Old 03-25-2013, 05:10 AM   #1816
tdrrally OP
tdrrally's Avatar
Oddometer: 3,395
its a very cool machine
i need a headlight from one for my drz
1996 Dr350se 1997 DR350se
1980 TS125 project in the corner 2002 Drz250k2 i miss that bike
tdrrally is offline   Reply With Quote
Old 03-25-2013, 05:54 AM   #1817
redleger
Horrible Mechanic
redleger's Avatar
Oddometer: 588
KLM welcome. I am army so I know what you mean about the basic riders course. Back from iraq I had to wait a month to ride because of it. Enjoy the machine!
2000 KTM 200EXC
redleger is offline   Reply With Quote
Old 03-25-2013, 06:10 AM   #1818
twinrider
pass the catnip
twinrider's Avatar
Oddometer: 9,445
Originally Posted by KLM 3 View Post
Nice to make your acquaintance. I looked in the Asia forum and only found crickets for Japan. I have heard that Chiba is the place to get away from the city; I would love to get out there sometime. Since I am military, I have to take the Experienced Rider Course before they will let me loose on the locals. I couldnt go tomorrow, so I have to wait 2 weeks. I'm stuck riding on base until then. Sucks.
Thanks for the welcome. I wasn't sure I would find a place here since it a bit of an oddball, at least in the US.
Sounds good, shoot me a PM when you're ready to ride.
And here's my Djebel in Chiba.
twinrider is offline   Reply With Quote
Old 03-25-2013, 08:30 AM   #1819
mountainduro
hardened rider
mountainduro's Avatar
Oddometer: 56
Originally Posted by redleger View Post
I am gonna have to dump that dyno jet kit and rejet it again but I seriously had a hell of a time dialing it in. How did you work your way around the fuel screw issue?
Well at the fuel screw 3 turns out (instead of 2.75) drilled the brass cap,its safe.Check the fuel level at the bowl.
mountainduro is offline   Reply With Quote
Old 03-25-2013, 10:01 AM   #1820
redleger
Horrible Mechanic
redleger's Avatar
Oddometer: 588
how do you check the fuel level at the bowl?I already drilled the brass my question was about the carburetor and fuel screwI could not get to the fuel screw while the carburetor was on the bike. I am going to order the screw from the post above in hopefully that will help.
2000 KTM 200EXC
Old 03-25-2013, 02:50 PM   #1821
hudsen8
hudsen8's Avatar
Oddometer: 47
Didn't even see that scooterhoon, I've seen a couple of your vids when I was researching this bike. Good vids you got there.
Mountain enduro, he's is just telling me what was on the bill of sale from the shop here were we live. He nor I have actually looked into it any further than that. Guess now I will have to actually look more into it. Thanks for telling me regardless, this could help me out in the future.
Also we went riding on some serious hill climbs this past weekend, one thing I noticed was the throttle seemed way longer than any other bike I've owned. Is there a way to shorten it? Thanks guys
hudsen8 is offline   Reply With Quote
Old 03-25-2013, 04:12 PM   #1822
tdrrally OP
tdrrally's Avatar
Oddometer: 3,395
the drz400 short pull throttle works
Old 03-25-2013, 04:51 PM   #1823
Stinky@240
( Chef)
Stinky@240's Avatar
Oddometer: 79
DRZ250 rear shock
Hey, does anyone know if a rear shock/ spring from a 2010 DR650 will fit a 2004 DRZ250? Just putting it out there before I tinker myself...
Stinky@240 is offline   Reply With Quote
Old 03-25-2013, 05:12 PM   #1824
KLM 3
KLM 3's Avatar
Oddometer: 118
Will do. Thanks for the offer.
I have nothing witty, sagelike, intelligent, irreverent, humorous, helpful, funny, or informative to share in this space. Thank you. Please drive through.
KLM 3 is offline   Reply With Quote
Old 03-25-2013, 05:27 PM   #1825
tdrrally OP
tdrrally's Avatar
Oddometer: 3,395
a dr650 spring will only work with a 2" spacer reducer
racetech sells a spring
the dr250/350 spring and shock will work too
Old 03-25-2013, 05:32 PM   #1826
redleger
Horrible Mechanic
redleger's Avatar
Oddometer: 588
Scooterhoon! Your hillarious. Thanks for watching my vid also. How did you like those protaper bars? What bend were they?
2000 KTM 200EXC
Old 03-25-2013, 06:22 PM   #1827
hudsen8
hudsen8's Avatar
Oddometer: 47
That's good to know. Any particular ones you recommend? Also do we have a push/pull throttle?
Old 03-25-2013, 07:38 PM   #1828
tdrrally OP
tdrrally's Avatar
Oddometer: 3,395
yes its a push pull dr250/350 drz250/400 all use the same throttle tube
procycle sells one, i think motion pro has a version too
Old 03-25-2013, 08:45 PM   #1829
mountainduro
hardened rider
Oddometer: 56
Ok pull out the carb,unscrew the bowl, dry the inner carb at the jets all that top area,put again the bowl without screws,hold the bowl with your hand ( best if someone can help) and hold the carb in a straight position beside the tank near the fuel petcock(put it in "On" position) then close the fuel and take off the bowl carefully, the fuel level will leave a wet mark at the jets ,that wet mark has to cover all jets at least 1 cm.
At the screw I just did the 3 turns out with the carb off.
Hope it can help.
Old 03-26-2013, 01:48 AM   #1830
JamesK
JamesK's Avatar
Oddometer: 113
I recently bought a brand new TM33 from www.carbparts.com for $319. You tell them what you've done to the DRZ250 and they pre-jet it for you, and include two sets of spare jets too. It's a nice carb...
Install is straight forward, all you need is the boot (connecting b/w the back of the carb and the airbox) from the pumper carb model.
And a slight tweak to the throttle cable bracket to prevent it from increasing the rpms at full right lock.
2007 FJR1300A 200K Mile Club
If you see my bike on a trailer call 911
TBA 904, IBA 27221
JamesK is offline   Reply With Quote
Times are GMT -7.   It's 02:20 AM.
