03-20-2013, 04:53 PM
#16 |
Southern Ontario
Oddometer: 1,986
read Neduro's tire changing thread beginning to end
03-21-2013, 08:03 PM
#17 | |
Oddometer: 1,624
I replaced my Deathwings with kenda 270's. I still crash.
Sometimes wheelies happen Quote:
03-21-2013, 08:06 PM
#18 | |
Nanu-Nanu Adventurer
Oddometer: 7,011
Marc
04 R1150RT,06 KTM 450EXC, 84 R100RS LE, 89 XL600V, 2012 Stelvio, 72 Guzzi Eldorado http://s22.photobucket.com/albums/b327/lomaxcm/?sc=3 |
03-22-2013, 08:21 PM
#19 |
Oddometer: 46
For the difficult and stubborn front tires (19" here) this seems to work, for me that is.
![]() It also takes plenty of lube, couple of minutes of foot stomping and an iron for the last press-on. Oh yes...plenty of lube. More lube. And no issues with tube getting twisted, pinched, ....
____________________________________ If it can go wrong, it will go wrong!!! |
03-23-2013, 03:09 PM
#20 |
No Marks....
Oddometer: 1,610
Why so much trouble changing tires? I took off two and put on two in 1 hr, 15 mins including taking them off the bike 2 days ago. This is not rocket science..... Are you taking the tube out after you break both sides and open up 1 side(the disc side)? Do you have 3 GOOD Spoons (MSR, MotionPro)? Do you have access to dishwashing soap?No need to waste 10 zip ties to do this.The only part that might slow you up at all is a rim lock.Also put just a touch of air in the tube so that it kind of takes a shape before you re-insert it back in the carcass. And a good compressor to pull up that bead.
