Old 03-16-2013, 03:10 AM   #5866
ditchwitch650
ditchwitch650's Avatar
Oddometer: 842
Originally Posted by KASUYAHO View Post
The first PWR's did not fit,
the thinner second set of PWR's did not fit and are being modified
and were ready the day after i came back to work.
My convern is when i get home and try the PWR's and they don't fit,
then i am up shits creek without a paddle.
No radiators, no Condo.
Just thinking i could put on the stockers and run with them,
then go back to gitting the PWR's.
why don't they fit? aren't they made for the XRR?
ditchwitch650 is offline   Reply With Quote
Old 03-16-2013, 04:04 AM   #5867
KASUYAHO
Road Hog
Oddometer: 3,607
Stock radiator is 18mm thick at the core.
The 42mm thick radiator would fit with a stock header is my guess.
The 32mm ones i got were messed up a bit, mounting holes too big, etc.
A guy from PWR Adam has come and looked at the problem where the bike is and will sort it eventually.
Note: the reason why i wanted the thicker radiators is, if i hole one,
i can by pass that radiator and the engine can still run with one radiator without overheating.
KASUYAHO is online now   Reply With Quote
Old 03-16-2013, 05:00 AM   #5868
ditchwitch650
Oddometer: 842
so there thicker rads will onlt fit with stock header pipes?
do you have rad guards to help prevent holing 1?
Old 03-16-2013, 05:30 AM   #5869
KASUYAHO
Road Hog
Oddometer: 3,607
42mm would fit with stock header and a header that has the same tight radius out of the cylinder head as the stock header has.
I have the "FAB" brand radiator guard / brace
Old 03-21-2013, 03:16 AM   #5870
Sean-0
straya carnt
Sean-0's Avatar
Oddometer: 4,371
Any new pics poppy
The subframe is working a treat mate
I am sum what used to it now but the bike seem to stiff'n up ,its hard to explain .. i noticed it most on the tar ...or maybe its just me
I have seemed to tame down the xr's only pipe ... its still loud and crackles a bit ..but no more flames and sparks
it has colored up real nice ... im real happy with it .. i think i can feel a nice pwr gain in the bottom end ..looking forward to getting it back on the dyno in a few weeks
Sean-0 is online now   Reply With Quote
Old 03-21-2013, 05:09 AM   #5871
ditchwitch650
Oddometer: 842
Originally Posted by Sean-0 View Post
Any new pics poppy
good news on the sub-frame, will be intrested to see what difference the pipe gets on the dyno
Old 03-24-2013, 02:42 AM   #5872
poppy
Slow and Steady
poppy's Avatar
Oddometer: 2,292
Starting to resemble a bike again Sean-O.
Didn't like the way the B&B frame guards fitted, so gave them a little tweak, fit much nicer now. Not sure why they dont do it to start with.
poppy is offline   Reply With Quote
Old 03-24-2013, 07:59 AM   #5873
ZXRaziel
ZXRaziel's Avatar
Location: Grey skyes and rain of Good old England ( NEast)
Oddometer: 481
Looking forward to see the bike finished poppy
good things them hondas
ZXRaziel is offline   Reply With Quote
Old 03-25-2013, 05:54 AM   #5874
poppy
Slow and Steady
poppy's Avatar
Oddometer: 2,292
You and me both mate. Hopefully it will be a nice bike to ride.
Got the barrel and piston fitted up tonight along with a few small things. Hopefully get my head back tomorrow from getting skimmed and the new valves seated.
poppy screwed with this post 03-26-2013 at 05:28 PM
Old 03-25-2013, 06:06 AM   #5875
ditchwitch650
Oddometer: 842
looking good poppy!!! what piston did you go for?
Old 03-25-2013, 06:17 AM   #5876
poppy
Slow and Steady
poppy's Avatar
Oddometer: 2,292
G'day Ditchy, just a forged Wiseco 10-1. Wanted to keep the comp standard for trips into no man's land with crappy fuel.
Old 03-26-2013, 05:26 PM   #5877
poppy
Slow and Steady
poppy's Avatar
Oddometer: 2,292
Head looks a little cleaner than before.
New spring seats, valve stem seals, springs and retainers ready for fitting.
New valves in place
Spring seats, and valve stem seals
Valves finished
Difference in height between the Kibble White valve springs and stock
Kibble White retainers are a liitle bigger dia as well, nice gear , very well finished.
Fit the rest of this gear up and the engine is ready to button up.
Old 03-27-2013, 03:07 AM   #5878
Sean-0
straya carnt
Sean-0's Avatar
Oddometer: 4,371
this things gunna rip ......pretty close to the end of March mate
better get a rigalong
Old 03-27-2013, 05:09 AM   #5879
poppy
Slow and Steady
poppy's Avatar
Oddometer: 2,292
Not sure about rip mate, its just gotta go and i will be happy.
Dont suppose anyone local to the Goldie has a cam shaft plug spare. It appears i didn't order one and it looks like i threw the old one out, if not, i'll try my luck with the local honda dealer.
Old 03-27-2013, 05:49 AM   #5880
digga1111
bann ed
digga1111's Avatar
Oddometer: 3,469
i have one. you gotta come to the dam to get it though
iam just not ready to be an adult
[QUOTE=troy safari carpente;24254589]
... the XR is the greatest off road motorcycle ever constructed. There's nothing it can't do, hasn't won or will not outperform.
digga1111 is offline   Reply With Quote
Times are GMT -7.   It's 05:30 PM.
