Old 03-06-2013, 07:54 PM   #1
Mr_Snips OP
Husky BRAAAAAAAAP!
Mr_Snips's Avatar
Oddometer: 352
Oil leak...help
Alright i recently picked this bike up its a 2011 ktm 990 adv r. It has about 12400 miles on it. It looks like there is a small leak just behind the countershaft sprocket. is this common and how hard will it be to fix? i havent pulled anything off the bike yet it just is where it looks like its coming from.
Originally Posted by Reprobate
Familiar. My stock response: "Most people die in bed. So, where do you sleep?"
Mr_Snips is offline   Reply With Quote
Old 03-06-2013, 08:10 PM   #2
Off Road Ryder
Off Road Ryder's Avatar
Oddometer: 2,738
It could be the countershaft seal. Not to big of a job, However before you tear into it check the shifter position switch, Its under the CS and is held on by two bolts and uses an Oring. I recently thought for sure my CS seal was gone, then after I pulled the sprocket off that area was dry as a bone. Turned out to be the O ring mentioned. Good luck
When Quality matters,Its all about choices.
Cyclops Performance LED Vendors thread
http://advrider.com/forums/showthread.php?t=839163
www.cyclopsadventuresports.com
1-800-624-0278
Off Road Ryder is offline   Reply With Quote
Old 03-06-2013, 08:23 PM   #3
Mr_Snips OP
Husky BRAAAAAAAAP!
Mr_Snips's Avatar
Oddometer: 352
awesome...probably wont get a chance until next week to check it unfortunately but its a very minor leak...maybe 4-5 drops over a 24 hour period. i assume its safe to ride as long as i keep close track of the oil level?
Old 03-06-2013, 08:29 PM   #4
slackmeyer
Don't mean sheeit. .
slackmeyer's Avatar
Oddometer: 3,147
Should be fine. Likely the neutral/gear position switch, like Cyclops says. . . this came up a half dozen pages ago on the "what did you do to your ktm today" thread, I think the o-ring size should be there, there's one in the harbor freight metric o-ring set that works, or you can order/buy the correct size one from someplace like Mcmaster-carr.
Zak
ktm
old bmw
others
slackmeyer is offline   Reply With Quote
Old 03-06-2013, 08:33 PM   #5
Qwik
Adrenaline Addict
Oddometer: 6,904
Its an easy fix. Takesabout twenty minutes
Topes never seem to make me go any faster.
Qwik is offline   Reply With Quote
Times are GMT -7.   It's 05:31 PM.
