03-05-2013, 12:46 PM
#1 |
Ontario Vstrommer
Oddometer: 146
Loading with a sling and crane
I'm returning to Newfoundland this summer for an extended tour. Lots of remote places and islands to visit but some of the ships are not regular roll-on roll-off ferry boats. Between Burgeo and Hermitage I'll need to have my Vstrom Dl 1000 lifted aboard by the ship crane used for regular cargo. The thick bulky webbing slings and massive hooks normally used by cranes just don't fit loaded bikes. There are not many places to attach and way too many plastic parts, side cases and controls to be damaged.
I'm thinking that some spliced Amsteel Dyneema lines, with over 5,000 pound strength, made into loops might work. I'm able to use 2 points of frame under the seat and the top of the steering head to provide 3 lift points. I know nothing about safety standards or certifications for crane operators. Any suggestions ? |
03-05-2013, 12:51 PM
#2 |
Oddometer: 744
sling through the front wheel, under the bars.
sling through the rear wheel. have a great trip
Crazy_Dave just made it into my sigline, and I agree: I fall down alot. |
03-05-2013, 07:02 PM
#3 |
Whatever...
Oddometer: 2,462
03-08-2013, 05:09 PM
#4 |
Oddometer: 1,485
03-10-2013, 05:25 PM
#5 |
Location: The far east of the far east of North America
Oddometer: 425
I have lifted the bikes (K75s and ZR7s) on in Rose Blanche and taken them off in Burgeo. I have lifted them on in Bay L'Argent and taken them off in Pooles Cove.
Both times they had to be tied to the foredeck and the salt spray will cover them. Both times the operator put the sling through the rear wheel and from the handlebars. I used a towel to keep the webbing from tearing up the paint on the side panels above the rear wheel. These guys are experts but it is use at your own risk. As for your proposed route do you know that the boat from Burgeo is not the boat that will take you to Hemitage? You will have to offload in Francois i believe and wait for the next boat coming from Hermitage. If i recall correctly this only happens once a week which is why i have not done this stage. An overnight is required. Good luck and be prepared for a culture shock.
R1150 GSA, KLR650, K75s(x3), RD350, PS250 (Big Ruckus) R65 If i was rich i would be an eccentric...but alas i am poor so i am just weird.
03-11-2013, 02:29 PM
#6 |
Ontario Vstrommer
Oddometer: 146
sling thru the wheels
Thanks damurph. Yes I know that an overnight is required.
My concern is that the sideways forces and webbing through the wheels will squish and wreck parts of my Vstrom. Side cases, plastic side panels etc and some controls on the handle bars. So ... that's why my idea of splicing some loops of Amsteel and lifting from the frame under the seat and I'm not yet sure of the front of the bike. But I'm wondering if the crane operator will just scoff at my loops and refuse to lift me. I've emailed the ferry service but their reply is inconclusive. I've not been able to get a definitive answer if the slings must go through the wheels. |
03-11-2013, 02:47 PM
#7 |
Oddometer: 425
You have to understand that everything that comes or goes from these communities does so at his hands. Fridges, stoves, fuel, quads and he has every variety of strap and rope. Take your luggage off the bike to reduce weight and carry it aboard. This will put less stress against the shiney bits.
Once i was late and had to ride the K75s up the gangplank after the crew took out the staunchions. Nothing but air and salt water on either side. When she hit the wet painted steel deck all the crew just grabbed on as she bounced. All part of the adventure.
03-11-2013, 07:47 PM
#8 |
My VStrom 650 was winched aboard a boat in Panama thusly:
- rope around steering head. - one rope each attached to each attached to the grab rails on the factory luggage carrier. The whole securing and lifting operation looked precarious but it went fine and didn't cause any damage to the plastics, however I did remove the windscreen and side cases beforehand. Here's the bike just after being winched off the boat. Note the attachment points ![]() I'm not sure how much heavier the 1000 is (40lbs?) but I'd be surprised if the same method didn't work for you. Like the other poster said, proceed at your own risk. My biggest worry at the time was standing in a dinghy with the bike swaying above my head.. . That made me a lot less worried about the plastics![]() Sounds like a great trip. Have fun!
https://twowheeledtravels.wordpress.com/ ------------------------------------------------------------------------------- 2005 Suzuki GS500F - The "Other" GS - Sold 2005 V-Strom 650 1Man2Wheels screwed with this post 03-11-2013 at 07:57 PM Reason: Clarity |
03-26-2013, 05:42 PM
#9 | |
Oddometer: 150
Sent from my SGH-I747M using Tapatalk 2 |
03-28-2013, 12:29 PM
#10 |
Oddometer: 425
Whenever you want. I have some pics but they are not digital. Actually, they closed Grand Bruit last year which was one of the stops. I am glad i saw it before they did.
03-28-2013, 02:06 PM
#11 | |
Oddometer: 150
03-28-2013, 02:09 PM
#12 |
Oddometer: 425
Not possible. The terrain is rough, mountainous, boggy and barren. Only in a tracked vehicle would be my thought.
Done on snowmobile but frozen ground is not the same in summer.
03-28-2013, 03:11 PM
#13 |
Oddometer: 150
that is what I assumed, although I wondered if a tw200 or rokon might make it.
04-19-2013, 01:09 PM
#14 |
Oddometer: 592
If I knew my bike might be loaded with a crane I would fabricate some winch points/brackets before the trip and test them with my comealong on a tree.If any inmate on here needs minor parts fab/welding in norcal send me a pm.Will work for beer.
