Go Back   ADVrider > Bikes > Beasts > Moto Bellissima: All Other Dualsports
Old 03-21-2013, 08:03 PM   #4381
Lomax
Nanu-Nanu Adventurer
Lomax's Avatar
Oddometer: 9,343
Danged, Farkles for this thing are expensive and hard to find, and all the directions are in Italian.
It will be a work on the bikes, in the garage, and stay away from the snow type of weekend I think.
Marc
84 R100RS LE,14 Ducati MTSGT, 73 850 Commando, 78 CT90, 14 Ural, 74 Eldorado police, 64 R50/2, 13 TR650, 01 DRZ400E, 94 900SS/CR
Lomax is online now   Reply With Quote
Old 03-21-2013, 08:11 PM   #4382
stevie88
That's gotta hurt
stevie88's Avatar
Oddometer: 19,609
Mistrial rocks.
I wasn't born with enough middle fingers.
stevie88 is offline   Reply With Quote
Old 03-21-2013, 08:17 PM   #4383
Lomax
Lomax's Avatar
Oddometer: 9,343
Yes they do. and speaking of Mistrial's, has anyone figured out a way to keep them from after-firing a LOT on deceleration?
Marc
Old 03-21-2013, 08:26 PM   #4384
stevie88
That's gotta hurt
stevie88's Avatar
Oddometer: 19,609
Marc
Todd over at GuzziTech says he can. I kind of like it myself.
Old 03-22-2013, 04:15 AM   #4385
WitchCityBallabio
Guzzi weirdo
WitchCityBallabio's Avatar
Oddometer: 922
Originally Posted by stevie88 View Post
Mistrial rocks.
Shocking what the stock can weighs when you take it off isn't it? It's worth it just for the weight savings.
Me too.
2011 Moto Guzzi Griso SE, 2009 Moto Guzzi Stelvio
2004 Moto Guzzi V11 Sport Ballabio, 1979 Moto Guzzi V1000 Roadster Cafe
1970 Moto Guzzi Ambassador
1966 Moto Guzzi Stornello
IBA # 35648
WitchCityBallabio is offline   Reply With Quote
Old 03-22-2013, 07:54 AM   #4386
Sock Monkey
Corporate slave
Sock Monkey's Avatar
Oddometer: 2,351
Marc
The new muffler opens things up a bit since it removes the CAT. As a result, you're running even leaner than you were, which is what's causing the popping and farting. To fix it, you need to richen the mixture, which means futzing with the ECU/EFI. Todd has one solution (arguably the sure-fire, plug-and-play and be done solution.....$$$$), but there are others out there (Redline Racing says they can reflash your ECU for you if you give them your list of mods for $300, you can go buy a PC-V and roll your own maps, go buy Tune Boy and roll your own, etc).
Two notes on this stuff. First, running lean means running hot. That's never good. However, point two is if you run richer, you use more fuel, so your mileage suffers (by how much is TBD). Pick your poison......
-SM
aka NoVector
Current: 2012 Moto Guzzi Stelvio NTX, 2008 Yamaha WR250R
Gone: Ducati Multistrada, Moto Guzzi Norge, BMW R1200GS, BMW F650 GS Dakar, KTM 520 EXC, Suzuki DRZ400E, and the list goes on.......
Sock Monkey is offline   Reply With Quote
Old 03-22-2013, 09:18 AM   #4387
WitchCityBallabio
Guzzi weirdo
Oddometer: 922
Todd also reflashes ECU's.
IBA # 35648
Old 03-22-2013, 10:05 AM   #4388
Boro128
Oddometer: 14
Show off!
Mistrial rocks.
Biggest Cock I have ever seen
Boro128 is offline   Reply With Quote
Old 03-22-2013, 10:16 AM   #4389
ripngrip
ripngrip's Avatar
Oddometer: 37
Made my Friday morning...
ripngrip is offline   Reply With Quote
Old 03-22-2013, 01:53 PM   #4390
dirtymartini
Shaken, Not Stirred
dirtymartini's Avatar
Oddometer: 2,627
-SM
Or for even less money you can use the Fat-Duc emulators....of which I have for sale (Shameless plug) I decided to have Todd flash my ECU so the emulators are up for sale.
"A free people ought not only to be armed and disciplined, but they should have sufficient arms and ammunition to maintain a status of independence from any who might attempt to abuse them, which would include their own government." -- George Washington
dirtymartini is offline   Reply With Quote
Old 03-22-2013, 02:11 PM   #4391
Precis
Maladroit malcontent
Precis's Avatar
Oddometer: 3,731
Surely we're talking a relatively minor adjustment here? Without seeing the existing map you can't know if it incorporates a Long Term Fuel Trim, which the ECU 'learns' and adjusts over time, but just richening it up a couple of points acording to an exhaust gas analyser should be possible: I doubt you need to rewrite the entire ECU.
I know TuneBoy charges a LOT of money to provide a cable, software and a unique-to-the bike 'key'; as an alternative, it might be worth seeing if the freeware TuneECU software can interrogate the Guzzi's ECU: it works fantastically well for some Aprilias, KTMs and Triumphs. They make available the software and some alternate maps on an honesty donantion basis.
Using a $10 interface cable from fleabay, I recently installed a map created by a guy in California specifically for our common models: he tuned it for 87 Octane fuel and even without a gas analyser, my consumption improved by 25%, the formerly pretty smooth V-twin has become turbine smooth - and there is so much extra power that just whacking on the throttle tosses the front wheel (of a 250kg bike) in the air.
His point was that the original map was too rich pretty much everywhere, to ensure the engines run cool and to hide some response glitches. Of course, extra fuel just washes oil off the cylinder walls and promotes carbon build-up: using a dyno at steadily more throttle, he has produced the bike the factory SHOULD have made in the first place. He requests a $25 donation....
I wonder if this can be done for Stelvios too?
"I would like to die on Mars; just not on impact." Elon Musk
Precis is offline   Reply With Quote
Old 03-22-2013, 02:44 PM   #4392
Mr. B
Contrarian
Mr. B's Avatar
Oddometer: 1,943
Does this apply to us Yanks? Running too rich to keep the engine cool does not seem to be the case with US-spec vehicles!
'12 Moto Guzzi Stelvio NTX
'14 Suzuki Burgman 400
Mr. B is offline   Reply With Quote
Old 03-22-2013, 03:01 PM   #4393
Precis
Precis's Avatar
Oddometer: 3,731
Mr B - I cannot speak for you poor, oppressed souls! But the fellow that did this remapping (admittedly of a 10-year-old bike, as it is now) lives in California - is that still considered part of America?
You will be blighted by o2 sensors, lambda sensors, Cats, dogs, deer, moose and probably elk too.
What brand is the Stelvio's ECU?
Old 03-22-2013, 03:28 PM   #4394
Adam R
Adam R's Avatar
Oddometer: 146
They use a Marelli (5AM from memory) - popular ECU choice. Interested to know if the solution works.
Moto Guzzi Stelvio 1200 2008
Adam R is offline   Reply With Quote
Old 03-22-2013, 03:52 PM   #4395
Precis
Precis's Avatar
Oddometer: 3,731
TuneECU
Here would be a good place to start a'lookin':
http://www.tomhamburg.net/TuneECU_En/index.html
If there's enough demand, perhaps Tom in Hamburg (Germany) and his colleagues would be able to make their software work for Guzzis - then it will just need someone to create more accurate maps: this requires knowledge, (a bike, obviously), extensive dyno-time, an industrial-grade vehicle exhaust gas analyser and a good deal of patience.
But as a mere user who has remapped both my own and my wife's Aprilias - the changes are astounding: what was a pretty smooth bike before became turbine-like; the power delivery & throttle response is noticeably snappier and more insistent and best of all, the fuel burn-rate was improved hugely.
If there's a down-side, it is that the bike is marginally slower to start up from cold: being EFI, I have a start-up sequence that I ALWAYS perform (pilot training!): bike in neutral, no clutch, kill switch off, key on - allows all sensors to calibrate, all check-systems to cycle; kill-switch on - allows stepper-motor to cycle and fuel pump to prime; then thumb the button, no throttle.
It will crank 3-4 times before firing up; I fancy that before the remapping, it maybe cranked over a bit less. A small price to pay!
Times are GMT -7.   It's 03:13 PM.
