Old 03-20-2013, 05:33 PM   #1
Ricardo Kuhn OP
a.k.a. Mr Rico Suave
Ricardo Kuhn's Avatar
Oddometer: 12,370
Question All the sudden "110v reverse negative polarity"
Can this happen all the sudden...!?
So we live on the same house for the last 3.8 years and last night when connecting the cable box coaxial cables I saw sparks, Yes sparks and the box was not even plug to the wall in at the time..
In any case the cable man came today and he tells me we have "reverse negative polarity" in some of the outlets and we need to get them fix before they can replace the fried cable boxes (yes two of them fried at the same time, I guess by been connected to the same coaxial cable)
Is this easy to fix by a clueless guy like me or do we need a call a expert.
Also, how can this polarity change can happen all the sudden...?
we use the same outlets to connect the same appliances for years with out any trouble.
Thanks in advance for the guidance and sorry if is a stupid question, since for me is not..
Wanted: worn, ugly, cheap motorcycle cover for a big GS 1200
Ricardo Kuhn is offline   Reply With Quote
Old 03-20-2013, 05:39 PM   #2
D.T.
Difficult but useful
D.T.'s Avatar
Oddometer: 11,347
Check for hot & neutral wires hooked up wrong at receptacles.
Originally posted by burgerking So?
Holland is about the most expensive country in Europe when it comes to bikes and fuel..Stop whining and go riding It's just money and you only live once...
D.T. is online now   Reply With Quote
Old 03-20-2013, 05:43 PM   #3
_cy_
Oddometer: 6,339
Gardner Bender GFI-501A Ground Fault Receptacle Tester and Circuit Analyzer
List Price: $11.45
Price: $8.99
_cy_ is online now   Reply With Quote
Old 03-20-2013, 05:50 PM   #4
Ricardo Kuhn OP
Oddometer: 12,370
But how can this be reverse with out changing anything, or was it wrong since we got the house and we never notice..??
Old 03-20-2013, 05:59 PM   #5
rapidoxidationman
Easily trainable
rapidoxidationman's Avatar
Oddometer: 8,764
If the 3 prong device shown by _cy_ shows any issues, then I'd start by taking the cover off the circuit breaker box and looking for anything obvious. If you're not comfy doing that then hire an electrician...
Patrick:
I know I'm feeling badly when I have no interest in speeding
rapidoxidationman is offline   Reply With Quote
Old 03-20-2013, 06:00 PM   #6
spafxer
spafxer's Avatar
Oddometer: 2,638
If I understand your correctly, it sounds as if your house ground system (possibly including the water pipes) has become energized. The coax is tied into the ground system of the house.
This is very possible if the common conductor that goes back to your electrical supplier has become compromised, AND your house panel ground conductor is poor or non existent (depends on house age etc.)
If this is the case, the electric supplier should come and take care of their side of the meter ON AN EMERGENCY BASIS.
It's easy to put a volt meter on the cold water pipe outside and measure to wet earth or wet concrete. If you show AC voltage, YOU'VE GOT A DANGEROUS SITUATION.
spafxer is offline   Reply With Quote
Old 03-20-2013, 06:26 PM   #7
D.T.
D.T.'s Avatar
Oddometer: 11,347
Reverse polarity is something that is real, but not "reverse negative polarity"
If there is voltage to ground somewhere usually it trips a circuit breaker in the panel. But if the amps are low enough or the CB is bad you have a dangerous situation as mentioned above. Usually fire. GFCI's will trip and you will get shocks too.
How old is the house? Most appliances will work fine if the hot and neutral are switched around.
Old 03-20-2013, 06:33 PM   #8
Fuzzy Wrench
Pick Your Tool
Fuzzy Wrench's Avatar
Oddometer: 5
call an electrician, fix it right....not sure how it happened but some appliances don't care and run anyway 'cause AC is just that, alternating (back and forth)...could be a problem with the neutral wire...
Fuzzy Wrench is offline   Reply With Quote
Old 03-20-2013, 06:35 PM   #9
Ricardo Kuhn OP
Oddometer: 12,370
we are a little scare so we call a expert, hopefully will know more by tomorrow..
1926 or something like it with knob and tube in at least some parts of the house even if the panel is newer.
Ricardo Kuhn screwed with this post 03-20-2013 at 06:40 PM
Old 03-20-2013, 06:36 PM   #10
caryder
caryder's Avatar
Oddometer: 217
There is no "polarity" on an AC circuit. Just Hot (power) and Neutral (reference). The "polarity" reverses at the frequency of the generator (usually 60 Hz (times/second) in the US or 50 Hz in Europe).
To answer your question, if the wiring of your outlets are reversed, they were that way to start with. What fried your cable boxes was a voltage surge either on the power supply or the cable itself. This is why it's a good idea to have your electronics connected to a surge suppressor although some cable companies don't like that if the cable signal is weak because they don't know what the suppressor is doing to the signal.
It's easy to use one of the circuit testers recommended by the above responses to check the wiring of each outlet in your house. The testers are cheap and some power companies offer to lend them for free. Once you figure out which outlets are suspect it's generally easy to refer to any handyman website and learn the white wire goes to the wide prong (usually the silver screw) and the black wire goes to the narrow prong (usually the brass colored screw). Green wire is ground and goes to the base (usually tinted green) prong at the bottom of the outlet. Make you turn off the circuit breaker or pull the fuse before you work on the outlet. You can use the circuit tester to verify the power is off. Otherwise call an electrician to fix the suspect outlets.
Chuck
Chuck
2012 Honda NC700X
2006 Gas Gas 300 Pro
2003 Kawasaki KDX220R
1976 Yamaha RD400C
caryder is offline   Reply With Quote
Old 03-20-2013, 06:42 PM   #11
P B G
Oddometer: 10,001
http://www.ehow.com/how_2313797_fix-...ceptacles.html
probably easiest to just make sure that the outlet it is plugged into is set properly, motors and the like don't give two hoots.
Old 03-20-2013, 10:39 PM   #12
the_gr8t_waldo
Oddometer: 2,126
reverse negative polarity- sounds like double talk! but it might make some sense to a cable guy. reguardless, if you haven't had anything done to the system, then it has to be at the transformer, out on the pole. and if it is, then the power company owns that problem!. (had a lighting storm in the last few days?) call 'em up and get them to figure out if they are delivering the right product to your home. before assuming that it's in your home
the_gr8t_waldo is offline   Reply With Quote
Old 03-21-2013, 03:33 AM   #13
foxtrapper
Oddometer: 849
Agree, the wires in your house didn't just reverse themselves. And being reversed wouldn't cause sparking. What you've described sounds like what spaxfxer describes, which is *darn* dangerous. It is not something I'd recommend dinking around with on a leasurely basis.
If I had an outlet that blew sparks at me when I plugged something in, and especially if it didn't blow the breaker when throwing those sparks, I'd be quickly investigating and either fixing it, or having it fixed, pronto. I do not like electrocution in the shower, nor do I like having my house burn.
foxtrapper is offline   Reply With Quote
Old 03-21-2013, 05:50 AM   #14
ph0rk
Doesn't Care
ph0rk's Avatar
Oddometer: 2,112
I wouldn't screw around with this - sometimes it is well worth paying a professional, though if the house has wiring that old you may end up really paying.
--Semantics are everything.
ph0rk is offline   Reply With Quote
Old 03-21-2013, 07:14 AM   #15
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 4,716
Get yourself ready if you call the power company. They may not fool around and just remove the meter.Different problem I had but call the electrician and get it fixed they told me and just then we will come back and reconnect. That was 2-3 days without power.
I am always ready for such days.....water, food, heat and cooking.
Have tools, will travel!
Times are GMT -7.   It's 04:24 AM.
