Old 03-10-2013, 06:06 PM   #1
Blu_Vue OP
Oddometer: 207
Front "wheel hop" issue
Howdy,
Please throw out your votes for what may be causing this issue:
Swapped a DRZ-400 front-end onto my gen-1 klr this winter and there is a feeling in the fron-end like the front wheel hops at highway speed. At first, I just thought it was the heightened feedback from the more sensitive fork / imperfections in then road, etc. But, it also happens on tar roads. More to the story: to the best of my recollection, the DRZ fork is aprox 1" taller than klr. To somewhat correct geometry, the Cogent shock was also lengthened an inch (and adding one inch of travel). Needless to say, it's a TALL mofo.
Things I've tried: two different wheels, each with a different tire (and both in good condition, no major flat spots, etc.); adjusting tire pressure; double-checking steering bearing preload.
Things I have NOT tried: making sure the tubes are the correct size (not bunched up inside the tire); checking tubes for Slime that may have gotten too thick to spread out (not sure if that's even a possibility, but both wheels have sat around a while before I mounted them); changing fork comp. / rebound dampening; verifying that the geometry is correct, front height to rear height, etc.; adjust sag.
Thank you in-advance for any good ideas you may have!
"What is to give light, must endure burning."
Victor Frankl
Blu_Vue is offline   Reply With Quote
Old 03-10-2013, 06:41 PM   #2
Wattner
Wattner's Avatar
Oddometer: 5,490
Just need to balance the wheel...
Wattner is offline   Reply With Quote
Old 03-10-2013, 08:02 PM   #3
RideFreak
Green Chile Eater
RideFreak's Avatar
Oddometer: 6,474
+1
That's pretty common although it could be caused by slime as you describe.
Chris
"Life's journey is not to arrive at the grave safely in a well preserved body, but to rather skid in sideways, totally worn out, shouting ... Holy Shit, what a ride!"
CL Adventure Ride 2013 /CL Revisited 2014 / 700 Miles of Scenic Utah Backcountry / MY VIDEOS / RIDEFREAK TV
RideFreak is offline   Reply With Quote
Times are GMT -7.   It's 12:11 AM.
