Old 03-02-2013, 10:51 AM   #1
Veter OP
Motoviajero
Veter's Avatar
Location: On a relaxed LONG trip all over Latin America
Oddometer: 48
New day, new problem 12gs 2011
Here is what I have now - when with full tank only 1 cylinder is working, smells like gas, 'helicopterish' sound. Power and torque are volatile. When 3/4 of the tank starts to work OK. Any ideas?
Veter is offline   Reply With Quote
Old 03-02-2013, 10:57 AM   #2
stevie88
That's gotta hurt
stevie88's Avatar
Oddometer: 18,654
Sounds like your charcoal canister might be full of fuel or the tanks not venting properly. That's where i would first look.
Green Bay coach Mike McCarthy is a total fucking pussy.
stevie88 is offline   Reply With Quote
Old 03-02-2013, 12:29 PM   #3
Mudcat
Unregistered
Mudcat's Avatar
Oddometer: 4,472
That is what it sounds like to me too.
Veter, are you overfilling your fuel tank? You can’t do that. Don’t fill the fuel tank all the way to the top.
One solution would be to remove the canister, it’s easy, but I don’t have direction for your bike
I've got to be cool
Relax
Take a long long ride on my motor bike
Untill I'm ready
Mudcat screwed with this post 03-02-2013 at 01:27 PM
Mudcat is offline   Reply With Quote
Old 03-02-2013, 10:43 PM   #4
Veter OP
Motoviajero
Veter's Avatar
Oddometer: 48
Thanks guys, will try it tomorrow!
Old 03-03-2013, 06:31 AM   #5
ghostrider.y2k
ride enything but HD
ghostrider.y2k's Avatar
Oddometer: 876
Start the bike for about 45-60 sec, do not touch the throttle, shut it off and open the gas tank quick( second key helps).If there is vacuum in the tank evap solenoid is not working properly, take it to the dealer for repair under warranty.
It happen to my friend 2011 GS, dealer try to blame overfill but it was not the case.BTW you should not top off the tank.
y2k
MOTORCYCLES-->created to keep us from choking the idiots around us
"w strone slonca..........."
ghostrider.y2k is offline   Reply With Quote
Old 03-03-2013, 07:13 AM   #6
Veter OP
Motoviajero
Veter's Avatar
Oddometer: 48
yeah you are right, there is vacuum
Old 03-03-2013, 07:23 AM   #7
stevie88
That's gotta hurt
stevie88's Avatar
Oddometer: 18,654
You can perform a canisterectomy on it pretty easily and eliminate those type of problems.
Old 03-03-2013, 07:26 AM   #8
LaurelPerryOnLand
Oddometer: 3,478
100 THREADS all GS/GSA owners should read.
http://advrider.com/forums/showthread.php?t=836736
83. HOW DO I REMOVE THE CHARCOAL CANISTER FROM MY GSA?
http://advrider.com/forums/showthread.php?t=211357
LaurelPerryOnLand is offline   Reply With Quote
Old 03-03-2013, 08:03 AM   #9
ghostrider.y2k
Oddometer: 876
Take to the dealer, evap solenoid is not working as it should.
My friends bike did this and went to the dealer 3 or 4 times but the tech at the shop was a bonehead and try to blame overfill witch was not the case.
You flooding the left cyl and thru the evap system.
PM sent
Old 03-03-2013, 08:11 AM   #10
stevie88
That's gotta hurt
stevie88's Avatar
Oddometer: 18,654
PM sent
True, but my preference would be to remove it. I'd leave the solenoid plugged into the electrical system so it wouldn't throw codes but I'd directly vent the fuel tank and either plug the throttle body vacumn ports or connect them with a hose. Then you've eliminated one source of future problems and you can pound gas into your tank with no worries.
Old 03-03-2013, 08:39 AM   #11
Mudcat
Unregistered
Mudcat's Avatar
Oddometer: 4,472
True, but my preference would be to remove it. I'd leave the solenoid plugged into the electrical system.
OK, so, removeing the canister will make the issue moote?
If so, he could just disconnect the lines from the canister and plug the proper vacuum lines? That way he could hook the system back up when he was home if he wanted too.
I don’t believe he has ready access to a dealer for a solenoid.
I've got to be cool
Relax
Untill I'm ready
Old 03-03-2013, 08:44 AM   #12
Veter OP
Motoviajero
Veter's Avatar
Oddometer: 48
OK. So, I disconnected the tubes, isolated the vacuum one. Seems to work OK so far! Many thanks, guys!
Old 03-03-2013, 08:52 AM   #13
stevie88
That's gotta hurt
stevie88's Avatar
Oddometer: 18,654
Old 03-03-2013, 08:53 AM   #14
Veter OP
Motoviajero
Veter's Avatar
Oddometer: 48
Veter screwed with this post 03-03-2013 at 09:00 AM
Old 03-03-2013, 08:59 AM   #15
ragtoplvr
Oddometer: 6,055
when you can please try to get this fixed right. The bike does pollute more without the charcoal canister.
Rod
ragtoplvr is offline   Reply With Quote
Times are GMT -7.   It's 05:49 AM.
