Old 03-18-2013, 07:55 PM   #1666
lineaway
Oddometer: 3,041
Glad to hear the bike still runs!!
lineaway is offline   Reply With Quote
Old 03-18-2013, 11:45 PM   #1667
jonnyc21
Trials Ninja
jonnyc21's Avatar
Oddometer: 1,038
Thumb Getting ready for the weekend
All 3 bikes got .
Mine (4RT):
- Oil change, chain clean and lube, general inspection.
Wife's (TXT Pro 125):
- chain clean and lube, topped off oil (Only a bit low), re-glued and tied left grip.
Daughter's (Beta Rev80):
- Dot 4 all around, Brakes and clutch, oil change, chain clean and lube.
Ready for Saturday!
jonnyc21 is offline   Reply With Quote
Old 03-20-2013, 04:42 AM   #1668
LarryDawg
trials nut
LarryDawg's Avatar
Location: Nickerson/Hutchinson Kansas=Cesspool of the World
Oddometer: 74
Wicked survey says
Originally Posted by Sting32 View Post
(insert your best Richard Dawson {Family Feud} voice)
"What did I do with my bike today!" "Survey Says!"
BUZZZZ!
Sorry this is NOT the "what I DIDNT DO with my bike today" thread, so now Brewtus's team has a chance to steal...
I have rode mine 3 times since saturday.. Really need to get my Big ass in shape!! Felt like I lost that Bear Wrasslin Match for 2 days after our ride..
Dawg
"you dont quit riding Cuz' ya got Old!!! Ya get Old Cuz' ya quit riding!!!
1976 Honda TL 250 (Dozer!)
LarryDawg is offline   Reply With Quote
Old 03-24-2013, 01:36 AM   #1669
jonnyc21
Trials Ninja
jonnyc21's Avatar
Oddometer: 1,038
Thumb Family B-Day weekend ride.
The wife Kid and I out having some trials fun after our daughters B-Day Friday.
(Edit)
51 seconds of balance practice.
jonnyc21 screwed with this post 03-24-2013 at 03:35 PM Reason: including balance practice.
Old 03-24-2013, 06:19 AM   #1670
ADVCoop
ADVCoop's Avatar
Oddometer: 792
I put a new front tire on yesterday. D803:
2006 Husqvarna TE610 - 1982 Suzuki PE175 - 2009 Yamaha XT250 (wife's)
ADVCoop is offline   Reply With Quote
Old 03-24-2013, 01:25 PM   #1671
Abdelhub
Blanco Trasho
Abdelhub's Avatar
Oddometer: 727
getting a Greeves running
be safe
Mike
the most valuable bike i own hasn't run in 20 years...
http://www.youtube.com/abdelhub
Abdelhub is offline   Reply With Quote
Old 03-24-2013, 01:45 PM   #1672
Wingboy
Wingboy's Avatar
Oddometer: 142
Got out for the afternoon finally.First time on a trialer in 35 years for this vintage 60 yr old dude.The bike is waaaaay more capable than i'll ever be.I was very surprised how much low end it had even in 3rd or 4th. (last trialer was a Beamish 250) The light weight makes it stupid easy to pop over riverbanks and rockpiles.
Let the goodtimes roll!
If ya want me,i'll be in the bar.
Wingboy is offline   Reply With Quote
Old 03-24-2013, 01:52 PM   #1673
ADVCoop
ADVCoop's Avatar
Oddometer: 792
Great looking bike!
Old 03-24-2013, 02:17 PM   #1674
darmst6829
Oddometer: 376
Originally Posted by Abdelhub View Post
be safe
Mike
Great bike! Are you going to ride any AHRMA events this year?
Dave
darmst6829 is offline   Reply With Quote
Old 03-24-2013, 03:11 PM   #1675
Abdelhub
Blanco Trasho
Abdelhub's Avatar
Oddometer: 727
I hope to. I have so many vintage trials bikes now I dont know what to do. I should be able to. what is a good site to check out upcoming events?
Mike
Old 03-25-2013, 04:41 AM   #1676
amcross
Career Rookie/Novice
amcross's Avatar
Oddometer: 203
(Edit)
yaay! way to go team-johnny! looking GREAT!
AnnMarie Cross, permanent Noob! & proud wife of "macattack"
Join us in 2014 at the 2nd annual Tilton Trials, Illinois!
Novice owner of "GheeGhee", '01 GG 80big & also '01 GG280 "TriXTer"
amcross is offline   Reply With Quote
Old 03-25-2013, 10:50 AM   #1677
jonnyc21
Trials Ninja
jonnyc21's Avatar
Oddometer: 1,038
We are having great fun and have next Saturday blocked to go play some more.
We are working on Callie off trail more as well as figure 8's and she is even starting to work on small logs.
Old 03-26-2013, 05:18 PM   #1678
wb22rules
Bourbon Tester
Oddometer: 197
http://wb22rules.shutterfly.com/pictures/8
Well I did a little disassembly today to perform some spring cleaning and some overdue maintenance on my 2001 Gas Gas 321 TXT. I have had an exhaust leak right at the head and at where the front pipe met the first silencer since I have had the bike, so I wanted to address those two issues. I had only one rivet left on the rear silencer, so once I removed the silencer I drilled the last one out and had a look, the exhaust packing appeared fine at the end of the last silencer, so I don't think I need to remove all of it and replace it. I do have an issue trying to remove the middle or front silencer, whichever you call it, I thought the bottom fastener on it was a 9mm bolt, but it wasn't, than I thought it must be an allen head with the center packed full of dirt, but it wasn't. I now think it it is a stud of some kind that I have to pry a clip off of. How is that fastener removed? I took two pictures of it in the group of pics I took tonight in the link above. I know that the Trials Shop will cut open and clean and reweld shut that silencer to make it perfect again, but since I am unemployed I cannot afford that at the moment, so I was wondering if I could clean that silencer out by putting it in a wood stove full of coals and cooking it out that way? I did check the water pump, all looks ok there, I am going to flush out the radiator good and put fresh coolant in it. One question though are those stock hose clamps reusable or should I plan on getting some hose clamps? I did loosen the head screws and will remove the head once I can borrow a soft mallet so I can clean the carbon off the piston and head. I am trying to get together a list of all that I need to get her right for this spring/summer, as of now I know I need fork seals and sliders, the bolt that holds the lower clutch line and its bleeder screw, the front counter sprocket cover, and I suspect the clutch plates as I have not confirmed my steel plates are warped yet but I believe that to be the case.
1980 Yamaha IT 250G
wb22rules is online now   Reply With Quote
Old 03-27-2013, 05:18 AM   #1679
lineaway
Oddometer: 3,041
That clip is just stuck. Put a flat blade screwdriver in between the clip and pry. While doing so unscew the bolt. I would not worry about the center muffler. If you try to burn it out you will be looking for a new one! And if you have the packing I would replace it. You can not see anything with out actually removing the old packing.
Old 03-27-2013, 09:05 AM   #1680
ADVCoop
ADVCoop's Avatar
Oddometer: 792
Agreed, it seldom looks too bad at the ends, but I bet in the middle it is much worse off.
Times are GMT -7.   It's 09:12 PM.
