Old 03-23-2013, 03:01 PM   #106
ebrabaek OP
Oddometer: 4,873
Then the headers were installed, and back in she went......
Erling
Old 03-23-2013, 03:02 PM   #107
ebrabaek OP
Oddometer: 4,873
Then although we were doing runs with out the PC-5/AT we hooked it up and looked , make sure we had readouts...
Erling
Old 03-23-2013, 03:03 PM   #108
ebrabaek OP
Oddometer: 4,873
Readying....
Erling
Old 03-23-2013, 03:04 PM   #109
ebrabaek OP
Oddometer: 4,873
Throttle bleep.....
Erling
Old 03-23-2013, 03:10 PM   #110
ebrabaek OP
Oddometer: 4,873
Third run with arrow headers, open pipe.... Note the Muffler insulation flying out of the pipe.... Most definitely breathing better....
Erling
Old 03-23-2013, 04:06 PM   #111
ebrabaek OP
Oddometer: 4,873
Fourth run.... Arrow headers, open exhaust, DJ PC-5/AT....first pull....
Erling
Old 03-23-2013, 04:07 PM   #112
ebrabaek OP
Oddometer: 4,873
Fourth run... Arrow headers, open exhaust DJ PC-5/AT second pull.
Erling
Old 03-25-2013, 02:04 PM   #113
gbtw
Oddometer: 148
Thank you kindly sir!
gbtw is offline   Reply With Quote
Old 03-25-2013, 02:35 PM   #114
ebrabaek OP
Oddometer: 4,873
Absolutely.... Worth every penny....with the right map... he he...
Erling
Old 03-25-2013, 02:42 PM   #115
ebrabaek OP
Oddometer: 4,873
Another update. Noticed another thing..... I find myself not opening the throttle as much. Dont get me wrong here...., but before it took a lot of throttle while riding..... I find myself not moving the throttle as much, but achieving the same ride. Same think happened on my big thumper. I was twisting like mad, during every day riding..... But as the fuel is now correct it simply takes less throttle. And... Fuel mileage you asked..... as of now... It is unchanged. Did I mention this thing is silly at low rpm...... I feel like I am on a stallion...... a very well behaved one, ready to go..... Ha ha.... funny thing... What comes into my mind, is the connect in avatar, between the rider and horse..... ... No exhaust popping anymore either. Simply fantastic. I will ride it a few more days, and if gas mileage remains unchanged..... then the handlebar switch, gets ripped off..... Eddie did mention this, while giggling....
Erling
Old 03-25-2013, 03:42 PM   #116
ebrabaek OP
Oddometer: 4,873
50 mph.... 75-80 mpg.
60 mph.... 65-67 mpg.
70 mph.... 55-57 mpg.
By the computer over distance.... no wind...... I will say that I gained a few miles per gallon..... Time will tell.
Erling
Old 03-25-2013, 03:45 PM   #117
ebrabaek OP
Oddometer: 4,873
Overall riding, I swear the noise is a bit quieter..... Might be wrong here, but it is at the very least a deeper, more pleasant tone. Note the high squeal with the dyno run and stock...... then the next video with my open pipe..... specially at high rpm, the stock was louder.....
Erling
Old 03-28-2013, 01:21 AM   #118
Mongo357
Mongo357's Avatar
Oddometer: 160
And the votes are in...
Ok, here is what I get when I digitized your data and back-calculated the engine RPMs and torque.
NOTE:
1) This assumes that you did not change the stock gearing (no sprocket swaps)
2) That your tire is a Heidenau K60 150/70-17 with similar wear to mine
3) Estimated 5% slip included
##EDIT##
Graphs were rendered obsolete by new information. Please see this post for final numbers:
http://www.advrider.com/forums/showp...&postcount=127
Mongo357 screwed with this post 03-29-2013 at 02:18 PM
Mongo357 is offline   Reply With Quote
Old 03-28-2013, 05:22 AM   #119
ebrabaek OP
Oddometer: 4,873
NOTE:
Thanks for the rendering...... I do feel like an idiot though..... as I forgot to tell you that I have an 18 inch on the rear, but with stock gearing......... Sorry.....
Erling
Old 03-28-2013, 07:56 AM   #120
Mongo357
Mongo357's Avatar
Oddometer: 160
18" rear
No problem, the hard part (digitizing) is done and I just have to tweak my spreadsheet.
But first I'll need you to measure the circumference of your tire.
Times are GMT -7.   It's 11:11 PM.
