Old 01-26-2013, 06:00 AM   #571
dirty_sanchez
Dirty_Sanchez
dirty_sanchez's Avatar
Oddometer: 2,991
Originally Posted by DC2wheels View Post
It probably has something to do with the fact that glass is actually a "super-cooled liquid"?
It VERY SLOWLY flows. Look at a very old pane of glass- it is thicker at the bottom than at the top.
Ding Ding Ding!!!! Circle gets the square!
Glass is actually a liquid. Liquids are tough to bond.
If you ever go into very old houses-the kind that still have wavy glass that has it's original window caulking, more often than not the caulking near the bottom of the pane has been busted out, while the caulking at the top is still in good shape. This happens because the glass settles or sags over long periods of time.
Dirty
No, really, the mustache means I love you.
dirty_sanchez is offline   Reply With Quote
Old 01-26-2013, 06:41 AM   #572
rufus
We're burning daylight...
rufus's Avatar
Oddometer: 4,242
#39 pages so far.......
It would save us all a lot of trouble if there was a chart somewhere that listed ALL the products (gasket sealers, thread lockers, gasket eliminators) and explained in PLAIN ENGLISH exactly what they are to be used for and where they shouldn't be used. How to apply them and how to remove them. I think that just posting a chart like this would improve sales immensly.
We want details.
rufus is offline   Reply With Quote
Old 01-26-2013, 10:33 AM   #573
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 4,719
Dirty
You shouldn't repeat that myth, been debunked many times over. Lower caulking gets damaged from condensation dripping down and swelling the wood at the bottom of the pane. Much worse when it freezes then thaw. I have restored enough of them old wavy panes windows, some close to a hundred years old to know.
Couple hundreds of them old panes in my little house and there will be many more when I close in the back porch with them old cedar framed school windows I have to restore someday.
Flowing glass maybe but.....:
Viscosity depends on the chemical composition of the glass. Even germanium oxide glass, which flows more easily than other types, would take 10^32 years (100,000,000,000,000,000,000,000,000,000,000) to sag. Zanotto calculates. Medieval stained glass contains impurities that could lower the viscosity and speed the flow, but even a significant reduction wouldn't alter the conclusion, he remarks, since the age of the universe is only 10^10 (100,000,000,00).
From there and there are many others:
http://www.glassnotes.com/WindowPanes.html
Have tools, will travel!
Old 03-09-2013, 06:06 PM   #574
cwc
Oddometer: 939
Bonding cloth to polypropylene
I need to bond some cloth, cotton I think, to some coroplast (sp?) which is the corrugated polypropylene sheet material used in political lawn signs.
This will be for use inside a van.
The sheets will be 1 ft. X 4 ft. and there will be three of them.
I'd like to use a spray-on adhesive if possible and hopefully be able to buy it at Menards, Home Depot etc.
I would like product suggestions and if known what the coverage per container will be.
I looked in the Loctite consumer product selector but didn't find info on specific materials.
TIA for any suggestions.
Charlie
DR350 It'll get you there
My Ride Reports Here
cwc is offline   Reply With Quote
Old 03-09-2013, 09:48 PM   #575
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 7,144
Any contact adhesive should be good.
Spray on both surfaces, let dry, press together...
NordieBoy is offline   Reply With Quote
Old 03-10-2013, 01:56 AM   #576
buickid
Lets ride!
Oddometer: 310
+1 on NordieBoy. 3M Super 77 or equivalent will work wonders. Once it sets up... its gonna be there for a while.
2005 Yamaha Zuma YW50, 2009 Kawasaki Super Sherpa KL250
buickid is offline   Reply With Quote
Old 03-12-2013, 06:36 AM   #577
Kannonball8
Oddometer: 92
Shelf Life?
Does Locktite 242 have a shelf life? I have several small bottles in the shop that may be as much as 10 to 15 years old. The contents are still liquid and look the same as new 242, but will it still work as well? (hope this hasn't been covered already - couldn't find topic in search.)
Thanks,
Bruce
Triumph 1200 Explorer & Speed Triple
BMW R-100 S & R-100 Café Racer
Ural Gear Up & Yam WR-250
Mrs. K8 - Tri. Tiger 800, Ural Patrol, WR-250
Kannonball8 is offline   Reply With Quote
Old 03-12-2013, 06:41 AM   #578
fallingoff
Oddometer: 3,677
if so explain the glass windows in europe
thin at the top
thick at the bottom
not like me i'm thick from top to bottom
lol
fallingoff is offline   Reply With Quote
Old 03-15-2013, 12:10 PM   #579
k-moe
Oddometer: 2,854
thin at the top
thick at the bottom
lol
Hand poured glass panes are thicker on one end than the other due to uneven cooling as the glass is poured. Modern glass is made in an entirely different way so that is is of uniform thickness. http://chemistry.about.com/od/matter...Or-A-Solid.htm
I am constantly amazed at how myths get propagated when actual facts are so easy to find. Seriously.....less than 10 minutes of searching yielded dozens of papers on the physical, and chemical properties of glass. Amorphous solids rule!
As for why it's difficult to "glue" glass.......there are very strong covalent bonds between the silicon and oxygen in the glass. What that amounts to is there are very few free electrons for anything else to bond to, so chemical bonding is difficult. Physical bonding is difficult for the reasons previously stated...the relative smoothness of the surface.
k-moe screwed with this post 03-15-2013 at 12:33 PM
k-moe is online now   Reply With Quote
Old 03-15-2013, 05:17 PM   #580
fallingoff
Oddometer: 3,677
ok
but why all thick on the bottoms of the windows
i'll ask my sister
chief material for nasa
ur spoiling what i thought was a fact
live and learn
cheers
Old 03-15-2013, 05:31 PM   #581
GSWayne
Old Guy nOOb
GSWayne's Avatar
Oddometer: 3,097
One more comment on flowing glass
If glass flowed it would be impossible to make accurate optics and things like telescopes and camera lenses would quickly become useless. Good optics are precise to almost atomic dimensions and will hold that precision for years.
It isn't the conditions its the decisions
Don't bring a motorcycle to a car fight
GSWayne is offline   Reply With Quote
Old 03-16-2013, 03:30 PM   #582
fallingoff
Oddometer: 3,677
quote from sister at nasa
''Glass is technically a liquid. However the time to flow so you could see it is very long. Early glass makers did not have the float glass system and so making flat glass was tricky. It was naturally uneven. It would be natural to put the thick part at the bottom.
Glass does not have long range order,I.e. the atoms are not arranged regularly to make a crystal structure.''
well that explains that urban legend
cheers
Old 04-23-2013, 02:18 PM   #583
stainlesscycle
stainlesscycle's Avatar
Oddometer: 2,278
recommended loctite retaining compound for o.d. of seals with nitrile coating? seal surface is good, seal went in tight. it still likes to push itself out after a few hours of hard running......
current bikes
stainlesscycle is offline   Reply With Quote
Old 04-23-2013, 07:26 PM   #584
dirty_sanchez
Dirty_Sanchez
Oddometer: 2,991
If the ID of the hole is ferrous OR non-ferrous I'd hit the mating surface of the seal with a quick shot of 7649 Primer N to activate the surface, then apply a thin bead spread around the metal hole with a Q-Tip any of the thicker viscosity retaining compounds. This should work fine.
Remember, a thinnish bead. We're trying to minimize the squeezeout to the innards of the engine. Don't glob it on-thus the Q-Tip trick to help you better control the amount of retaining compound you apply.
Then gently drive the seal into place and let it sit overnight.
As far as a specific product suggestion in absolutely no order of importance: 620, 609, 680, 603, 660.
Good Question, Great Application! Thanks for asking-this question and answer will get someone out of a jam one of these days.
Dirty
Old 05-26-2013, 04:19 AM   #585
dondy
dondy's Avatar
Oddometer: 5
Hello to all, I'm new here and loctite topic bring me in... A lot of great info on a subject!
I'm curetly removing old studs from my vespa hub, because they are to short for new aluminium wheels. I need to replace them with longer one.
The old ones had no thread in the middle so they are locking on one side with no threaded part, and on the back side they are punched at the end and are locked not to unscrew.
I bought new studs, but they are threaded all the way, and I have no tool to punch them on the back, and also don't want to brake hub (it's aluminium).
The best solution I could think of is loctite.
Wich one to use? When those studs are in place i need to fasten rim on them. Studs are M8.
I will have no need to remove the studs again (eventualy for few years if I damage the treads)
Where I live I found only 2701 as the strongest threadlocker (green), i think 243 is to weak for my needs.
I hope i explaind well, sry for my lack o english..
Thanks for any help!
dondy is offline   Reply With Quote
Times are GMT -7.   It's 10:58 PM.
