Old 03-03-2013, 09:39 AM   #1
bgoodsoil OP
Dare to be Stupid
bgoodsoil's Avatar
Oddometer: 4,605
Keihin 35mm Air Striker Carb Jetting
Anybody put these on an airhead that could give me some jetting advice? I'm running cylinders, pistons and heads from a '92 r100gs and a 38mm exhaust. I got this set off a 2000 something Yamaha Banshee. Getting carbs from a 2-stroke 4-wheeler to work on the G/S might be a challenge.
The carbs are coming with the original cables and the thumb throttle. I'm going to try to rig it and at least take a trip around the block with the thumb throttle
tags: Keihin PWK A/S flat slide mikuni tm tmx vm round slide
'85 BMW r80G/S--Another G/S on the road--Central America on a Shoestring--Nova Scotia on a Shoestring--Never Leave a Man's Behind
Proud SmugMug User Support ADV: Don't give those cheap bums your discount code
bgoodsoil is offline   Reply With Quote
Old 03-04-2013, 04:19 PM   #2
bgoodsoil OP
Dare to be Stupid
bgoodsoil's Avatar
Oddometer: 4,605
Oh come on. I can't be the first person to pull carbs off a 4-wheeler and try to make 'em work on a G/S. Maybe I should've pulled some off a tractor
Old 03-04-2013, 09:21 PM   #3
bgoodsoil OP
Dare to be Stupid
bgoodsoil's Avatar
Oddometer: 4,605
My solution to most airhead upgrades, 'wait until AW figures it out', didn't work this time. Damnit, now I have to do it the hard way! Well, at least the forks'll be easy.
Old 03-04-2013, 09:39 PM   #4
Kt-88
I like everything.
Kt-88's Avatar
Oddometer: 886
It says race use only. That kinda guarantees fun.
Kt-88 is online now   Reply With Quote
Old 03-04-2013, 09:43 PM   #5
bgoodsoil OP
Dare to be Stupid
bgoodsoil's Avatar
Oddometer: 4,605
Yeah but I found that pic on a Vespa website. That might be some hipster swag. They may also sell pants that are really skinny and 2 inches too short to save weight for "racing".
Old 03-04-2013, 10:23 PM   #6
Kt-88
I like everything.
Kt-88's Avatar
Oddometer: 886
When I get dedicated enough to going fast to ride a racing Vespa, I will have lost anything those pants were trying to constrict anyway.
Jk. I'd totally race a Vespa. I'm easy.
Old 03-05-2013, 06:28 AM   #7
oldroadie
Two wheel addict
Oddometer: 467
Whatcha gonna use for an intake and filter? K&N pods on a Keihin 34mm CV for a similar displacement Triumph engine usually start at 145 mains and 48 pilots. I know some with unrestricted exhausts that are running 155 mains for that setup, too. That flat slide won't be the same as a butterfly throttle but it should be close enough to get you started.
oldroadie is offline   Reply With Quote
Old 03-05-2013, 06:58 AM   #8
bgoodsoil OP
Dare to be Stupid
bgoodsoil's Avatar
Oddometer: 4,605
I'm going to try to use the stock airbox to start. I might play with pulling the snorkels off and running the filter open to see how it affects flow. I can't do that until I get it to run though.
Thanks for the numbers. As far as I know it's coming with 48 slow jets and 160 mains. I've got a ColorTune and I'm hoping to use that to set...well everything. If I start with a 48 idle, and the spark is orange, even with the mixture all the way in, I'll go down a jet. And so on.
That's the plan anyways. I'm still waiting to talk to Jenna to hear what she has to say about it.
Old 03-05-2013, 07:36 AM   #9
Airhead Wrangler
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,548
Sorry, boss. You're on your own on this one.
Air striker. Ha. Awesome name. I vote that you leave the "racing use only" stickers on there. Not quite as cool as the "not for aircraft use" stickers that come on mikunis though.
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Airhead Wrangler is online now   Reply With Quote
Old 03-05-2013, 07:44 AM   #10
hardwaregrrl
ignore list
hardwaregrrl's Avatar
Oddometer: 7,527
So first lets start with what can be changed. Can you change the needle jet, jet needle, slide angle? I ended up shooting into a barrel with my needle jet size and just got incredibly lucky. Msp has a dyno and only charges 50-75$ for a run but their probe won't fit in out stock muffler so lets get the busa in there. Can you get a chart to show sizes for different machines these will work on?
Old 03-05-2013, 08:15 AM   #11
bgoodsoil OP
Dare to be Stupid
bgoodsoil's Avatar
Oddometer: 4,605
Yep, it's got different slides, different needles, different needle heights, the whole 9 yards. I haven't bought any jets yet because I don't have the slightest clue even what range I'd be in. I'm not sure of the jetting that will come from the Banshee.
They're all on 2-stroke dirtbikes. I haven't found any specs from people putting these on 4-strokes. Hopefully I didn't screw up buying them. I read a lot of people switching from the Mikunis to the Keihins on thumpertalk because they're easier to jet. Nobody said it performs any better, just simpler to tune. That's what caused me to take the risk and get these carbs. This is the website that sold me on the air strikers:
http://motocrosshideout.com/cr250cr1...w-out-the-tmx/
I've got a good guide on the carbs but I still expect this to be a long process. Really wish these had that quick release float bowl. I'm going to have to pull those bowls a thousand times.
bgoodsoil screwed with this post 03-05-2013 at 08:21 AM
Old 03-05-2013, 08:28 AM   #12
One Less Harley
OH.THAT'S GONNA HURT
One Less Harley's Avatar
Oddometer: 4,744
Brad, you gonna have to get your air filter set up first as this will affect everything you do on the carb. No point jetting the carb 1st then figuring out the air filter arrangement. No point putting the cart before the horse if you do you'll wind up in the sand.......LIKE JENNA...
My DRZ doesn't run worth a shit with out the air filter. I tore it once when cleaning and who would have thought a needle and thread would be needed in a tool kit!!!!
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
Old 03-05-2013, 08:46 AM   #13
bgoodsoil OP
Dare to be Stupid
bgoodsoil's Avatar
Oddometer: 4,605
Oh I'm not going to run without an air filter. I'd like to try it without the snorkel some time but I'm not taking off the filter. If I drop the snorkel I'll throw an oil-soaked green pad over the top of the filter. I think some bungee cords ought to hold it down.
I'm fully expecting to do a 'Fred Special' and hose clamp a split inner-tube around the intake boots.
Old 03-05-2013, 08:52 AM   #14
oldroadie
Two wheel addict
Oddometer: 467
Might as well head down to True Value now a get those Allen head replacement bolts. Sure beats stripping one of those dodgy Phillips heads.
Old 03-05-2013, 09:12 AM   #15
hardwaregrrl
ignore list
Oddometer: 7,527
+1 However, if you're worried about changing the main over and over, there is a plug on the bottom that allows for access to the main. Mine is a 17mm
There must be a compairison somewhere between Mik and Kehin jets so we can at least get you in the ball park.
Times are GMT -7.   It's 10:55 PM.
