Old 02-23-2013, 11:20 PM   #256
tHEtREV
Captain Awesome
tHEtREV's Avatar
Oddometer: 7,676
I just picked up an 05 te250 that has dropped a valve.
Head is stuffed and the cylinder has some damage.
I think I'll get a 300cc kit for it, but what do you guys suggest for the head?
What other years fit it, and can you get stainless steel valves for it?
tEAM iDIOT.
A KDX is way cooler than what ever you ride...
tHEtREV is offline   Reply With Quote
Old 02-25-2013, 07:55 AM   #257
Beer_me
JY
Beer_me's Avatar
Oddometer: 65
Nice videos prey4mojo. I really like the start of the third one with the snow in the desert. Hey what gearing (sprockets front/rear) are you running? The bike I bought came with a 53 rear and that'd be great if I had a rocky cliff in my backyard but most of my riding will be dirt roads I reckon. Wasn't sure if I should go all the way back to the stock 40 or something in between. I do know shifting 4 times just to get to 25 mph is amusing but quickly gets tiresome.
tHEtREV, you made me curious. I searched quite a bit and really didn't come up with anything. There's a well known Husqvarna shop in the US called Halls that was apparently at one time at least selling SS valves. I did find these guys in the UK as well http://www.hmracing.co.uk/index.php/...ngine-products Not much detail on their website. One last resource is an old thread on ThumperTalk http://www.thumpertalk.com/topic/179...inless-valves/ Again, probably more questions than answers. As to the head, I find no info regarding an aftermarket option. :( It seems your best bet would be to find a shop in Australia that specializes in Husqvarna. As good as they are, this brand simply doesn't sell the volume that the Japanese brands do so the aftermarket is that much more limited; not telling you anything you don't know I'm sure. Good luck!
Beer_me is offline   Reply With Quote
Old 02-25-2013, 09:11 PM   #258
prey4mojo
Oddometer: 4
Beer_me, Thanks for checking the vids! I am running 13 (stock) in the front and 53 in the rear. Sounds like the setup you have. It does get old shifting from 2nd to 5th as fast as you can when you hit a dirt road or something, but I need the low gears for the steep stuff. When I bought the bike I switched from the stock TE 40 to the stock TC 50 and loved it, went up to the 53 to give me that really low 1st. Maybe try something in between the 40 and the 50? Guess it depends on how much road vs trail you do.
prey4mojo is offline   Reply With Quote
Old 03-20-2013, 05:38 PM   #259
Monster_TE250
Oddometer: 3
My TE 250 Motard setup
so new to this site, but ive had my 09 TE 250 for quite a while and i have recently got my motorbike liscence. now i hate wrecking my nobbies so im looking at getting a set of motard tires and rims with over sized front disc and all the works.
has anyone tried this before?
anyone know if it will work with smaller wheels (17") and a 43 or so tooth rear sprocket? would like to sit on 100 occasionally but would like the grunt down low
comments anyone?
Monster_TE250 is offline   Reply With Quote
Old 03-20-2013, 08:18 PM   #260
SmileyRider
With lots of Teeth
SmileyRider's Avatar
Oddometer: 37
I have thought about this with a couple of my bikes and never pulled the trigger. Wheels are quite expensive. But in theory, all you need is a set of wheels, tires, a sprocket, another chain, acouple of new discs and a caliper relocation bracket.
It isn't as easy as just swapping the wheels. To switch from sm to dirt would take about an hour of wrench time. I prefer to just get a new set of DOT tires every year
if I ever get bored of dirt riding I will buy myself a sm setup.
And yes 17" rims will work fine on the husky, just make sure the rim width and hub sizing is correct
SmileyRider is offline   Reply With Quote
Old 03-20-2013, 08:47 PM   #261
jxg
Oddometer: 597
comments anyone?
I know others have done it, look at the cafehusky site. I don't think you have the xlite motor in your 09, but no way i could imagine going 100 on my '10. i would think at a minimum you will need a 40 tooth in the rear (stock on the '10, but i run a 51).
2010 Husqvarna TE250
jxg is offline   Reply With Quote
Old 03-21-2013, 04:40 AM   #262
Monster_TE250
Oddometer: 3
hmm thanks for the comments.
my current sprocket setup enables my 250 to go 120+ and still has heaps of grunt.
but that being said low down grunt is heaps due to my riding and i dont need insane low down grunt like i used to have with old sprocket setup.
so would there be any issues with a motard setup TE 250? so i can solve all the problems before i buy
also i have heard of guys buying a full motard setup then the hup being to thin for the tire and the chain hits it... but i think that was a fail not a general problem
Old 03-21-2013, 06:16 AM   #263
jxg
Oddometer: 597
not knowing where you are from, i now assume 100 kph, not mph, so that is a bit more reasonable.
i use my setup 99% offroad, mostly rocky, muddy single track, so i really like the low down grunt. 40 mph max for the short crossover roads between trails. I have thought about buying the motard setup, but then can't justify the cost for the amount of time i would actually use it. i think if i would spend more time on the road, i would buy a 2nd bike, something a bit more comfy for 2, so i could drag my wife along with me.
Old 03-21-2013, 04:11 PM   #264
Monster_TE250
Oddometer: 3
oh yea sorry QLD australia, i do alot of off road riding but not im getting my bike liscence i think it would be fun to have motard set up so i can enjoy my bike 100% more because i wont go through my nobbbies real fast on road.
and for the low down grunt i used to need it and all but ive being riding since i was like 5 lol and ive progressed so now i am faster around most trackes and trails etc, therefore new sprocker setup
Old 03-23-2013, 10:00 AM   #265
drw
drw's Avatar
Oddometer: 2
The '05, '06 and '07 engines seem to be essentially the same, looking at the parts numbers (bottom end parts, anyway) manuals. You can download them here:
http://www.halls-cycles.com/default.asp?page=catalogs
drw is offline   Reply With Quote
Old 03-25-2013, 08:05 PM   #266
c3eh
Oddometer: 30
just bought
Just bought a 2010 te250, has several upgrades and a few spare parts. Real excited to ride it except the weather in st louis is shit right now. Got a good deal. Hope there are some people on here who know about them and can lend a hand. Post pics soon enough
The best navigators are not quite sure where they're going until they get there and than they're still not sure
but I know one thing indecision may or may not be my problem.....
c3eh is offline   Reply With Quote
Old 03-25-2013, 08:38 PM   #267
swamp
U lie&yo'breff stank
swamp's Avatar
Oddometer: 1,803
anyone with a 2012 or newer checked their valves yet ?
if so what mileage ?
were they in spec or out of spec ?
thanks.
Enduro Earth
YOUTUBE
off the grid and deep in the woods
swamp is offline   Reply With Quote
Old 04-02-2013, 09:42 AM   #268
tbradbury
Oddometer: 1
2011 Husqvarna te250 1st gear bog
I was hoping someone here could help me with this problem. 1st gear seems to bog bad. I have read many different forums about this and still can't seem to find the answer. I have a JD tuner but yet to mess with it. Am I running lean on the low end? Is the JD tuner the answer to my problems? Can anyone provide me with the settings?
Thanks in advance!
tbradbury is offline   Reply With Quote
Old 04-02-2013, 09:47 AM   #269
Laser145
Laser145's Avatar
Oddometer: 361
for sale
Hey guys
Just listed my TXC250 for sale in the FM...just a heads up.
http://www.advrider.com/forums/showthread.php?t=875021
Cheers
1976 BMW R75/6
2007 KTM 690 Supermoto
Laser145 is offline   Reply With Quote
Old 04-02-2013, 12:03 PM   #270
Luke
GPoET&P
Luke's Avatar
Oddometer: 4,178
Thanks in advance!
If you've done the standard powerup it's way too rich. The tuner should fix it. I can't help with the settings for the JD -I have a powercommander. I'm sure the default setting on the JD is a huge improvement. The fueling error is not small.
Luke is offline   Reply With Quote
Times are GMT -7.   It's 01:24 AM.
