Old 02-21-2011, 04:42 PM   #16
Farscape
Oh, look! Orange koolaid!
Farscape's Avatar
Location: Kickin' stones down the road to hell - Edmond, OK
Oddometer: 553
Different...
Okay, mine's different... But okay. I guess.
I measured my voltage today. .53v - 3.67v smooth.
BUT!!! This was measured between the BLACK and YELLOW wires!!! (like adiablolex?)
I could not get a correct reading between the BLUE/BLACK or BLUE/YELLOW wires
2004 950 Adv. Mfg. 12 / 2003 if it matters to anyone...
I'm not sure what this means... But I'm puttin' her back together and moving on.
-- Jody
'04 KTM 950 Adventure "Garfield" '02 KTM 520 exc-r "Hooligan Machine"
Looks like someone swung a turd covered stick through a junkyard dumpster and that's what stuck to it. - Barman
Farscape screwed with this post 03-08-2011 at 07:33 PM
Farscape is offline   Reply With Quote
Old 02-21-2011, 06:16 PM   #17
adiablolex
Lost again
adiablolex's Avatar
Oddometer: 3,692
I measured my voltagee today. .53v - 3.67v smooth.
must be an 04 thing...
can anyone else with an 04 confirm?
DRCOOL rides with me
adiablolex is offline   Reply With Quote
Old 02-21-2011, 07:30 PM   #18
Zuber
Zoob
Zuber's Avatar
Oddometer: 1,925
Yes, Black and Yellow wires on all KTM's.
The early manuals were worng with the Blue/Yellow.
I edited the original post above.
"Son, you can't do both"
Old 03-08-2011, 06:29 PM   #19
bomose
bomose's Avatar
Oddometer: 1,156
I'm having a surge at about 70 mph. The needle has been raised. I checked my TPS and got a reading of .562 closed and 3.72 WOT. At about half throttle the meter would say off or no reading. That would be about the 70 mph mark. Would you say the TPS is bad or do they all read like that? I am new to the 950 and am having to learn a lot.
I prefer a short life with width to a narrow one with length-Avicenna
http://www.advrider.com/forums/showthread.php?t=810149 Ouray Adv
http://www.advrider.com/forums/showthread.php?t=800723 Cortez & Moab
http://www.advrider.com/forums/showt...=955211Chasing Dinosaurs
bomose is offline   Reply With Quote
Old 03-08-2011, 06:51 PM   #20
cpmodem
Orange Caveman
cpmodem's Avatar
Oddometer: 7,103
The reading should be linear through the full range of throttle motion. No place should it drop to zero. make sure you are making good contact with the meter probes. You may have a faulty TPS. It happens.
-cp
DISCLAIMER: All observations made in this post are mine and based solely on my own anecdotal experiences, and may contain large doses of facetiousness. YMMV, of course. You are "on your own", and I take no responsibility if someone tries anything in this post and gets into trouble with the law, damages their person or property, or goes blind. Take everything you read or hear "anywhere" butt especially on the Web with a large dose of salt.
cpmodem is offline   Reply With Quote
Old 03-24-2012, 11:19 AM   #21
sakurama
on an endless build
sakurama's Avatar
Oddometer: 1,458
Originally Posted by adiablolex View Post
*correction*
black and yellow WTF?
Just for the record I set mine and it was black and yellow for an 04 harness.
G
sakurama is offline   Reply With Quote
Old 03-14-2013, 08:47 AM   #22
yellowbronco
yellowbronco's Avatar
Oddometer: 212
Dragging this topic out again in the hopes that someone can help.
For as long as I can remember, my 950 has had the hesitation problem. I've owned it 6 years now and, early on, I thought it was a jetting issue. Then, when I switched to the FMF mufflers, I rejetted to accommodate them and hoped that the hesitation would go away. It didn't. I even recall riding with the choke slightly engaged and this seemed to help. Then I ran across the TPS setting issue. Well, I've finally gotten around to testing mine. I get 0 volts no matter what combination of wires I test. I thought that it was my meter so I checked the battery. The Shorai is reading 13.36V. That seems reasonable so I doubt that it's my meter. Maybe I wasn't getting a cood contact with the connectors so my next action was to pierce the wires with sewing pins to ensure a good contact and then test the pins. No dice. Still 0 volts for all wire combinations. Still thinking that I might have been suffering from bad connections to the leads on my meter, I actually stripped very small sections of the insulation off of each of the wires on the harness side of the connector. Still getting 0V on all wire combinations (blue/black, yellow/black, and blue/yellow).
I placed an order for a new TPS but have begun to second guess myself. I have a hard time believing that a bad TPS would cause this. Shouldn't a measurement taken between the blue and black wires show some voltage that doesn't change, even when the throttle is twisted?
08 KTM 320 SXF, '07 Beta Rev 3,
Frankenberg 501, '96 Husaberg FC600, '68 Yamaha DT1, '74 Bultaco Alpina 250, '84 Husqvarna WR400 - My Dad says I've never seen a motorcycle I didn't want to own...
yellowbronco is offline   Reply With Quote
Old 03-14-2013, 01:49 PM   #23
geometrician
let's keep going...
geometrician's Avatar
Oddometer: 1,026
Laugh Check Supply Voltage First
You may want to look up-stream of your TPS connector to see if/where you're getting/losing your reference voltage supply before you go ordering a new one... $$
The blue wire sends 5.0 volts from the ECU, and the Yellow wire returns the throttle postition (sweep) voltage you are looking for. The Black wire is the earth/ground side of the potentiometer windings. all on page 7-16 of the LC8 repair manual.
Britt
'06 KTM 950 Adv 'S'
'03 KTM 250 EXC
'87 KLR650 - <200K miles "Like the Energizer Bunny, just keeps going & going..."
geometrician is offline   Reply With Quote
Old 09-25-2014, 05:22 PM   #24
ABuck99
0.0
ABuck99's Avatar
Oddometer: 570
2006 950S TPS Question
Re-setting the TPS; neutral position is set at .52v but WOT reads 4.07v. Manual says 3.6-3.7volts; Cant seem to get the wot reading to go any lower. Anyone experience this?
KTM: 06 KTM950S & 10 KTM450EXC
ABuck99 is offline   Reply With Quote
Old 09-27-2014, 07:08 PM   #25
braaap!
waiting for the big one
braaap!'s Avatar
Oddometer: 2,385
Hmmm! need some advice, the bike is an 04, carbs are out and on the bench... So I measure 4.99V on the blue wire (at the rear of the connector) on the TPS, good!
Hook the multimeter between the Blue and Yellow wires (per the manual) and it reads 4.9v closed and 0.0v WOT (arse about like others have found).
It's an 04, so take a new reading between the Yellow and Black wires and it's 0.0v closed and 0.0v WOT... WTF?
I've got good contact with the probes... what am I missing here? Duh.
braaap! screwed with this post 09-27-2014 at 07:35 PM
braaap! is online now   Reply With Quote
Times are GMT -7.   It's 06:28 PM.
