03-29-2010, 09:50 AM
#1 |
In a state of equilibrium
Location: North Dallas 'burb in a box made of ticky tacky.
Oddometer: 2,905
SW-Motech Trip Tankbag - mini review and questions
I just installed the Bags Connection Trip tankbag for the SW-Motech gascap conection. I got the bag from Wunderlich at the last Int'l Motorcycle Show, but its the same as the one sold by twistedthrottle.com.
Installation is no big deal once you can see what to do. The German/English instructions do leave a bit to be desired. I made use of a tutorial in PDF the link for which is on twistedthrottle. One problem was the drill bit. While SW Motech used to send the correct sized drill bit (5.5mm, in this case), they don't anymore. Not to worry, as a trusty 7/32" drill bit works just fine (5.5mm=0.2165", and 7/32"=0.2188"). The screw is 5mm (or 0.1969"), and the washer is 5.3mm (or 0.2087"), so what you need is a drill bit that'll let the screw through, but not swallow the washer, and 7/32 is just 3/1000 bigger than 5.5mm, so it worked like a charm. One of the cool things about the product is that you can decide how close or far you want it from you. I have mine so that its as far back, or close to me, as possible. I marked my spots to drill by putting a thin nail in each hole of the attachment piece and whacking it with a small hammer to leave enough indentation so I could see it. The directions say to put a piece of wood in the bag as you drill, but a power drill goes through the plastic so quickly that its not necessary. After the holes are drilled it installs easily. The fit and finish are very clean. At 3.5 ltrs its small (it'll expand to 6 ltrs), but I think I'll like it as I prefer a smaller tankbag. Nothing fancy inside: no pockets or dividers, etc... If I want a larger tank bag for whatever reason, any of the SW Motech bags will fit on the gas cap connector. And, true to the term "Quick-Lock", it snaps on and off with ease. Nothing touches the bike, and unlike the Marsee Corona there's no magnets flying around everytime its removed. It ought to be a good product. Here's a pic that I stole from another website: ![]() See that rectangular "window" in the top of the case? Its for a cell phone so you can look down and "see who is calling." IMHO is a ridiculous idea as my cell phone will be in my pocket so if I'm thrown from the bike I can get to it. In any event, the window doesn't otherwise detract from what seems to be a well made product. Here're my questions for those of you who know more about this product than I do:
'05 R1200GS The following statement is true. The above statement is false. |
03-29-2010, 10:38 AM
#2 |
WeeBeastie
Oddometer: 18,213
The map holder, has two clips for the forward facing mount points and a small velcro tab for the back.
It holds on very well and on my daytripper it holds maps, phone and a few other goodies. Nice zipper and zipper tab to use even with gloves on.
⊕R1200GS⊕ ⊕Zuma 125⊕ Save $5 on Smugmug "so9RUAXlMm0bE" |
03-06-2013, 01:17 PM
#3 |
I just got this bag and like it a lot. its the right size for me and my bike.
But I noticed it does not have a pass through to run a charger cable to the inside of it. All other Motech bags have this feature. What up with that? |
