Old 12-17-2008, 08:01 PM   #46
Tappet
Feral
Tappet's Avatar
Oddometer: 1,451
Hey Laramie thanks for this thread. I only did the carb removal but your beer pacing was spot on.
Cheers!
Tappet is offline   Reply With Quote
Old 10-10-2009, 06:15 PM   #47
vdlcinc
vdlcinc's Avatar
Oddometer: 73
Trouble with carb installation...
Ok... I got the carb off... had to wrestle it out of there though. A tight fit with those two boots.
But for the life of me, I can not get it back on. Is there a trick to do this?
Don
'12 Tiger 800 XC
'68 Tiger 650 TR6R
vdlcinc is offline   Reply With Quote
Old 10-11-2009, 10:07 AM   #48
mars
Starbucks anyone?
mars's Avatar
Oddometer: 1,900
unplug the wiring harness, remove the two bolts holding the upper rear frame in place, loosen the muffler connections and mid pipe, look for any other hoses and wires they let the rear subframe drop down. it doesn't take that long and it gives you a chance to clean the mid exhaust pipe with steel wool and put dielectric grease in all of the connections.
mars is offline   Reply With Quote
Old 09-14-2010, 03:05 PM   #49
DaBit
Oddometer: 345
When reinstalling my engine I was missing about 1.5mm of space for reinstalling the bottom spacers/skidplate mounts. It just wasn't there; wigglewiggle on the engine, left/clutch side slips in. wigglewiggle again, right/generator side was impossible to fit due to 1.5mm too little space. On the left side it was a close fit; no space left to move the engine to the left.
I ended up beveling the top of the spacer a little using the bench grinder, and tapping it in with a plastic mallet.
DaBit is offline   Reply With Quote
Old 09-14-2010, 06:06 PM   #50
laramie LC4 OP
crash test dummy!
laramie LC4's Avatar
Oddometer: 2,368
those can be very tight. i hope you didnt take too much off....
laramie
DON'T TRUST CUT 7! HE IS A CROOK! ASK ME HOW I KNOW.
'12 LC8 990R, '02 LC4 640, '05 WR 450f (part-out), '98 XR400R, '76 KE100, '05 525 (Step-Child)
laramie LC4 is offline   Reply With Quote
Old 09-14-2010, 11:41 PM   #51
DaBit
Oddometer: 345
It wasn't just tight; the required 1.5mm wasn't there without spreading the bottom frame rails.
I didn't take off material from the entire spacer BTW, I just beveled the top side slightly so I could 'wedge' it in.
Old 09-27-2010, 07:17 AM   #52
rallyelc4
rallyelc4's Avatar
Oddometer: 143
Thumb
cheers mate just got my engine out thanks to you i am a groupie
2004 KTM 640lc4 enduro/rallye cam/FCRRGV rims
came with a sxc comp pipe
rallyelc4 is offline   Reply With Quote
Old 09-27-2010, 08:20 AM   #53
laramie LC4 OP
crash test dummy!
Oddometer: 2,368
cool. whats up with the motor? something fail your are you just being preemptive?
laramie
Old 09-30-2010, 01:46 AM   #54
rallyelc4
rallyelc4's Avatar
Oddometer: 143
Thumb
nothings failed at the moment (the intake roller went at about 35000k) my plan is to strip the whole engine just to check all is well,new piston and crank replace the valves and springs and have the head worked mildly,paint(hammer tone?) the frame and subframe and a WHOLE heap more stuff . i plan to start a thread ive been taking heaps of photos but i am pretty crap on the old computor so it might take awhile
BTW is there any threads that any one can reccomend re: the bottom end
cheers all
Old 08-09-2011, 01:17 PM   #55
DingDangKid
El Lechero
DingDangKid's Avatar
Oddometer: 2,319
Laramie, you got another groupie here! I'm parting my 640 out and this guide was near perfect. All it needed was more breaks for beer
Thanks for the write up!
2006 TW200 85mpg
1981 Honda CM400T
ISO: 198X Honda TA
DingDangKid is online now   Reply With Quote
Old 08-09-2011, 04:02 PM   #56
clintnz
Trans-Global Chook Chaser
clintnz's Avatar
Oddometer: 3,425
cheers all
Gunnerbuck, Tseta & myself have all rebuilt LC4 motors in the last 12 months & we all put up some notes & pics:
http://www.advrider.com/forums/showthread.php?t=628511
http://www.advrider.com/forums/showthread.php?t=632893
http://www.advrider.com/forums/showthread.php?t=633753
Cheers
Clint
'03 KTM 640 LC4 Enduro
The wilderness, the desert - why are they not crowded
.................................................. .....with pilgrims?
clintnz is offline   Reply With Quote
Old 08-10-2011, 02:54 AM   #57
rallyelc4
rallyelc4's Avatar
Oddometer: 143
http://www.supermotoaus.com/attachme...6&d=1300783060 Pic of frame painted orange and crappy half done build thread on another forem
Cheers
Clint
Thanks Clint I found them and have posted and subscribed You Blokes are bloody informative .
My beast is 100%stripped ATM and is waiting foor about another $1000 before I can move forward
Then I might start my own build thread so I don't clutter up the others will stupid questions.
Thanks again mate!
rallyelc4 screwed with this post 08-10-2011 at 03:04 AM
Old 07-01-2012, 06:36 AM   #58
zappa71
60.000 km BIG fun
zappa71's Avatar
Oddometer: 101
Thanks,
Got the big lump out and next step is taking it apart to see why it goose chunk chunk chunk [ had to stop after 340km off road roadbook riding last time, did not dare to finish all the 470km off the ride cause of the noise]
Don't cry, you can fix it.....
zappa71 is offline   Reply With Quote
Old 03-24-2013, 01:18 AM   #59
Chipper6
Oddometer: 2
Just dropped my motor for a swap. I'm going to try and swing the new(er) one in without taking the decomp. mount off.
Chipper6 is offline   Reply With Quote
Old 03-31-2014, 06:36 PM   #60
mortimer
Oddometer: 14
Thanks for the excellent information - just pulled my first LC4 and felt like I had done it before...
My tip - you really gotta 'tip' the engine to the left so that the engine comes free from the swingarm pivot, then lift 'er out.
mortimer is offline   Reply With Quote
Times are GMT -7.   It's 12:02 PM.
