Old 12-05-2005, 11:01 AM   #1
AllEuro OP
Sausage Creature calling
AllEuro's Avatar
Oddometer: 67
Question LC4 Charging problems
I'm working on a 00 LC4 enduro and it is failing to charge the battery and has a slight voltage drain with the key off and a meter hooked between the ground and - terminal of the battery. It will run if kicked over but the voltage on the battery is around 10.5 volts while running 12+ if turned off and battery is charged. Ideas? or does anyone have emailable service manual info that I could test out the various components to sort out the culprit.
Cheers,
Mr. B
AllEuro is offline   Reply With Quote
Times are GMT -7.   It's 12:00 PM.
