU ?
Old 12-27-2012, 03:38 AM   #334
Poolside
Syndicated
Poolside's Avatar
Oddometer: 11,887
PM your email address.
Old 12-27-2012, 03:54 AM   #335
Steptoe
steptoe
Steptoe's Avatar
Oddometer: 2,711
Originally Posted by GS-Jake View Post
I didn't realise that this was such an on going problem.
It's not.
It's just the same couple of people who always have the problems.
www.gsshop.biz
Steptoe is offline   Reply With Quote
Old 12-27-2012, 04:03 AM   #336
Poolside
Syndicated
Poolside's Avatar
Oddometer: 11,887
Way to empathize, Neil. 
Old 12-27-2012, 05:31 AM   #337
roger 04 rt
roger 04 rt's Avatar
Oddometer: 2,371
Originally Posted by Steptoe View Post
It's not.
I hear you.
Pinging may not be much of an on-going problem but there seem to be lots of lingering effects of lean-running in the Oilhead fleet. It seems that most owners accept them "just the way they are". My personal favorite symptoms are, "keep the RPMs up, Oilheads love 4-5000RPM", or " ... rarely in 6th gear below 70". With as little as 3-4% more fuel, the Boxer motor is transformed.
Although Lamda shifters can be bought for $160 (Innovate Motorsports LC-1), when someone makes a Nightrider-type Lambda-shifter, then I think there'll be a wave of interest in what these devices can do. Here's a good comparison table: comparison of different lambda settings.
roger 04 rt is offline   Reply With Quote
Old 12-27-2012, 08:17 AM   #338
Poolside
Syndicated
Poolside's Avatar
Oddometer: 11,887
That 'lambda shifter' is fantasy.
Old 12-27-2012, 11:04 AM   #339
Mr. Canoehead
Taste Gunnels!
Mr. Canoehead's Avatar
Location: Calgary, Too far to the mountains and too cold
Oddometer: 1,822
It's not.
If it ain't broke, fix it 'til it is!
Sent from my SGH-I747M using Tapatalk 2
2006 FJR1300A, 2005 GS1150 Adventure, 2002 DR650 SE, a fortune in Farkles.
"No matter how many [internet] opinions you line up, you can't vote nonsense into truth"- Kevin Cameron
Mr. Canoehead is online now   Reply With Quote
Old 12-27-2012, 12:34 PM   #340
roger 04 rt
Oddometer: 2,371
Hi Jim,
Happy Holidays to you too. May you have a prosperous New Year.
RB
Old 12-27-2012, 07:07 PM   #341
Poolside
Syndicated
Poolside's Avatar
Oddometer: 11,887
Hi Jim,
I was referring to the Nightrider 'level shifter' piece you mentioned. Not your LC-1.
Old 03-02-2013, 03:59 PM   #342
JohnGS1100
JohnGS1100's Avatar
Oddometer: 128
Hello again.
The tuning on my bmw r1100gs is continue.
I think to use two ignition coil parallel for better fire spark. The bosch coil gives up to 12.000 Volt. I dont know what happen and how long will be the voltage by one battery. Have anyone some idea how to make the connection by register or by AC Adapter for the seccond coil ?? I will try to use an AC adapter for low voltage at the second coil. Etc 12 V for the first coil and 4-6 Volt for the second. So i think that the new high voltage on the spark being 14-16.000 Volt .
I want to make my R1100 gs to gives up 8.000 rpn. I make new camshaft and new pistons, compress ratio up to 12:1, free air and exchaust..
Now by my old setup, with ratio 11:1 and camshaft from r1100s, the engine gives until 7.500 rpn and i think the power could be continue up to 8.000 rpn. So i need more compres ratio, more fuel, dual pin plug sparks.
The dual sparks is this one (NGK BKR6EK) and work fine on R1100GS :
JohnGS1100 screwed with this post 03-02-2013 at 04:08 PM
Old 09-30-2014, 06:51 AM   #343
Dan Căta
Dan Căta's Avatar
Oddometer: 1,685
I am having some trouble tunning a 1150GSA, 2003, servo model.
No matter what I do, the spark plugs are white.
The bike came without a CCP. I installed a jumper wire like this - http://t2.gstatic.com/images?q=tbn:A...xre_JSm-KT2RwA
That did not change anything, as the spark plugs are still white.
The bike now feels a little like powerless. It pulls, but it does not feel as a regular 1150GSA.
I did run a diagnose on the GS911 and I can see that the graph for the O2 sensor looks normal, like /\/\/\/\/\/\/\/\/\//\/\/\. Perhaps it is a little lazy, meaning that it does not update as often as it should, but it stays in the green zone.
I have also changed the fuel filter. Sadly, I do not have tools to measure the gas pressure between the FPR and injectors. That is a nice to have tool and I plan to get it soon, but I do not have it now...
Any ideas on what is wrong ans the mixture is too lean?
The GS911 shows the Motronic version as 4.
Dan.
Dan Căta is offline   Reply With Quote
Old 10-01-2014, 12:50 AM   #344
Dan Căta
Dan Căta's Avatar
Oddometer: 1,685
What I did was to take the injectors and lambda probe for ultrasound cleaning. Also, I got myself an almost new cat, that I am going to replace.
I hope I can make the swap today and I will see how that goes...
Dan.
Old 10-01-2014, 02:48 AM   #345
Poolside
Syndicated
Poolside's Avatar
Oddometer: 11,887
Any ideas on what is wrong...?
I think you're using the wrong Cat Code Jumper (CCP) positions. The image you posted is one of the jumper positions used with an aftermarket EPROM.
Check out the factory CCP positions, and the Steptoe jumper. People use the Steptoe jumper positions of 30 and 87a for the R1150 with Motronic 2.4 ECU.
The factory Cat Code Plug jumper positions.
The jumper positions for an aftermarket Motronic EPROM chip. Possibly the BBPower chip.
The Steptoe jumper.
Poolside screwed with this post 10-01-2014 at 03:46 AM
Times are GMT -7.   It's 06:25 PM.
