03-17-2013, 04:50 AM
#1 |
Forever N00b
Oddometer: 1,607
I know you make your own motorcycle tools
I know you make your own tools. Seems like anyone who uses tools much soon hits a case where cutting a piece of PVC for a seal driver is easier than buying a "real" one.
I'm tired of taking heads to use someone else's valve spring compressor. I made mine oversize because I'm sure I'll use it as a clamp eventually. Instead of shopping and waiting for acme thread, I just used threaded rod. The rest is 1/2" square tubing and 3/8" square rod -- they slip fit great and hold themselves aligned for brazing. A better handle and valve pad will come somewhere down the line. ![]() ![]() So toss in your homemade motorcycle tools.
Motorcycles are magical. |
03-17-2013, 04:59 AM
#2 |
World Wide Inmate
Oddometer: 2,120
Great design.
I always appreciate the thought and concept of stuff like that. Grew up with a father that was a Machinist, he was the king of overkill when it came to heavy duty, and was great at getting thoughts of things like that from his head to his fingers to the finished project.
´¯`·.¸¸.·´¯`·.¸ ><((((((º> `·.¸¸.·´¯`·.¸¸.·´¯`·.¸ ><((((º> ´¯`·.¸¸.·´¯`·.¸¸.·´¯`·.¸ ><((((((º> Everything happens for a reason. "Still seeking the reason" |
03-17-2013, 08:08 AM
#3 |
Oddometer: 637
Don't have any pictures of mine over the years , so they didn't happen . Many years ago before they had cast wheels , the olden days bike had the damnedest wheels that had wire spokes . Made a truing stand and hated every time I used it . Made many odd sized seal drivers and bearing drivers . At one time I even made a frame and wheel alignment jig . Modified many wrenches for special jobs . Many of the tools got recycled for other projects after the need for them passed . I am a machinist but do not have a lathe or mill any longer . Always loved the challenge of engineering a tool along with being a cheap FF . Always nice having the satisfaction of using a tool you made . Nice work .
Save yourself $5 us my SmugMug coupon b87YWgTeSWxEc Couple volcanos , stonehenge and some peg scraping http://www.advrider.com/forums/showthread.php?t=620436 Old Man plays with his Wee http://www.advrider.com/forums/showthread.php?t=608068 |
03-17-2013, 09:22 AM
#4 |
Oddometer: 466
a clutch spring compressor for a Norton made from an ABS pipe cap, also a bead breaker made from scrap and grafted onto a DIY bicycle repair stand
BTW there is a great site on DIY tools at http://www.homemadetools.net/ ![]() ![]()
victor441 screwed with this post 03-17-2013 at 09:27 AM |
03-17-2013, 09:40 AM
#5 |
Forever N00b
Oddometer: 1,607
Took me a while to find your clutch spring compressor; it blends in.
I was interested in tools by ADV inmates. I had seen the homemade tools site (I'm sure there's a thread about it here) but there is SO MUCH and not all that many for motorcycles.
03-17-2013, 05:54 PM
#6 | |
Oddometer: 126
Homemade Tools- Motorcycle |
03-18-2013, 09:50 AM
#7 |
a.k.a. Mr Rico Suave
I made a wrench to tight the BMW oil cooler connectors under the headlight, very difficult to get to it with a normal wrench.
![]() I just cut and shape a socket and weld it to a rod, works great..
I'm really Sorry but I'm "Out" of Rickybars, Actually I have a bunch of bars and a Ton of end pieces but Not that many clamps to offer them as a product anymore. |
03-18-2013, 02:27 PM
#8 |
Enjoying my last V8
Oddometer: 5,319
Brake pressure bleeder
I made this along time before they sold them made of plastic. Pressure bleeding brakes is the way to go. Using this method I always get a firm feel on the first go.
Complete with sight glass on the side! ![]() REDNECK seal retianer remover: ![]() Chain alingment tool. A couple of transfer punches( two for swing arm axle and two for wheel axle ) ( red tip has point ) ( measure point to point on both sides to get whell alingment dead nuts) from Harbor Frieght and a metal rule from some other EL-Cheapo tool place. Bungee holds wheel tight to adjusters.
Regards Fritzcoinc 96 XR650L, 96 Guzzi Sport, 07 BMW K1200GT, 86 Husky 400 XCE, 03 Harley Road King Police, 00 Husky Te 610 e, 1999 Husky TC610 SM, |
03-19-2013, 01:20 PM
#9 |
Oddometer: 4,127
my bead breaker. all the neighbors use it.
03-19-2013, 01:22 PM
#10 |
Oddometer: 4,127
![]() my lift stand. works on front or rear end of the bike. |
03-19-2013, 01:29 PM
#11 |
Trans-Global Chook Chaser
Oddometer: 2,703
KTM 640 crank bearing race removers:
![]() You heat these buggers up, clamp them onto the press fit inner roller main bearing races, squeeze, twist, & pull & off they come. It's kinda magical. Clint
'03 KTM 640 LC4 Enduro The wilderness, the desert - why are they not crowded .................................................. .....with pilgrims? |
03-22-2013, 11:00 AM
#12 |
Idiot
Location: The Beast (across the bridge from SF), California
Oddometer: 119
I'm a bit of a tyro, but a reasonably clever.
Problem: When I was rebuilding my old CB550, I needed a spring compressor. Complication: The local parts store didn't have any to rent. Complication: I wasn't working in my own shop. Complication: No access to any real fab tools except a drill press. Solution: drill press + plastic pipe fitting. The fitting, bored out on both sides. I made a big hole on one side to get the edges in, and small ones on the other for light and some structural integrity. The hole wasn't big enough, so I ended up making that into a slot later. ![]() And the whole thing mounted. It was a press fit (and by that I mean "adjust the chuck to the size of the pipe without thread and then mush the chuck down over it and just shear off the threads"), and I built a custom jig ("stacked some wood blocks") to hold the head underneath it. Lever action. Worked a charm!
03-22-2013, 12:14 PM
#13 |
Oddometer: 466
[QUOTE=DustyRags;21009073]I'm a bit of a tyro, but a reasonably clever.
Problem: When I was rebuilding my old CB550, I needed a spring compressor. Complication: The local parts store didn't have any to rent. Complication: I wasn't working in my own shop. Complication: No access to any real fab tools except a drill press. Solution: drill press + plastic pipe fitting. The fitting, bored out on both sides. I made a big hole on one side to get the edges in, and small ones on the other for light and some structural integrity. The hole wasn't big enough, so I ended up making that into a slot later. cked some wood blocks") to hold the head underneath it. Lever action. Worked a charm! -quote- clever! be careful using a drill press as an arbor press though, have heard of them being damaged that way....it is probably perfectly OK for a valve spring but not a good idea for heavy duty press jobs |
03-22-2013, 04:29 PM
#14 |
Begining the Adventure
Oddometer: 997
Just installed an Ohlins shock on my F800GS and needed a tool for the preload adjuster so I whipped this up. I found a 8mm hex driver bit in my junk drawer and made the rest out of aluminum. Turned everything on the lathe then milled the notch in the end of the shaft to fit to the handle. Drilled and counter sunk the handle to attach it with a socket head bolt. The bit driver is pressed into the end of the shaft which was drilled to suit. Rather than leave the shaft and handle as plain bar stock, I spent a bit of time fancying them up. Last thing was to print the preload settings out on the label maker and stick it around the tool shaft.
Ed 2009 BMW F800GS, 2008 BMW K1200GT |
03-22-2013, 04:38 PM
#15 |
"Cool" Aid!
Oddometer: 41,500
![]() ![]() ![]() ![]() ![]() Not made by me, but definitely home made! It worked well! Jim
