Old 02-20-2013, 05:48 AM   #391
Yokomo
Gorilla Adventurer
Yokomo's Avatar
Oddometer: 2,260
Mine has done that before while trying to start but never while riding. I don't know, but I would think you have a broken spring that keeps enough tension on the kicker to keep it from going backwards.
I run Klotz in my weed wacker and chainsaw for the smell
Yokomo is offline   Reply With Quote
Old 03-04-2013, 11:54 AM   #392
rabags
Oddometer: 1
Hi guys and dolls, does anyone here have a stock muffler off of their klx300 that they would like to sale? Thanks just let me know
rabags is offline   Reply With Quote
Old 03-18-2013, 06:22 AM   #393
craydds
craydds's Avatar
Oddometer: 1,156
Sunday ride
Desert ride on a Sunday morning with my son. There are hundreds of miles of trails, don't think I could ever ride them all:
ABC #12947
'75 R90S
craydds is offline   Reply With Quote
Old 03-24-2013, 04:30 PM   #394
73Mustang
Oddometer: 394
How smooth and viby is the 300 on the highway?
I'm looking to buy and DS one. I currently ride a KDX 220 (same bike as KLX except 2-stroke). I find the KDX to be too much vibration, even at low speed. Cruising at 45 MPH was all I could bear. But the bike is very powerful; it can probably do 80 MPH. But anything over 45 is too viby and too loud (even with stock muffler) for a normal person to bear for extended time.
73Mustang is offline   Reply With Quote
Old 04-28-2013, 10:05 AM   #395
djchan
djchan's Avatar
Oddometer: 1,173
Mustang - I've owned and ridden both on and offroad.
The KDX is better offroad although not much . I believe I get the KLX's power to the ground more effectively but it's a bit heavier. Pick your poison....
The KLX is much smoother onroad. Mine will do 85-90 mph with taller gearing. Now I own a dualsported KLX250S and KLX300R. The 250 is going up for sale soon. It's 25 pounds heavier and 5-6 ponies less. Only drawback is the kickstart only on the 300R. Good news - the 2004s and newer are super easy to kick anyway. I can and have started it by hand several times.
I had a hard time riidng the KDX without keeping it "on the pipe". 2T's have that effect on me. The 300R is super easy to ride slow and unlike the KDX, doesn't mind being wound.
BTW, my 220 was Ron Black'd to the max and was a real monster.
Hope that helps.
used to have - 1982 Maxim 650, 2000 Concours, 2001 KLX300, 2001 DRZ400E, 2004 KLR650, 2006 TE610, 1998 KDX220, 2001 Bandit 1200S, 2007 KLX-250, 2004 KLX-300R and a 2002 KTM 400EXC.
Now own - 2007 Suzuki Bandit 1250, 2002 KTM LC4E, and a 2007 CRF250X.
djchan is offline   Reply With Quote
Old 04-29-2013, 08:06 AM   #396
73Mustang
Oddometer: 394
What makes the pre-04s difficult to start? I just got a '98. And it is a ?#$&*! to start.
Old 04-29-2013, 06:17 PM   #397
Yokomo
Gorilla Adventurer
Yokomo's Avatar
Oddometer: 2,260
Something about the cam being off 180 degrees or something.
My 98 kicks nice and firm/hard, but it fires right up when you set it to TDC.
Old 04-30-2013, 09:43 AM   #398
not ned
not ned's Avatar
Oddometer: 87
some kawasaki's did and may still use what is called KACR - for automatic compression release. I think KLR's still use this too.
at 0 to very low rpm's - prob less than 1000 or so - the mechanism holds one of the exhaust valves open acting as a compression release. once the motor starts and rpm's increase the mechanism allows the exhaust valve to close all the way and the engine runs normally at full compression.
this is why klx's start so easy with a soft kick and why you don't feel much resistance or kick back at any point on the crankshaft start cycle.
one thing is for certain - I am definitley not ned!
AMA - COHVCO - BMWMOA - Moto Boulder - DROC - BCTR - NCTR
not ned is offline   Reply With Quote
Old 05-17-2013, 11:38 AM   #399
djchan
djchan's Avatar
Oddometer: 1,173
My 300R has the billet straight endcap seen on ebay for $35 for the stock muffler. Anyone have the billet turndown but would like to trade? Mine's in great condition - just looking for a change.
Old 05-17-2013, 12:14 PM   #400
Yokomo
Gorilla Adventurer
Yokomo's Avatar
Oddometer: 2,260
Here's a vid of my KLX300 going thru a little enduro practice track.
http://www.youtube.com/watch?v=v06xfBhzKSU
Old 05-26-2013, 05:48 PM   #401
djchan
djchan's Avatar
Oddometer: 1,173
Dumb question - which end of the petcock lever is the pointer end - the short end or the long end?
I don't want to run out of gas (again) by leaving it on "reserve" when I want it in the "on" position.
edit: never mind. I figured it out AND put it to the test. Long end of handle is the pointer.
djchan screwed with this post 05-31-2013 at 12:53 PM
Old 06-24-2013, 07:54 PM   #402
thinairflyer
Oddometer: 161
KLX300 muffler rear tip size?
Can anyone give me the dimensions of the pipe that usually gets removed from the rear of the [COLOR=blue !important][COLOR=blue !important]muffler[/COLOR][/COLOR]? Inside diameter and length and how much of that length goes inside the muffler? I need to make one to quiet down the muffler I have that is missing that part. Thanks
thinairflyer is offline   Reply With Quote
Old 06-24-2013, 07:58 PM   #403
thinairflyer
Oddometer: 161
Wanted KLX300R stock muffler tip
I need a stock KLX300 muffler tip.
Price shipped cheapest way to 81252?
Pay by PayPal
Old 07-10-2013, 02:37 PM   #404
hadfield4wd
Oddometer: 117
My new ride.
1998 KLX300
Thats after a 5 hour wrench fest to get it in shape for a a ride the next day. 24 hours after I bought it.
So far I love it.
I did all the free mods.
Added the Kawi 49 state needle.
#132 Main Jet
#38 pilot (this was in it already)
Fuel screw out 2 turns
Maier MX fender
Pro Circuit Platinum pipe (looks like a stock header)
Also the suspension both front forks and rear shock have proaction stickers but no data on them. I'll be tearing them down soon to see what is inside. And maybe sending them off for valving for me.
It has some of the baja designs DS kit installed. Just need a rear tail light and blinkers to make it street legal.
I put MT21's on for the DOT and I have a MT43 on order just need to scare up a spare rear wheel to mount it.
Anybody know what other bikes croos the KLX rear wheel?
hadfield4wd screwed with this post 07-10-2013 at 03:23 PM
hadfield4wd is offline   Reply With Quote
Old 07-10-2013, 10:13 PM   #405
Huskyfatman
Huskyfatman's Avatar
Oddometer: 1,250
I've swapped wheels back and forth on my girls KLX and my KDX200. Pretty sure '95 to 2006 are the same as well as the 220 model.
http://www.sharetrails.org/
http://www.americansandassociation.org/
"YOU KNOW. . . . . .WE ARE LIVING IN A HEAT LAMP SOCIETY!"-Ron Perez 2002
Huskyfatman is online now   Reply With Quote
Times are GMT -7.   It's 04:54 PM.
