Old 03-11-2013, 05:59 PM   #751
MiteyF
MiteyF's Avatar
Oddometer: 2,028
I've always wanted an S3... nice!
People tell me I have a motorcycle problem. I tell them, I may have problems, but motorcycles are the solution.
MiteyF is offline   Reply With Quote
Old 03-11-2013, 07:22 PM   #752
Trane Francks
Trane Francks's Avatar
Oddometer: 645
Originally Posted by smokin2stroke View Post
75 Kaw S3A, rebuilt engine, ported, stage 2 reeds, Denco repops, ram air induction. I dont know how much hp its got but it isnt stock by any means. Ive had this bike for 25 years.
Dude! That S3 is KILLER! Absolutely gorgeous. I've always had a soft spot for this one, but a '79 RD400 got in the way of me ever buying an S3.
Trane Francks is offline   Reply With Quote
Old 03-13-2013, 09:44 PM   #753
Pete-NZ
Pete-NZ's Avatar
Oddometer: 751
I had a 77 Kawasaki S3 400... Blue bugger...
They are a piston port motor .. 2 stage reeds ?
Here.... my XR250 leaner side car build
http://www.advrider.com/forums/showthread.php?t=716993
Pete-NZ is offline   Reply With Quote
Old 03-14-2013, 05:16 PM   #754
smokin2stroke
smokin2stroke's Avatar
Oddometer: 18
It's been moodified a bit.
http://www.3cyl.com/mraxl/aylor/reeds/reeds.htm
Cylinders were decked (a shade more than I should have and that was my mistake), intakes had to be shaved for 30mm carbs, been bored .20 over, Paul Gast did that work, I added new boost ports, reed kit, and added 30mm mikunis help it breath. As you can see, there's a big difference in size.
Build thread is over here if you want to see. It was alot of work but I like it. I've had this bike for a long time and it's almost like family. Lots of memories and it's twice the bike it ever was.
http://www.kawi2strokes.com/forum/vi...hp?f=16&t=2613
75 S3A-RA, 71 RT1B, 77 CT125, 83 HD 1000 Sporster and other toys. Next up.....a 74 H2B in pieces. It'll be just like putting together a big puzzle.
smokin2stroke is offline   Reply With Quote
Old 03-17-2013, 01:58 PM   #755
Hellracer.nl
What the hack???
Hellracer.nl's Avatar
Oddometer: 449
Just playing around today:
To beer or not to beer, that's no question.
My Leaner build: http://advrider.com/forums/showthread.php?t=836987
K1100rs, K100rs, F650, GSX1100, TS185
Hellracer.nl is offline   Reply With Quote
Old 03-18-2013, 09:55 AM   #756
Seavoyage
Seavoyage's Avatar
Oddometer: 133
Big Bore Trials
The Find!: GasGas 1995 JT35 posted on CL and quickly purchased it:
Due Diligence:
The previous owner purchased it in San Jose in 2011 and did not do any maintenance, or ride it much. He bought it from someone who could not start the high-compression motor.
Developed by 7-time World Champion Jordi Tarres (hence the JT model) for GasGas to compete in the World Trials Championship (WTC), this model won the WTC 3 consecutive years from 1993-1995.
This is not a beginners bike! Quite scary!
I contacted Jon Stoodley http://www.gasgas.com/tech.htm , one of the key figures in preserving Trials scene here in the USA. Jon told me that the bike was originally owned by Steve Darrow, a National ranked US Observed Trials Championship competitor. Jon had made some head modification on this bike to make it easier to start. This bike is a 'big-bore 2-stroke beast: capable of 6th gear wheelies. The 327cc engine was the most powerful trial motorcycle produced by any manufacturer until the 1996-1997 338cc JTR370..
The engine design is considered to be bullet proof. Used in GasGas trials models till 2003, it is also used in the 1995 to the current generation of GasGas EnduroCross bikes which have roots in the Cagiva/Husqvarna WR chassis design. The EnduroCross 250/300 uses different transmission ratios, cylinder, and incorporates a exhaust powervalve. Trials manufacturers no longer build these big bore bikes (current models are under 300 cc).
After a few hours inspection, and routine maintenance, everything works!
Due to the heavy clutch use on a trials bike, we run Dexron III ATF fluid in this transmission (or 5W30 Dino oil) and never sythetic oil. The transmission 1st-4th gear are suited for trials, with 5th & 6th set up for trail riding.
The Paioli fork design which was used by GasGas until 2001 (Current GasGas Pro uses Marzocchi), Sherco to 2009, and Beta to 2010. The Paioli RSD fork has only one spring held in the Left fork with 280cc of 5W fork oil. The dampening cartridge is held in the opposite (Right) fork with 330cc of 7.5W fork oil. Bleeding the AJP clutch (mineral oil) and the rear brake (DOT 4) is interesting as you push the fluid up though the nipple towards the master cylinder: as opposed to filling the upper cylinder and letting the fluid drain down. The bike has all the components of the GasGas Factory WTC bikes: Dellorto PHBH26CS replaced with Keihin PWK28 (yes a 28mm!); Kokusan ignition; Boyesen reed valves. You'll notice that a trials 2-stroke does not have an expansion chamber (note the exhaust pipe).
These models are wired for lighting, and were street legal in Europe. I will probably get a CA license plate for this one in the near future.
Nut and Bolt check complete, lubed, and fresh fluids. Replaced fork oil. Tyre pressure set: 7 psi Front/3.5 psi Rear. Fresh 80:1 Pre-mix.Taking her out today to bash some rocks and logs!
Here's the Jordi Tarres video:
First Ride Report: The JT35 definitely feels heavier at around 170 lbs. In comparison the trials bikes over the past decade are sub 150 lbs. The geometry is fine and comparable to more modern bikes, but some bikes have even tighter steering lock. I need to get fresh Michelin X11 and adjust the clutch engagement: I kept on pushing my front in limited traction turns - and I should really lean the bike more and turn the bars less (oxymoron when you are practising full lock turns.)
It feels very planted, and compared to my daughter's GasGas TXT Pro 200, it much more suited for trail riding. Gobs of torque which let's you power through anything, even more so than my GasGas EC300. But relatively a challenge to kickstart with the high compression and low exhaust port. With the proper technique I can kickstart in the first or second kick. Good fuel mileage - we rode 4-hrs. yesterday without refueling.
I highly recommend trials as the foundation for all riders. It will make you a much more controlled and proficient rider.
There is no hunting like the hunting of man, and those who have hunted armed men long enough and liked it, never care for anything else thereafter. -Ernest Hemingway
Seavoyage screwed with this post 05-13-2013 at 10:11 PM
Seavoyage is offline   Reply With Quote
Old 03-23-2013, 07:02 AM   #757
smokin2stroke
Oddometer: 18
Watching those guys do that trial stuff running up and over the biggest obstacles with that much balance is amazing. It really takes some skill.
Nice machine. As light as those bikes look, they have to be a blast to ride.
Old 03-23-2013, 07:54 AM   #758
KayAitch
KayAitch's Avatar
Oddometer: 91
Figured I would throw my 2 smoker into the ring.
Read all about the pain I am having here
KayAitch is offline   Reply With Quote
Old 04-06-2013, 02:04 PM   #759
Droptarotter
Oddometer: 1,285
Finished mine..........
Cheers
HP2 Sport, R1200S, R100S, KTM 640 Adventure, KTM 520 EXC/Motard, Yamaha RZ350, Hodaka 125 Wombat
Droptarotter is online now   Reply With Quote
Old 04-12-2013, 08:39 AM   #760
Knobbiethrower
ADV in ADK
Knobbiethrower's Avatar
Oddometer: 1,324
Finished winter project
Knobbiethrower is offline   Reply With Quote
Old 04-12-2013, 11:45 AM   #761
AWM
Beard Bros Racing
AWM's Avatar
Oddometer: 11,383
Hey,,,wheres the headlight?
"Hes not called the Angry White Man for nothing,much more fitting then the,Unicorn Clouds and Happy Trees Man".... UpST8
Theres a name for people without beards,"Women".
AWM is offline   Reply With Quote
Old 04-12-2013, 12:18 PM   #762
roadholder
roadholder's Avatar
Oddometer: 2,516
Kawasaki KMX 125
My ride exploring the Isle of Man many years back. Went everywhere with that thing from the TT course to tractor paths.
roadholder is offline   Reply With Quote
Old 04-12-2013, 01:05 PM   #763
Knobbiethrower
ADV in ADK
Oddometer: 1,324
No headlight for this one....
Old 04-12-2013, 01:06 PM   #764
Knobbiethrower
ADV in ADK
Oddometer: 1,324
That must have been a ton of fun!
Old 04-12-2013, 01:06 PM   #765
AWM
Beard Bros Racing
AWM's Avatar
Oddometer: 11,383
Hare Scrambler!
Times are GMT -7.   It's 08:18 AM.
