Old 03-16-2013, 04:50 PM   #1
Mikepotter86 OP
Oddometer: 178
1981 R 100 RT rear brake problem! What did I do wrong?
I just swapped the brake lines and front master cylinder off my 81 R100Rt, replacing with new steel lines from spiegler, and a brand new OEM MC.
Before the operation the front had no brake pressure due to a leaky MC, with the new MC and the new steel brake lines the front is working great.
Before the operation the rear was fine, but I figured I might as well swap the line out since they're probably 30 years old, but after installing and bleeding the rear, it has no pressure. I bled the system for what seemed like hours, but no pressure builds, even once the air bubbles are all gone. I don't mean it is spungy, it is like I have no brakes! With the bleeder closed I have no leaks that I can see.
I am sure I did something stupid. Help me out here!
Mikepotter86 is online now   Reply With Quote
Old 03-16-2013, 05:19 PM   #2
Married Man
Oddometer: 134
I've had the same issue after replacing the rear mc and brake line. I tried pushing and sucking the fluid through with the same poor results. I got pressure after I removed the caliper, put a wedge in between the brake pads, and strung it up so that the bleeder was on top. I used a one-way valve brake bleeder until I got no air and then let it sit for a day and bled it again. Teflon tape the bleeder valve to keep air out. I have good brake pressure now.
Married Man is online now   Reply With Quote
Old 03-17-2013, 02:54 AM   #3
Plaka
Brevis illi vita est
Oddometer: 4,609
What does this mean: "...swap the line out."?
Old 03-17-2013, 04:10 AM   #4
Paul_Rochdale
Paul_Rochdale's Avatar
Oddometer: 150
Replace the brake hose for a new one.
Paul_Rochdale is offline   Reply With Quote
Old 03-17-2013, 04:34 AM   #5
TINK
Oddometer: 732
Been there, didn't like that
This might help... http://www.advrider.com/forums/showp...1&postcount=10
TINK
TINK is offline   Reply With Quote
Old 03-17-2013, 04:39 AM   #6
TINK
Oddometer: 732
+1 on the Teflon tape.. oh, ya, don't forget to wedge the pads.
Old 03-17-2013, 04:46 AM   #7
hardwaregrrl
ignore list
hardwaregrrl's Avatar
Oddometer: 7,540
Have you disconnected the line from the caliper to insure there isn't a block in the new line?
Old 03-17-2013, 07:30 AM   #8
pbarmy
pbarmy's Avatar
Oddometer: 1,818
Everything I've read says hang the caliper upside down,this puts the bleeder at the bottom,allowing for any trapped air to escape.
"Nostalgia ain't what it once was"
pbarmy is offline   Reply With Quote
Old 03-17-2013, 09:08 AM   #9
Mikepotter86 OP
Oddometer: 178
Thanks for all the advice! I will try a new approach when I next have use of a garage, or when the weather improves.
Old 03-19-2013, 05:59 PM   #10
Slipkid
Slipkid's Avatar
Oddometer: 1,827
brake bleeder
I have had a couple of difficult brake bleeding sessions. The best trick I found is to not just pump the brakes up and then open the bleeder when compressed but to always remember to pump the brake pedal or lever many times before starting the pump and purge process with the bleeder wide open. I think this gets the brake fluid and air moving towards the vent. Also add a length of flexible hose to the bleeder to catch the fluid and create a liquid trap.
Just keep trying and don't get any on the paint.
Slipkid is offline   Reply With Quote
Old 03-19-2013, 07:20 PM   #11
lucky6600
lucky6600's Avatar
Oddometer: 633
Do you have the rear caliper all screwed/tide down at it's position while you are trying to "bleed" out all the air?
If you did, lose the support arm and move the caliper angle little bit (rotate it) having the bleeder facing up, let gravity does it's job. You might find more air still trapped in there.
worth a try and ask me why I know that
lucky6600 is offline   Reply With Quote
Old 03-20-2013, 06:26 PM   #12
DaveBall
DaveBall's Avatar
Oddometer: 1,163
I see that everyone wants to bleed the brakes using the most time consuming and difficult methods.
1. Leave everything mounted as it should be.
2. Go to local pharmacy / drug store and purchase 2 large syringes that hold at least 30cc of fluid. and purchase some clear surgical tubing from them as well, about 2 feet is more than enough.
3. Use 1 syringe to suck all the fluid out of the master cylinder and dispose of it in a disposable container.
4. Using the 2nd syringe attach about 12 inches of tubing and suck up some new brake fluid.
5. Attach the tubing and the 2nd syringe to the bleeder on the caliper, and crack the bleeder.
6. Slowly inject the fluid in thru the bleeder while having someone hold the brake pedal slightly depressed. I just put a 1 quart paint can on it.
7. Close the bleeder and refill the syringe.
8. Repeat steps 5 and 6, watching the master cylinder for bubbles and remove excess fluid as required.
I have done the above procedure on a lot of friends bikes with "useless non working rear disk brakes" and every one of them has ended up with an excellent rear brake. This procedure is simple and once you do it, you will be very surprised how easy it is to get a good solid pedal, and a brake that will actually stop the bike.
I also use this same procedure on front brakes if I have had to remove any lines, or I just can't get the spongy feeling out of them using the normal methods.
DaveBall is offline   Reply With Quote
Old 03-20-2013, 06:28 PM   #13
hardwaregrrl
ignore list
Oddometer: 7,540
+1 In your neck of the woods, hit up a feed and seed for the syringe.
Old 03-20-2013, 06:39 PM   #14
jackd
Oddometer: 3,049
Is it just me or does this statement make no sense to anyone else? Why would you put the bleeder at the bottom when any trapped air in the caliper would be floating up toward the top of the chamber, where it can not be expelled? I bleed lots of disc brakes in my line of work and you always go for the uppermost bleed screw to allow the bubbles to leave the unit.
Old 03-20-2013, 07:05 PM   #15
Plaka
Oddometer: 4,609
I use a small electric vacuum pump and a receiver for the fluid. Brake bleeding is incredibly fast zero hassle process. Any brake, any time, anywhere (that has power). This is what shops use, for a reason. I can do a full flush in about 5 minutes and most of that time is getting the pump off the shelf and hooked up. if the system is dry I put on the vacuum first then add the fluid. Gets pushed right through driving any air ahead of it.
I notice MityVac makes vacuum pumps. Vacuum pump and receiver, runs of an air compressor.
http://www.amazon.com/Mityvac-6830-B...ywords=mityvac
This will pull vastly more vacuum than you need but the pric is right and you can play some other games with it (I use a bigger one to preserve food as well as do HVAC work). The easy way to use it would be with a cheapo portable air tank. Evacuate the tank and then use the tank to bleed to a receiver---or you could just work right off the pump into a receiver.
www.amazon.com/Mityvac-6830-Brake-Bleeder/dp/B000JFN9WC/ref=sr_1_13?s=automotive&ie=UTF8&qid=1363830686&sr=1-13&keywords=mityvac
pumps are just getting so cheap there isn't a reason not to have one. it's a tool that makes you happy every time you use it.
Times are GMT -7.   It's 07:49 AM.
