Old 03-21-2013, 12:50 AM   #10141
Gravel Seeker
Thomas
Gravel Seeker's Avatar
Location: Dreary old Norway, dreaming of adventures past
Oddometer: 3,979
Originally Posted by Mr.Dabalina View Post
Has anyone tried the explorer shock from Touratech? As a noob, what riding characteristics can I expect from an upgraded shock? I'm about 215 in my birthday suit. I might also throw in the Touratech progressive springs as well.
Higher end components yields a quicker, more reponsive damper which won't "pack up" when stressed.
The progressive Wirth springs that Touratech sell worked very well for me and my camping gear laden mule for 8 months in Australia. I've been up to 255lbs at the most + riding gear and camping gear.
Total weight... just guessing: ca 340 kg/ 750 lbs
(Rider 115kg, riding gear + luggage 35kg, bike 190 kg)
Touratech TT45 tankbag with side bags
Ortlieb soft cases
Ortliebe roll bag
'01 F650 Dakar - modified as best I can
2005: Australia - 8 months/ 26.000 km (anti clockwise circle)
2009: Norway - 2 weeks/ 6000 km (Lindesnes to North cape)
Gravel Seekers.com
Hey !
It's the African ant eater ritual !
Gravel Seeker is offline   Reply With Quote
Old 03-21-2013, 02:14 PM   #10142
Mr.Dabalina
Mr.Dabalina's Avatar
Oddometer: 188
@gravelseeker
When the bike is unloaded are the springs too stiff? What weight oil in the forks? Also how much do you weigh of you don't mind me asking? Do you have the stock shock under the butt?
This is my only bike since I was a little kid. And I honestly don't know how bad something is riding if I've never ridden anything else. I like the idea of the Yamaha fork swap, I can chase down the parts if someone had an exact complete list. I wish someone would create a Yamaha fork conversion kit.
Mr.Dabalina is offline   Reply With Quote
Old 03-21-2013, 10:19 PM   #10143
Kainic
Almost there
Kainic's Avatar
Oddometer: 380
@gravelseeker
House of Horsepower was suppose to have some type of offering but not sure if it ever materialized?
Sent from my iPad using Tapatalk HD
Kainic is offline   Reply With Quote
Old 03-22-2013, 12:25 AM   #10144
isgila
isgila's Avatar
Oddometer: 109
...... I wish someone would create a Yamaha fork conversion kit.[/QUOTE]
You don't need a conversion kit.. The whole process is almost a direct swap. The headache only starts when you want to retain your abs, 19' rims, steering lock and brembo brakes.
isgila is offline   Reply With Quote
Old 03-22-2013, 06:52 AM   #10145
JDRadman
Moto Head
JDRadman's Avatar
Oddometer: 195
Originally Posted by Kainic View Post
House of Horsepower was suppose to have some type of offering but not sure if it...
Kainic,
I believe it did materialize...I sent all of the data to Richard at HOH a few months ago. I am sure he would like to hear from anyone interested in building/doing the swap. He may even have some forks on the shelf. At one time he kept a couple of different sets of springs too.
Good luck with the conversion. By far the best mod I ever did to my GS.
Rad
JDRadman is offline   Reply With Quote
Old 03-22-2013, 09:05 AM   #10146
Gravel Seeker
Thomas
Oddometer: 3,979
@gravelseeker
In a word; no.
But I'm kinda easy, just letting it live it's own life underneath me.
Like I said I was 115kg at the most. On the trip around Oz I started out at 110kg and came home weighing 92kg.
It's been 10 years since I replaced the fork springs but as far as I remember the biggest difference is that they don't bottom out and feel less bouncy than the stock springs.
Touratech says to use SAE15WT and 0,5ltr per leg which is perfect since a bottle usually is 1 ltr.
I did run the stock Showa untill a guy helping me make a new top bushing let gas out of it. I rode almost 5 cm lower after that, but was still ridable.
I rode the lowered Showa for 3 more years before getting an Öhlins. This was at about 50.000km or so (can't recall exactly). Also had the forks rebuilt by a racing suspension specialist (who build Ullevålseters Dakar forks among others). He said the stock fork legs (inners and outers) were 100% straight, with no damage what so ever - they actually looked very good. All the wear parts inside were totally worn out though.
Gravel Seekers.com
Hey !
Old 03-24-2013, 08:37 AM   #10147
KG6BWS
KG6BWS's Avatar
Oddometer: 895
Thinking I might need a new voltage regulator.
Charged my battery up full and reinstalled it. With the bike idling, Im getting 12.4 volts at the battery, 3000 rpms gets it up to 12.5/12.6. Turn the hibeam on and it drops down about .3/.4 volts.
What do you guys think?? R/R, stator or battery??
"But I swear, a woman's breast is the hardest rock that the Almighty ever made on this earth, and I can find no sign on it." Bear Claw Chris Lapp
Justin
01 F650GS Dakar
KG6BWS is offline   Reply With Quote
Old 03-24-2013, 10:24 AM   #10148
Gravel Seeker
Thomas
Oddometer: 3,979
No sure, but you should get about 12,3-12,5V on the battery and 14,3-14,5V with the engine running
Gravel Seekers.com
Hey !
Old 03-24-2013, 11:07 AM   #10149
1911fan
Master of the Obvious
1911fan's Avatar
Oddometer: 2,988
Tankbg and possum scraper for sale: Linky
http://advrider.com/forums/showthrea...0#post21022480
Read The Patriot Post -- It's Right. It's Free.
http://patriotpost.us/subscribe/
Sometimes the light to see your way forward is provided by the bridge burning behind you.
1911fan is offline   Reply With Quote
Old 03-24-2013, 02:08 PM   #10150
KG6BWS
KG6BWS's Avatar
Oddometer: 895
THats where my problem is. Getting about 12.2 or so from the battery, but only 12.5 or so with the engine running and at 3000rpm's. Just not sure if it would be a bad R/R or stator. I know how to test a car alternator, just not sure on a bike.
Justin
01 F650GS Dakar
Old 03-24-2013, 04:26 PM   #10151
tomatoe333
tomatoe333's Avatar
Oddometer: 2,280
My bet's on the R/R, or a bad connection between the R/R and the battery. Usually if the stator goes it's only one winding, and you'll get some voltage out of the regulator when you rev the engine.
If you do want to check the stator, unplug the connector in the harness going to the R/R that has the three yellow wires. Check the resistance between the three yellow wires going back towards the engine (1-2, 2-3, 1-3), and between each wire and ground. There should be low (like an ohm or two) of resistance between the wires, and very high (megohms) between each wire and ground. You can also start the bike up and measure the AC voltage between the yellow wires. Should be approximately equal, and something over 12 volts.
"Keep the standard settings will be useful to learn more about the bike. One should reach a sufficient technical level, when then humbly questioning calibration of your motorcycles."
tomatoe333 is offline   Reply With Quote
Old 03-25-2013, 08:52 AM   #10152
Barnman
Barnman's Avatar
Oddometer: 203
Relocated foot rests
With all the talk on foot rest positions, I thought this picture might help.
I took it part way through the swap from the standard location (Right) to the TT relocated position (Left).
What you can't see is the relocated footrest is also higher. I had initial lowered them for comfort, but found them catching the ruts so have now gone higher. Not as comfortable but beats falling off.
Barnman is offline   Reply With Quote
Old 03-25-2013, 10:00 AM   #10153
Gravel Seeker
Thomas
Oddometer: 3,979
If possible I'd use the pegs on the right - the TT ones are really soft (glad I wore MX boots though... they're not that soft ).
I just got the sloppy seconds. Same rock was first struck by an airhead right in front of me and I ended up leaving tire tracks across the airhead's tank/ map before both of us ended up in a pile on the ground. I've replaced at least 2 - if not 3 RHS pegs over the years.
The crash also bent my disc so it was rubbing on the caliper. Wasn't just fun riding home without front brakes when you're used to having them...
The shifter is also soft, good thing is that it bends right back and works flawlessly for at least another 8 years and counting
Gravel Seekers.com
Hey !
Old 03-25-2013, 10:08 AM   #10154
LoJack
LoJack's Avatar
Oddometer: 1,533
Yeah, my TT pegs look like that, too. I'd like to swap them out sometime for some PivotPegs, but the location is great. I just want to recover my seat so there is no scoop to take advantage of the position better.
LoJack is offline   Reply With Quote
Old 03-25-2013, 10:20 AM   #10155
TobyG
be happy :)
TobyG's Avatar
Oddometer: 544
Wow....I've already bent mine as well, but nowhere close to that, in other words I've always been able to fix them again :O
But then again, I am only riding my 650gs since last year.
Other than that, the pics from Gravel Seeker and Barnman show one thing I noticed before.
There are 2 types of TT Rallye footpegs. The ones Gravel Seeker are extended to the front, barnman's are extended to the rear. I myself have two sets, one of each kind.
Yep, quite a useless fact, but I am still wondering why....
And yeah, I can confirm what Gravel Seeker said about the shifter
"a scoot (that wouldn't go more than 28mph if you dropped it out of an airplane)" ~duck
"If loud pipes saved lives, then ambulances would run straight pipes instead of lights and sirens." ~Phlemdog
This is why I always wear gloves. How you gonna wipe your butt with hands covered in bandages? ~MrBob
TobyG is offline   Reply With Quote
Times are GMT -7.   It's 09:26 PM.
