Old 03-04-2013, 11:19 AM   #1
AutoXfreak OP
AutoXfreak's Avatar
Oddometer: 120
Tall Guy Looking to raise the Bars
Hey all,
I have an 06 950, love the bike. However like all other bikes (offroad) I need to raise the bars so I can stand comfortably. (I'm 6'5") I have used the simple rising blocks in the past. However I have seen the "Rox" brand risers and thinking it would be nice to have the ability to move the bars fore/aft to my comfort level. Also how much rise will the stock cables allow? I am thinking atleast 2" rise and keeping the stock bars. I also hear the Protaper or Renthal Pastrana bars help for taller folks as well.
Thaks all for your advise/help.
-Brad
950 Adventure
AutoXfreak is offline   Reply With Quote
Old 03-04-2013, 12:52 PM   #2
Hipster
Hipster's Avatar
Oddometer: 1,812
See this thread http://www.advrider.com/forums/showthread.php?t=867394
2008 KTM 990 Adv & 2007 KTM 640 Adv
Hipster is offline   Reply With Quote
Old 03-04-2013, 03:06 PM   #3
georgedaman
Oddometer: 123
I'm 6'5'' myself and I'm using this..
http://www.advrider.com/forums/showt...ghlight=risers
It raises and tilts forward.
Best mod ever for someone tall like us.
georgedaman is offline   Reply With Quote
Old 03-04-2013, 03:18 PM   #4
Kyler
Confused Hack Nut
Kyler's Avatar
Oddometer: 2,620
I have a Scotts underbar damper with the Scotts triple (which is taller) and then the Rox risers. That is about as high as it will go without completely rerouting the hoses.
I'm 6'5" and it is now perfect for me.
Ken => I'm a DAMN Rider (No rules, just ride!)
Happiness is a 3-wheel drift!
Member of the Maryland OHV Alliance
2014 Yamaha FZ-09 Adventure
Kyler is offline   Reply With Quote
Old 03-04-2013, 05:33 PM   #5
biggus
biggus's Avatar
Oddometer: 378
I have an 06 950s with the BRP Upper Triple, Scott's Damper, 2" Rox Risers and RC High Bend Bars with HDB Hand Guards.
biggus is offline   Reply With Quote
Old 03-05-2013, 02:43 AM   #6
AUT-EasyRider
AUT-EasyRider's Avatar
Oddometer: 127
I use this one (5cm): http://sigutech.com/index.php?option...6&lang=english
Did not change the wiring and the cables, works fine
In combination with the 3cm lower pegs it is ideal for me, I am 201cm tall
http://www.motobau.de/shop/product_i...asten-lc8.html
The site is only iun german, write Kai a Email, he will answer: info@motobau.de
We blew it
AUT-EasyRider is offline   Reply With Quote
Old 03-05-2013, 10:23 AM   #7
ABuck99
0.0
ABuck99's Avatar
Oddometer: 606
How much do you want to spend....? You can squeeze about 2" of height out of the existing cables. More than that means spending more $$ to extend things.
With out replacing handle bars or cables, for under $100 bucks you can get the 1.75" or 2" ROX risers, that allow you to pivot the mounts & bars to suit your specific riding preference. Ive got the 1.75 " & RC High set up. I like these better than some of the other options only because of the wider range of adjustment. Your only limitation to more height are the stock cable lengths. After moving the controls inward and downward a little, the front brake & clutch lines are maxed using the ROX 2" & that is using Pastrana or RC High. The 1.75" leaves a little extra length but the lines are tight on the fittings when the suspension is fully unloaded, Im not sure how these will hold up over the long haul. Throttle cables will likely need to be rerouted through to pass through the right side of the steering head, this allows you to keep the throttle cables in the standard upright position.
I want longer cables all around so I'm currently working on an extended brake line & clutch line & throttle cable kit for the 950/990. I'll keep you guys posted on how that comes out.
KTM: 06 KTM950S & 10 KTM450EXC
ABuck99 is offline   Reply With Quote
Old 03-05-2013, 11:28 AM   #8
rattis
rattis's Avatar
Oddometer: 1,199
Question Bmw?
I bought some Roz risers for my Blue & White marvel that I never got around to fit will they fit my 990 ADV?
I wish I had bought a GSA a long time ago
and now I drink Orange Crush as well, thrice up now, two 990 Adv and a 950 SER
rattis is offline   Reply With Quote
Old 03-05-2013, 02:43 PM   #9
AutoXfreak OP
AutoXfreak's Avatar
Oddometer: 120
Thanks for the input. I was thinking about going with the 3.5" risers, however it sounds like most of you are happy with the 2" units. I would like to someday go for the Long travel "s" suspension so it might be wise to start looking for the longer brake lines. Has anyone done the 3.5"? It really sounds like I will need to change/re-route cables if I decide to go that route...
Thanks for your suggestions. Cant wait to ride a machine that fits...
950 Adventure
Times are GMT -7.   It's 11:35 PM.
