Old 03-21-2013, 08:07 PM   #7171
m2h
"Old guys rule"
m2h's Avatar
Oddometer: 133
Originally Posted by Dracus124 View Post
You need LED flashers
Thanks buddy was afraid of that.
m2h is offline   Reply With Quote
Old 03-21-2013, 08:11 PM   #7172
m2h
"Old guys rule"
m2h's Avatar
Oddometer: 133
Originally Posted by davek181 View Post
I used a flasher that I got from NAPA parts store. It is universal, two pin, and capable of figuring out out to keep it's cool and flash with any light combo. I have 20 watt standard front signals for visibility and LED for rear and it works great with them. The package claims one to ten light capable 300 watt, non thermal type. It is cheap too, $10.00. Their part number is EL-12.
Thanks Dave,
As always great info with reply. Will check that out as the one on the aussie site was $45nz
Cheers
M2H
Old 03-22-2013, 06:54 AM   #7173
Carter Pewterschmidt
Carter Pewterschmidt's Avatar
Oddometer: 1,092
Thanks for the suggestions guys, but I don't know if I'm going to try and mess with a custom spring set on this front end. I have a set of XR600R forks sitting in the basement that actually have such parts available for them. I'm going to see how much it would cost to get them rebuilt and shortened to the XL length.
Carter Pewterschmidt is offline   Reply With Quote
Old 03-22-2013, 09:09 AM   #7174
davek181
davek181's Avatar
Oddometer: 897
Use the XR forks as is, and add an XR reservoir shock and all will be well. I have an extra one if you need it. i did that on my XL, only I used XR400 forks instead and I am quite happy with it.
davek181 is offline   Reply With Quote
Old 03-22-2013, 12:17 PM   #7175
Chobro
spinning the wheel
Chobro's Avatar
Oddometer: 791
XL600R Suspension Upgrades
Here's a good link from thumpertalk on the topic of XR suspension for our XLs. May have been posted, but it seems like a popular topic. I've got most of the stuff to make the switch on my '85, except time.
http://www.thumpertalk.com/topic/607...sion-upgrades/
-Chobro
Chobro is offline   Reply With Quote
Old 03-22-2013, 12:20 PM   #7176
Oddometer: 1,092
I have a feeling that this thing will be super tall with the full XR treatment. A little extra height would be ok, but those forks are whole 1 and a half inch longer than stock XL, that and the shock is something like an inch longer. That's quite the jack up. If I was a trail rider sure, but I'm an urban dweller and I don't know about riding around town on what would be something like a 36" seat height.
I'd be able to see much further above traffic though. I could coordinate traffic lights from miles off into the distance.
Old 03-22-2013, 12:55 PM   #7177
davek181
davek181's Avatar
Oddometer: 897
My seat height is higher than stock, but with a 32" inseam I can touch the ground with both feet on the balls of my feet. You get used to the height pretty quickly and adapt. No way I would go back now.
Old 03-22-2013, 01:15 PM   #7178
RFVC600R
SAND EATER!
RFVC600R's Avatar
Oddometer: 2,893
Those Hagon springs are only $121..... Its tempting lol
'83 Honda XL600R 618cc 11:1 Wiseco, XR's Only Exhaust + over sized header
Originally Posted by Carter Pewterschmidt View Post
He's the XL600 Jesus, his bike dies for our sins.
RFVC600R is online now   Reply With Quote
Old 03-22-2013, 01:19 PM   #7179
davek181
davek181's Avatar
Oddometer: 897
What spring weights do they have available?
Old 03-22-2013, 02:20 PM   #7180
RFVC600R
SAND EATER!
RFVC600R's Avatar
Oddometer: 2,893
IDK but they have to be better than stock.
http://www.hagon-shocks.co.uk/catalo...tno=400-160-02
Old 03-22-2013, 03:57 PM   #7181
Oddometer: 1,092
Those probably wont work because the bike they list has a different fork. The XL600LM and XL600RM have 41mm forks instead of that stupid 39mm front end that we got.
Old 03-22-2013, 04:22 PM   #7182
RFVC600R
SAND EATER!
RFVC600R's Avatar
Oddometer: 2,893
that sucks.
Old 03-23-2013, 09:32 AM   #7183
Oddometer: 1,092
that sucks.
Lol, Indeed. The US version and I know Italy, maybe a handful of other countries got shafted with this 39mm front end. It's obviously a weak front fork setup for a dual sport bike, which I'm willing to deal with because I'm not that interested in mucking about with a fork swap, but realizing that it's such an odd ball front end that you can't find aftermarket parts to improve it, or even service it with things like new bushings etc, I'm almost ready to throw in the towel on these forks. With a XR600 front end you can get all the parts in the world, everyone sells a service kit, springs, etc. Even the 41mm XR250R forks are about the same length as stock XL and you can get a bunch parts for them as well.
TL;DR A fork swap on the XL600R is almost a decision of necessity out of practicality, rather than a performance upgrade.
Old 03-23-2013, 11:29 AM   #7184
Novgorod
Oddometer: 11
Buying an XL600R? What to look for?
So I'm thinking about buying a local XL600R. The bike has under 5k miles claimed, and looks like new. What things should I look for on the bike before buying it. Is $1,500 a good price for a bike like this? If I buy it, do you recommend I take the entire bike apart, including the engine and inspect it before a long trip, or just take off and wing it? I need to make a 2,500 mile trip soon, lightly packed. It's an '83 model.
Novgorod is offline   Reply With Quote
Old 03-23-2013, 12:02 PM   #7185
MAXNX
Oddometer: 53
Damn Brakes
So I got some time to mess with my brakes last night, bleed it out no problem right?
I spent 2 hour trying and trying, but still have nothing. Worked fine before the brake line swap.
The only thing I can think of is that the inner diameter of the banjo I used for the master cylinder is bigger than the threaded fitting of the stock line.
I used a vacuum pump and must have put half a bottle through the system and absolutely no pressure...none
The only thing I can think of doing is getting a new banjo for an xr650 or 400 and see if that works
suggestions?
MAXNX is offline   Reply With Quote
Times are GMT -7.   It's 02:50 AM.
