03-13-2013, 03:34 PM
#16456 |
Global Bummer!
Oddometer: 266
03-13-2013, 03:36 PM
#16457 |
Global Bummer!
Oddometer: 266
03-13-2013, 08:01 PM
#16458 |
Solo con rambo
Do you sell them as well or was that custom? I like it.
I have a rack off a drz on mine.
Alan My ride reports 2000 Xr650r Supermoto/dualsport ![]() 1991 Dodge Oversize...err 250 4wd Diesel ![]() 1985 me |
03-13-2013, 09:19 PM
#16459 |
Global Bummer!
Oddometer: 266
QUOTE=lstzephyr;20941756]Do you sell them as well or was that custom? I like it.
I have a rack off a drz on mine. [/QUOTE]Thanks. It's a one off custom. I contemplated selling them but to much work
03-14-2013, 01:56 AM
#16460 |
broooommmm brooommm
Oddometer: 2,739
does it use a fuel pump?
---------------------------------------------- iam just not ready to be an adult |
03-14-2013, 05:57 AM
#16461 |
Pumpkinhead ;-)
Oddometer: 455
Yes it does, a Mikuni vacuum pump, on the lhs - it comes with this standard. This tank is less wide as the Acerbis, and fits well.
Mind though, this tank canNOT be removed off the bike when full - at least, not without adding quick-connectors with checkvalves, obviously to prevent leaking fuel all over when removing this tank. |
03-14-2013, 07:16 AM
#16462 | |
Oddometer: 1,382
Careful with the "less wide" because the Acerbis is actually narrower. The Acerbis is very narrow between the legs, but flares out in front, the IMS is wide between the legs, but stays narrower up front.
Tour of Idaho T1 Challenge - On Dual Sported XR650R's: Coming Summer 2013 Eat. Sleep. Ride - The Great Divide: http://advrider.com/forums/showthrea...4#post19193704 Go, Get Lost - Heading South: http://advrider.com/forums/showthread.php?t=735690 Dirt Donkeys Do Baja: http://advrider.com/forums/showthread.php?t=671095 |
03-14-2013, 08:19 AM
#16463 |
Global Bummer!
Oddometer: 266
As was said it does have a vacuum fuel pump (very reliable) and i have check valved quick disconnects installed so removing the tank is easy without fuel loss. Personally i don't find the tank wide at the knees at all and i wear knee braces. Like i said before it carries the fuel low which is great for balance.
03-14-2013, 09:54 AM
#16464 |
The Bone Destroyer
Oddometer: 189
I have big hands so mounting the 6.3 Acerbis is a pain in the ass! Is the IMS 7 easier to take on and off? Anyone with experience mounting both?
R1200 GSA XR650R dualsport/Rally Trainer “We should come home from adventures, and perils, and discoveries every day with new experience and character” |
03-14-2013, 03:13 PM
#16465 | |
Solo con rambo
Any help would be greatly appreciated!
Alan My ride reports 2000 Xr650r Supermoto/dualsport ![]() 1991 Dodge Oversize...err 250 4wd Diesel ![]() 1985 me lstzephyr screwed with this post 03-14-2013 at 03:54 PM |
03-14-2013, 03:37 PM
#16466 | |
Oddometer: 38
03-14-2013, 03:42 PM
#16467 | |
Global Bummer!
Oddometer: 266
03-14-2013, 03:53 PM
#16468 |
Solo con rambo
Yeah I know. The thing is I have been doing everything one piece at a time. You are just looking at a list of six months of swapping parts around. I would have taken it to a dealer or something a while ago if I thought they could do better. I have changed so much on this bike that I'm not sure a mechanic would have a starting point.
Alan My ride reports 2000 Xr650r Supermoto/dualsport ![]() 1991 Dodge Oversize...err 250 4wd Diesel ![]() 1985 me lstzephyr screwed with this post 03-14-2013 at 04:02 PM |
03-14-2013, 05:18 PM
#16469 | |
Oddometer: 475
Sounds like maybe you are 180degrees off on your cam. turn the gas off, unplug spark plug and ground it.....Have someone kick it over a bunch of times while putting your hand over the end of your exhaust. (gloved). is it blowing air out or is it sucking it in? Like wise you can see if you are blowing air out the carb instead of sucking in. Humor me?
03-15-2013, 01:09 AM
#16470 |
Pumpkinhead ;-)
Oddometer: 455
Ist,
Did you ever check if the valves actually seal - like by pouring in meth in the intake & exhaust ports, with the head in your hands or on a bench? A very mild seepage may be acceptable but not clear sweating, never mind leaking. In any case I would increase the valve clearance now, goto 0.3 & 0.4mm, and try again, just to get it to run. Also, some 4% 2T premix (yes, oil-rich!) may help in valve-sealing just to get it to run, and obviously this is a temporary makeshift measure. When it starts set the carb there where it idles best (only the idling, fork the rest), then go back to proper valve settings, fuel etc, and take it from there. With the std camshaft I doubt if one can set the cam 180-deg off, unless you have a non-std flywheel that is. But, this is darn easy to check: take rocker covers off, turn engine until both valves "rock", then check if the piston is in the top of stroke if not TDC. If so all's fine. Mind though, I think valves will hit the crown with a cam 180 degs off so you would have noticed this already, especially seeing you've tkaen the top off already. 1 thing: the camshaft is stock innit? Not reground or modded in some way? Another thing worth checking (dunno what a 'spark tester is, sorry, Thick here ) is the spark. Take a normal 4-hole button. Rig a ground wire through 1 of the holes, and rig the HT through the diagonally opposite hole. Kick the bugger over and you should see & hear the spark, pulling a generous distance. If this works your spark quality is fine.. but maybe this is what that tester does?
