Old 03-02-2013, 04:59 PM   #61
mcma111
mcma111's Avatar
Oddometer: 12,441
Piston envy. Now I've heard it all...
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 03-02-2013, 05:02 PM   #62
mcma111
mcma111's Avatar
Oddometer: 12,441
You want a piston? Here's a piston. 106mm bubba:
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 03-02-2013, 05:29 PM   #63
elsalvadorklr
southern xr rider
Oddometer: 4,154
not impressed unless its 200mm steve! geeze
elsalvadorklr is offline   Reply With Quote
Old 03-02-2013, 08:28 PM   #64
Huskylove
Oddometer: 54
That is one...big...member of aluminum there.
96 Xr600r, 644cc 10.5:1 Je, megacycle cam/rockers, fcr41 sudco, custom exhaust and a set of 17's <motor and frame for sale PM me
Huskylove is offline   Reply With Quote
Old 03-03-2013, 08:46 AM   #65
brucifer OP
brucifer's Avatar
Oddometer: 2,496
Piston and cylinder installed.
Sorry for the slight fuzziness in the last two pics. I have to learn to keep more steady when shooting.
2014.5 Kawasaki KLR650 NE-2006 Buell XB12SS-2002 Husky TE570-2001 Yamaha WR250F-1993 Kawasaki KX500-1984 Honda XL600R/XR650L Hybrid-1984 Yamaha TT600L-1980 Honda CB750F
brucifer is offline   Reply With Quote
Old 03-03-2013, 09:10 AM   #66
mcma111
mcma111's Avatar
Oddometer: 12,441
So what? Another six months for the head to show up?
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 03-03-2013, 09:41 AM   #67
brucifer OP
brucifer's Avatar
Oddometer: 2,496
Lol. Well, the head has been quite the ordeal. He fixed a broken fin, is porting it, bought oversize valves but the distance from the keeper groove to the end where the tappet taps is way shorter than stock. He said we should be able to take that up with the screw adjuster. However (and I didn't even think about this until this morning ) with the RFVC sub rockers, that isn't possible. I know he knows that too--he just forgot. Lash caps maybe? The valve stem sits pretty far down in the aftermarket spring retainer.
Old 03-03-2013, 10:33 AM   #68
elsalvadorklr
southern xr rider
Oddometer: 4,154
aaaaay
wish you luck bud, looks great so far
ps. doesnyt cyclewizard make estra tall cooling caps that allow for more movement of the screw locknuts on the rockers? or is it still a no go?
Old 03-03-2013, 11:38 AM   #69
brucifer OP
brucifer's Avatar
Oddometer: 2,496
Still a no go Christian. I need the extra length where the sub rocker contacts the valve, not where the screw adjuster is.
Old 03-03-2013, 12:03 PM   #70
elsalvadorklr
southern xr rider
Oddometer: 4,154
aaaah gotcha
bummer
Old 10-12-2013, 06:30 PM   #71
brucifer OP
brucifer's Avatar
Oddometer: 2,496
Nope.....SEVEN! FINALLY! Ported, polished, big valves, new guides, fins repaired.
Old 10-13-2013, 11:38 AM   #72
brucifer OP
brucifer's Avatar
Oddometer: 2,496
Was going to begin assembly this morning and realized both of the new head gaskets I had were for an XL600, so the bolt and dowel holes were too small.
Here's a few pics anyway. Tried to shoot some of the port work but just doesn't show up.
Old 10-20-2013, 05:32 PM   #73
brucifer OP
brucifer's Avatar
Oddometer: 2,496
The top end is back together! Got oil coming out of the top banjo bolt. Did the air pressure deal then hand-kicked it over without the plug in (obviously ). Spent the afternoon chasing a no-spark issue--turns out it was the stator. Funny, as it ran fine prior to tear down. I guess electrical components can go bad just sitting. Stuck an XL600 stator in I had laying around and that cured it.
Getting closer.
Old 10-21-2013, 12:30 PM   #74
mcma111
mcma111's Avatar
Oddometer: 12,441
The odds of that XL stator lasting are pretty slim. Better plan on getting a Rickey. BTDT...
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 10-21-2013, 07:02 PM   #75
brucifer OP
brucifer's Avatar
Oddometer: 2,496
If it lasts long enough to break the cam in I'll be happy. A Ricky's definitely in the plan--just gonna have to wait a bit.
Times are GMT -7.   It's 02:13 PM.
