Old 03-13-2013, 10:38 AM   #1
meijer's trails OP
meijer's trails's Avatar
Oddometer: 493
anyone have a yamaha snorkel from a 1966 yj-2
I think other Yamaha's used this part too:
I'm looking all over for one of these. Anyone want to sell one, or loan a n.o.s. one?
I know a guy that remakes rubber parts if some old yamafans want to do a group buy.
It would be even better if anyone has a n.o.s. one to copy
I was kind of thinking that maybe 3d printing might be an option??
meijer's trails is offline   Reply With Quote
Old 03-13-2013, 12:17 PM   #2
meijer's trails OP
Oddometer: 493
I just checked the parts list
Its called JOINT, air cleaner 110-14453-00 or 109-14453-00
Old 04-01-2013, 09:30 PM   #3
meijer's trails OP
Oddometer: 493
Seeing double. Not quite exact, but nice, flexxy, and not leaking grit into the carb chamber.
If anyone else needs a snorkel, pm me.
Old 04-02-2013, 03:41 PM   #4
hoodellyhoo
Dummy
hoodellyhoo's Avatar
Oddometer: 220
Feel like posting a tutorial on how you did that?
1972 Honda CB350F
1972 Honda CB750 K2
1976 Honda CB750 K6
hoodellyhoo is offline   Reply With Quote
Old 04-02-2013, 08:16 PM   #5
anonny
What could go wrong?
anonny's Avatar
Oddometer: 5,697
That is awesome and we want to know more.
Kawasaki H1 build thread
71- 450 Honda CL re & re
anonny is online now   Reply With Quote
Old 04-03-2013, 05:51 AM   #6
meijer's trails OP
Oddometer: 493
i learned it on youtube by watching martha stewart tutorials about candles
Ordered the Smooth-On 2 part platinum cure silicone, no vacuum De gassing required.
200 series mold release spray.
Ordered Poly Flex 85, 2 part urethane. The 85 is a hardness rating
Plus urethane color additive from bity rubber casting supply.
The hardest part was finding an original to make the mold, but you could do by gluing the original together, molding it, casting it In Acrylic, and then sanding and adjusting it. Fixing the the areas of cracks. Then re molding and re casting in urethane.
Used a sour cream container instead of the 4sided mold making thing. And a painted shelf board as a base.
I double side taped the original down, but I should have hot glued it or got some stickier double side instead of removable double side.
Release compound seeped under one edge, thus silicone seeped under.
Hot glued the sour cream bucket, upside down, bottom cut out, as the mold.
Filled, cure, carefully remove original without tearing mold, fill it up with urethane, repeat.
Ta-daaaa vintage yamaha snorkels now available!
If anyone needs one, I can make you one for $20(my cost about 80$ to make 4)
Next up, kick start rubber with correct original horizontal grip lines, not the vertical line repros being sold in bangkock.
Old 04-03-2013, 05:54 AM   #7
meijer's trails OP
Oddometer: 493
They're multiplying like tribbles from star trek!! Help!!
Old 04-03-2013, 03:01 PM   #8
meijer's trails OP
Oddometer: 493
Horizontal lines kick start rubber complete!
The original wasn't very clean, so neither is the copy. Boiling water limbered up the copy so it slid right over the widened end of the kick pedal!
Let me know that if you need one
Old 04-03-2013, 08:20 PM   #9
anonny
anonny's Avatar
Oddometer: 5,697
Impressive, my current restoration has some "hard to get" rubber pieces. This could be the ticket.
Times are GMT -7.   It's 09:25 PM.
