Go Back   ADVrider > Riding > Regional forums > New Zealand
Old 01-07-2012, 11:24 PM   #16
kiwipeet OP
Uber Cyber Loafer
kiwipeet's Avatar
Oddometer: 3,010
Originally Posted by Lovin' it Strom View Post
I know I'm asking a broad question, what kind of weather - generally- can we expect in March? Cold, wet, dry, clear, rainy?
I had a quick google and found this: http://www.tourism.net.nz/new-zealan....html#regional which contains average temps and rainfalls by season for each region.
Lonely planet has a little info as well: http://www.lonelyplanet.com/new-zealand/weather
Our national weather bureau can be found here: http://www.metservice.com/national/index
NZ has some wild and varied terrain and we also have weather to match. Weather here changes quickly. If you really want to know why, read this.
For biking, the vast majority or NZ is rideable all year round. The most southern parts of the South Island may be under snow for a few months during the peak of winter, but main roads are regularly serviced and seldom closed for long. However, high passes can close quickly and with little notice.
Our best advice is carry gear for all conditions. Removable layers are a very good idea.
However, one advantage of our terrain and being a small country is that in many cases you can ride around or out of the weather within a few hours. If you keep your plans flexible and keep an eye on the weather forecast you can stay dry while it's raining only an hour away.
kiwipeet screwed with this post 02-19-2012 at 05:43 PM
kiwipeet is online now   Reply With Quote
Old 02-18-2012, 04:39 PM   #17
Lovin' it Strom
Now low fat!
Lovin' it Strom's Avatar
Oddometer: 2,817
Surface Water Quality
A buddy of mine, during his research found there was some warning of virus issues in the water?
I will be there traveling with a Katadyn Hiker PRO water filter, however it has limited virus filtration. We plan on topping off the Camelback at stops along rivers and at campgrounds.
Is there a viral issue in the rivers/streams we may be filling our Camelback with, or will we be OK with a standard filter?
When we leave a place a part of it goes with us and a part of us remains
Lovin' it Strom is offline   Reply With Quote
Old 02-18-2012, 05:15 PM   #18
Box'a'bits
In need of repair
Box'a'bits's Avatar
Oddometer: 2,182
The major issue is Giardia. Dependent upon your filtration system you should be fine. Otherwise fill your Camelbaks at fuel fill time (most have outside taps somewhere) & at cafes etc.
My '91 R100GS thread is here
My Ride photos are here
Box'a'bits is offline   Reply With Quote
Old 02-26-2012, 01:33 AM   #19
Dino3310
Oddometer: 673
watch out for algae bloom in some of the lakes in summer, i know some of the smaller lakes around the waikato get it from time to time, there are public warning signs. But i wouldnt think you would need the water out of the lakes up here as communities arent that far apart. ie: pubs
you can pick up filterd straws for Giardia, most hunting stores have the filters and info, but like Box'a'bits said top up at fueling points and ya should be right.
Dino3310 is offline   Reply With Quote
Old 05-23-2012, 11:58 PM   #20
Crazykiwi
Crazykiwi's Avatar
Oddometer: 10
Wicked
Has anyone shipped a bike from the UK, just thinking about a low Km Africa Twin, wanting to know what total cost break down would be??
Or is this just not worth my time and money??.
Is there anywere else that is worth importing from? Japan?????
Bikes don't leak oil, they mark their territory
Crazykiwi is offline   Reply With Quote
Old 06-14-2012, 03:16 AM   #21
kiwipeet OP
Uber Cyber Loafer
kiwipeet's Avatar
Oddometer: 3,010
Hi. It's been discussed a few times in the NZ forum. You'll find many of the basics in this thread here: http://advrider.com/forums/showthread.php?t=702718
Costs vary depending on several factors. (explained in the thread above). Whether it's worth it or not is a personal choice. The short answer is if the bike is rare or desireable, has sentimental value to you or you're just busting your nuts to have one, then maybe yes.
If you could reasonably buy one here... then probably not.
If it's purely a money thing I would say youd have to be able to buy it overseas for $3-5k cheaper than you can here just to break even, let alone make it worth while. If you're doing it to make money then it'll need to $4-6k cheaper to make it viable.
kiwipeet screwed with this post 06-14-2012 at 03:33 AM
Old 03-04-2013, 11:54 AM   #22
BOOTLACE
Bikie Scum.
BOOTLACE's Avatar
Oddometer: 3,884
http://aussiebikeshipping.com.au/
bootlace
BOOTLACE is offline   Reply With Quote
Old 05-22-2013, 02:39 AM   #23
Three Dawg
Three Dawg's Avatar
Oddometer: 503
I'll be over in NZ early next year (been there several times before, but only once on a bike) and this time I'm getting a Super Tenere to do some gravel riding. All good info here, but given that I'll be 2 up on a big bike, what would a 'gnarly' road/track be defined as?
Three Dawg is offline   Reply With Quote
Old 05-22-2013, 05:01 PM   #24
clintnz
Trans-Global Chook Chaser
clintnz's Avatar
Oddometer: 3,420
One that you shouldn't do 2-up on a big bike
Unless you are Chris Birch
Cheers
Clint
'03 KTM 640 LC4 Enduro
The wilderness, the desert - why are they not crowded
.................................................. .....with pilgrims?
clintnz is offline   Reply With Quote
Old 05-23-2013, 05:35 AM   #25
Three Dawg
Three Dawg's Avatar
Oddometer: 503
Ha ha, yeah OK, stupid question. Although it isn't the gnarlyness I'm bothered about so much as the potential damage to someone else's bike. And my wallet.
Three Dawg screwed with this post 05-23-2013 at 11:53 AM
Old 09-16-2013, 07:56 PM   #26
philth
philth
philth's Avatar
Oddometer: 6,146
gday legends
i just ordered the hema new zealand motorcycle atlas and mark wilsons 4wd north island but the south island one seems to be out of print? can anyone recommend a south island 4wd map book?
i must not post hairy buttocks
philth is offline   Reply With Quote
Old 09-17-2013, 12:34 AM   #27
NZDave
Oddometer: 24
I used to have this one http://www.mightyape.co.nz/product/B...rails/2975049/
From memory it wasnt as comprehensive as Mark Wilsons books though.
NZDave is offline   Reply With Quote
Old 09-17-2013, 01:08 AM   #28
ztaj
jatz
ztaj's Avatar
Oddometer: 933
Grab yourself a KiwiMaps South island drivers atlas. It has lots of the same tracks as the 4wd book marked. It's also more comprehensive than the Hema maps.
If you "must" have the proper book, I can loan you my copy
ztaj is offline   Reply With Quote
Old 09-17-2013, 01:28 AM   #29
nz gravel man
ADVENTURE RIDER
nz gravel man's Avatar
Oddometer: 20
G' Day Philth.
Check out www.adventureguide.co.nz it may help with some ideas.
I have volume1 & volume2 of Ken Sibley & Mark Wilson's South Island 4x4
books.
I have just been talking to Westy & he will flick you an email.
Some dvd's of NZ with your humour would be a good watch.
Cheers G.M.
nz gravel man is offline   Reply With Quote
Old 09-17-2013, 04:00 AM   #30
philth
philth
philth's Avatar
Oddometer: 6,146
thanks legends!
i do like paper maps!
Times are GMT -7.   It's 03:40 PM.
