Old 03-19-2013, 07:05 AM   #1
rossguzzi OP
990 Adv.
rossguzzi's Avatar
Oddometer: 996
Can a Rekluse fix dragging clutch?
As the title asks.
I have new Oberon slave, bled to death, updated rod, plates measured, all good. By wet and dry roughing steel plates I get almost perfect operation for a little while.
Clutch jet clean and drilled slightly bigger.
Short of buying a new basket and pressure plate, and steels, I wonder if any one has cured a dragging clutch by fitting a Rekluse.
I love the bike but the dragging is getting on my nerves. I need to be able to get neutral when stopped at lights with out reving the motor up and down.
rossguzzi is offline   Reply With Quote
Old 03-19-2013, 07:55 AM   #2
Chuckracer
Jerkus Maximus
Chuckracer's Avatar
Oddometer: 8,331
That's why it's dragging.
2012 KTM 990 Adventure
Chuckracer is offline   Reply With Quote
Old 03-19-2013, 07:59 AM   #3
Foot dragger
singletracker
Foot dragger's Avatar
Oddometer: 12,854
The trick is,put it in neutral as it stops,not when its stopped.
Shifting a bike when its sitting still is hard on linkage and other parts,practice slipping it into neutral while moving and it will become natural.
But,a Rekluse will indeed make all this irrelevant,no way to stall it,no need to find neutral if the clutch is working right.
Some bikes around at times
Foot dragger is offline   Reply With Quote
Old 03-19-2013, 10:25 AM   #4
gefr
Life is a trip
gefr's Avatar
Oddometer: 3,981
I 've been there.
When clutch fibre discs are well oiled, the clutch works like a dream. The problem in my case was solved with new clutch assy. You do not mention milleage.
Cheers.
Old 03-19-2013, 04:14 PM   #5
rossguzzi OP
990 Adv.
rossguzzi's Avatar
Oddometer: 996
35000 kls.
I know how to slip it into N before you stop. But yesterday I got caught in heavy peak hour traffic that I could not filter through. The slow moving stop start was awefull.
Old 03-19-2013, 04:36 PM   #6
Chuckracer
Jerkus Maximus
Chuckracer's Avatar
Oddometer: 8,331
Too much oil to the clutch via the oil jet will cause it to drag. I've had my oil jet come loose and exhibit the same symptoms you are describing.
More oil = dragging clutch.
Make sure it's tight. Can you get a stock jet?
Old 03-19-2013, 07:32 PM   #7
JTucker
JTucker's Avatar
Oddometer: 2,270
How about an adjustable slave, most of the KTM dirt bikes I've ridden drag the clutch.
http://rekluse.mybigcommerce.com/ktm...ylinder-03-12/
http://www.ktm-parts.com
03 Aprilia Caponord 06DR650
13 GasGas EC300 05 WR450F 87 T-dub
JTucker is offline   Reply With Quote
Old 03-19-2013, 07:36 PM   #8
cjracer
AWD please!!
cjracer's Avatar
Oddometer: 3,971
Using the Rekluse slave alone is not fix for an improperly working stock clutch. Having this setup with preload on the pressure plate with a stock clutch would cause a loss of full lock up and cause faster fiber wear and heat.
Bad idea imo.
If you are dealing with Stop and go traffic. A Rekluse EXP can be helpful and I find it very helpful when running errands in the city.
If you want stock feel I'd start by going back to OEM jet size as many have stated before.
My 2006 950S thread. 2006 950s update
New product updates here! Wordpress BLOG
click www.cjdesignsllc.com for the full line of products. FREE STUFF!!
cjracer is offline   Reply With Quote
Old 03-19-2013, 08:52 PM   #9
rossguzzi OP
990 Adv.
rossguzzi's Avatar
Oddometer: 996
Thanks for all the replies. I have ordered a new jet. The reason I got it drilled from memory .3 to .5 was because info on here suggested it would fix the problem. For the record it is an 03 model.
Cheers
Old 03-19-2013, 11:54 PM   #10
gefr
Life is a trip
gefr's Avatar
Oddometer: 3,981
I suggest you check all the relevant parts
The central nut and the deep steel disc for scoring from contact to the belevil spring. I use a drilled oil reduction jet with good results.
Cheers.
Old 03-22-2013, 05:10 AM   #11
rossguzzi OP
990 Adv.
rossguzzi's Avatar
Oddometer: 996
Fitted the standard oil jet and it is much better. Almost easy to get N at stand still and bike does not want to creep forward !
I just dont understand how a smaller jet makes this possible. I would have thought that the clutch would drag thru not having enough lubrication. So how does a smaller jet do this?
Just curious.
Old 03-23-2013, 11:14 AM   #12
FlyingPenguin
FlyingPenguin's Avatar
Oddometer: 212
F
Just curious.
"Viscous oil drag". Too much oil causes a drag between the plates.
"We'll burn that bridge when we get to it"
Deadhorse- 2002, 2012
ALCAN 5000- 2004
COBDR- 2014
FlyingPenguin is offline   Reply With Quote
Old 03-23-2013, 07:39 PM   #13
rossguzzi OP
990 Adv.
rossguzzi's Avatar
Oddometer: 996
Got it !
Times are GMT -7.   It's 06:16 PM.
