Old 03-21-2013, 09:39 AM   #3691
rtwpaul
out riding...
rtwpaul's Avatar
Oddometer: 1,996
case saver
does anyone have a source for a case saver? i find photos all over the place of them mounted, are guys making them themselves, or are they hiding in the KTM fiche somewhere - part number? or buying them from....
kind of like this i'm talking about
and how about these type of case saver for the clutch cover etc...i know this is not a photo pf a KTM LC4, thats kind of my point...is anyone out making something for us?
rtwpaul is offline   Reply With Quote
Old 03-21-2013, 09:58 AM   #3692
bmwktmbill
Traveler
Oddometer: 5,048
Paul, it's already on your machine or should be, some of us grind them thinner to fit the 17T sprocket cause it's too small,
The thing is aluminum and grinds easily.
17/42T make an easy cruising gearing and less vibs for sure.
There are several threads on this and the mod.
http://www.advrider.com/forums/showthread.php?t=649629
BTW there are some really heavy chains and good oilers out there.
I'd recommend the use of one. I'll go on your thread tonight with what worked for me.
bill
'02 KTM 640 Adventure-lowered
Cormack McCarthy-The Crossing
Bill Shockley
bmwktmbill screwed with this post 03-21-2013 at 10:04 AM
bmwktmbill is offline   Reply With Quote
Old 03-21-2013, 10:00 AM   #3693
Boon Booni
Red Clay Halo
Boon Booni's Avatar
Oddometer: 13,422
Look under "Engine Case" in the motor Fiche.
Where the fuck...
Where the fuck is the bike?
You gotta be shitting me.
Where the fuck is the road?
Old 03-21-2013, 10:04 AM   #3694
rtwpaul
out riding...
rtwpaul's Avatar
Oddometer: 1,996
bill
bill i thought you'd be the first in on this, my bike is still with RAD MFG so haven't had a chance to pull it apart yet, so as i read other threads its is giving me ideas, good to know its there already, thanks
Old 03-21-2013, 10:22 AM   #3695
rtwpaul
out riding...
rtwpaul's Avatar
Oddometer: 1,996
OK, so found the first one in two sizes, thanks for the direction...what i found and pricing right here
CHA.DAMPERSHEET 15/16T 92MM 03 58430047200 $9.74
CHAIN DAMPERSHEET 17T 92MM 03 58730047100 $9.71
so how about the the clutch and engine cover saver?
Old 03-21-2013, 01:13 PM   #3696
gunnerbuck
Island Hopper
gunnerbuck's Avatar
Oddometer: 4,111
The LC 4 cases are initially built fairly tough and can take a beating... Not to say that they won't puncture with the perfect hit, but nobody has produced cover savers for this model because there was no demand... The few punctures I have heard of were easily repaired with a JB/quicksteel type product...
Your showing the Suzuki case covers which have a rep for how easily they puncture, hence the need for extra armor...
640 A x 2
BC RIDING 2014
gunnerbuck screwed with this post 03-21-2013 at 01:19 PM
gunnerbuck is offline   Reply With Quote
Old 03-21-2013, 08:55 PM   #3697
rtwpaul
out riding...
rtwpaul's Avatar
Oddometer: 1,996
OK if they're not out there now i can stop looking, i will probably make some myself then just as extra insurance thanks for letting me know
Old 03-21-2013, 10:13 PM   #3698
gunnerbuck
Island Hopper
gunnerbuck's Avatar
Oddometer: 4,111
I look forward to seeing what you come up with...
640 A x 2
BC RIDING 2014
Old 03-21-2013, 10:44 PM   #3699
dnrobertson
Big Bike, Slow Rider
Oddometer: 794
Have you considered one of these?:
http://www.advrider.com/forums/showthread.php?t=806155
I have personally crashed tested it and no damage to cases or fuel taps.
Plenty of damage to LC4 pilot (not sure how fast as I knocked myself out and cannot remember any of the accident)
Also good for storage and one of the inmates here modified it to make it a bit more secure.
David
2005 KTM 640A
2008 Wee-Strom
dnrobertson is offline   Reply With Quote
Old 03-21-2013, 11:28 PM   #3700
rtwpaul
out riding...
rtwpaul's Avatar
Oddometer: 1,996
looks like sturdy stuff but at over $700 US to get it here i can make it myself if need be, if you look at my thread i have a bash plate already, and if need be i am a welder and fabricator so can make changes/ additions if required...what i was looking for was just simple covers like the ones that are available for other bikes just as additional coverage and strength. I will probably end up making something out of steel, aluminum or carbon fiber
Old 03-22-2013, 02:08 AM   #3701
Marten660
Marten660's Avatar
Oddometer: 18
Now i know how to upload pics (at last..) i want to show you my LC4 adventure:
Uploaded with ImageShack.us
Is an '05 witch i bought new, but had to respray after a serious accident in '06.
Fine bike, but sold it a couple of years ago...
Today i own a different LC4.. (bought in jan. this year en restored en had it sprayed in Galoises colors etc.)
It 's a 660RR and has a lot more power compared with the 640adv!
And the noise is also a bit (...) more
Marten660 is offline   Reply With Quote
Old 03-22-2013, 02:57 AM   #3702
warewolf
Tyre critic
warewolf's Avatar
Oddometer: 2,525
The best way I have found to avoid the air filter hassle is either to be way in front or way behind.
Nup, doesn't work as the 640 self-dusts.
Why not close the sides and eliminate the problem?
I ran my bike for years and years with the OEM configuration (closed side and snorkel in) and it still dusted up pretty bad. I have not noticed any increase in dusting after opening the side and removing the snorkel.
Carry several filter skins which can be changed in a couple of minutes. That will get you through a long dusty day (or days) without having to clean the filter itself.
Cheers,
Colin
KTM LC4 640 Question? Check here first --> KTM LC4 (640) Index Thread
The Stable
warewolf is offline   Reply With Quote
Old 03-24-2013, 09:36 AM   #3703
timolgra1
timolgra1's Avatar
Oddometer: 495
Timo, Why not close the sides, that's the problem.
You get enough air from the top and it's clean.
This thread, we plowed this ground, us old ones!!!
http://advrider.com/forums/showthrea...=123569&page=5
The link is to Happe's pic but the whole thread is good and I love the old arguements.
IMHO.
Open the top and then leave it alone.
You can flip the filter to get more miles once it grunges up, it will be clean on the bottom.
Easy to clean the stock filter with tank gas and reoil with engine oil.
Carry a couple of EMT gloves or the like.
Pull the fuel line, soak filter with gas, wring it out, di it again, set filter in sun or by the campfire, knock out any loose shit, reoil with engine oil and install.
GO!!!
And don't forget to fill your stove fuel bottle and reconnect the fuel line.
bill
Thanks for the link, I must have missed that thread when I was searching for info
I'll give it a try with the side closed back up, snorkel off and may make a screen for the top.....and use filter skins.
timolgra1 is offline   Reply With Quote
Old 03-24-2013, 11:45 PM   #3704
bmwktmbill
Traveler
Oddometer: 5,048
IMHO, no screen on top as it willl disturb the smooth air flow/ movement-motion into the box and to the filter.
IMHO.
bill
Bill Shockley
Old 03-25-2013, 05:55 AM   #3705
beek-02
blazing a trail
beek-02's Avatar
Oddometer: 113
IMHO.
bill
Bill is correct to an extent. This really depends on the carb you have. If you are still running a stock bst 40 he is absolutely correct. In my experience if you open up the airbox to much you establish no pressure(vacuum) in the airbox. The reason this is bad is because that is the way that your carb operates. It creates a lag until that airflow velocity/pressure is reestablished. With a fcr/pumper carb open the intake and exhaust as much as possible and let that (and off course the motor itself) be your only restriction. As far as filtration goes, there are many theories, but as long as you are keeping the dirt out and the air coming in your, theory is as accurate as any other. Beek
Sent from my SCH-I535 using Tapatalk 2
"Opinions are like a$$holes. Everybody's got one and everyone thinks everyone else's stinks."
beek-02 is offline   Reply With Quote
Times are GMT -7.   It's 02:22 PM.
