03-03-2013, 06:58 PM
#1 |
Dubbious Adventurer
Oddometer: 4,697
Shorten WP43 Fork for the R80 Project
My R80G/S project has finally kicked into high gear with arrival of a brand new YSS shock from Klaus at EPM Performance.
![]() I thought I post a quick how it's done for the fork shortening. I wanted to wait unitl the shock arrived, and then take some educated guesses as to leveling the front. I had the new shock set up at a length of 375mm. This is as far as I dare take the mono swing arm. As I recall (say what), the oem shock is 360mm long. (No, not as I recall, as Wrangler aptly states below) Up front, I'm going to look for about 210mm of fork travel. To do that, I need to shorten the WP with a 65mm spacer. We'll see how it all works. If it's wrong, I'll do it again. Here are the forks taking shape inside a shiny pair of R-dubb triple clamps: ![]() ![]() Not a lot of photos, but here's the step by step of getting to that spot right above the top out spring where the 65mm spacer goes. As some of you may know, getting to the spot requires taking the fork legs completely apart including the cartridge.
Just in case you don't know how to put it all back, I'm not tellin'. ![]()
MINIMOUNT R-dubb screwed with this post 03-03-2013 at 09:29 PM |
03-03-2013, 07:06 PM
#2 | |
More tacos than you
Oddometer: 5,197
![]() Stock shock length of a G/S is ~360mm. You're not talking stroke length either cuz that'd be way too long. Which measurement are you talking about here?
R80ST Gets The HPN Treatment Ducati Pantah 500SL Rebuild Seattle to TDF on an airhead WTB R100R Mystic sidestand and mount. |
03-03-2013, 07:16 PM
#3 | |
Dubbious Adventurer
Oddometer: 4,697
MINIMOUNT |
03-03-2013, 10:01 PM
#4 |
More tacos than you
Oddometer: 5,197
I'm curious about the choice of forks. Why the 4354s? I know zero about them, but the pieces look pretty much the same as the 4860s just a little skinnier. Do they somehow manage to avoid the stiction issues that the 4860s have?
03-03-2013, 10:29 PM
#5 |
Dubbious Adventurer
Oddometer: 4,697
Has everything to do with the clamps. I made clamps for the 43's whenever that was because they were cheap and plentiful at the time. 48's weigh more and use to cost more used and were scarce due to being newer. I still feel 48's are overkill for our rubber-ish frames.
43's, they still stick, but maybe a tad less. Same design as 48's. I think they stick more with shallow rake (like airheads). Oh well. Could have used the Extremes. They are buttery smooth, but way heavy. One way to minimize stiction might be less preload and minimal compression damping. I'll let you know how it goes when this thing hits the road in a month or so.
MINIMOUNT |
03-03-2013, 11:41 PM
#6 |
Oddometer: 1,215
I had shortened 43s on my GS and thought they were pretty good. You may find them better shortened as they have more overlap so should stick less.
03-04-2013, 06:06 AM
#7 |
More tacos than you
Oddometer: 5,197
Prutser said that additional overlap after shortening helped quite a bit on his 48s.
03-04-2013, 08:14 AM
#8 | |
airhead or nothing
Oddometer: 7,976
Good to see you around here again R-Dubb!
Can you post a few more pix of your headlight bucket support and how it mounts to your triples please?
"punkrocks what it's all about" - J. Strummer Quote:
03-04-2013, 11:13 AM
#9 |
Location: Moving further away from Wellington, New Zealand
Oddometer: 1,096
Yes please!
Operation: Battle Panda |
03-04-2013, 02:10 PM
#10 | |
Desert Lion
Oddometer: 290
I have them on my '11 EXC and never felt any issues |
03-04-2013, 02:14 PM
#11 |
More tacos than you
Oddometer: 5,197
Mine are particularly bad, but that's just because I bought them used on ebay and put them straight on my bike without even changing the oil. They cleaerly are in need of a full rebuild. That said, the other 4860s I've seen have more stiction than conventional forks, but I don't really notice much when riding them. The improvement in stiffness and overall function is so much better (on forks in good condition) that I don't really care about a bit of stiction when fully extended.
03-04-2013, 02:24 PM
#12 | |
Desert Lion
Oddometer: 290
03-04-2013, 02:32 PM
#13 |
More tacos than you
Oddometer: 5,197
Depends which ones you're talking about. The layout, USD or conventional, has a lot less bearing on performance than the internals, though typically USD forks are less flexy and have lower unsprung weight than comparable conventionals. Modern conventionals with adjustable compression and rebound damping and a tunable shim stack (aka open cartridge forks) are every bit as good performance-wise, but most conventional dirt bike forks are so-called damping rod (more accurately "fixed orifice") forks. They are comparatively primitive and their performance isn't nearly as good. Think KLR650 vs. 690 Enduro.
03-04-2013, 02:47 PM
#14 | |
Desert Lion
Oddometer: 290
Optically you would think there is a bunch of difference, is this the case? How much can that difference be felt in practice? |
03-04-2013, 02:52 PM
#15 |
More tacos than you
Oddometer: 5,197
[QUOTE=Ras Thurlo;20864472]so assuming we are using good conventionals, the argument come down to relative unsprung weight
Unsprung weight and stiffness. USD forks are just a "better" design when you consider the forces acting on the forks. Well yeah. Definitely. Some people think airheads are supposed to have conventionals. I agree that they look better on an older bike, but I'd rather put performance and parts availability ahead of aesthetics. Shiny part up or shiny part down? That's the question.
R80ST Gets The HPN Treatment Ducati Pantah 500SL Rebuild Seattle to TDF on an airhead WTB R100R Mystic sidestand and mount. Airhead Wrangler screwed with this post 03-04-2013 at 02:59 PM |
