Old 02-27-2013, 06:21 AM   #286
Tseta OP
Lost
Tseta's Avatar
Oddometer: 672
Well, as you can see from the photo, the pin wrench I'm using is a "size 6" from Gedore, meaning the pins are 6mm in diameter. As I mentioned, for this to work nicely, I still had to grind a little bit off of the body of the tool (not the pins). The holes in the back of the stator are actually quite big, maybe something like 10mm in diameter.
All in all, I think you would be better off with something like this: click!
Cheers,
Tseta
Tseta is offline   Reply With Quote
Old 02-27-2013, 07:42 AM   #287
Antikid
Oddometer: 69
i did see that one, but if i can get away with spending less then that is always better.
i have never needed a tool like this, and don't mind buying one, but don't want to spend $$ that i will never get back out of the tool if the cheaper version will work.
(i am a cheap bastard)
any idea of the distance between the 2 holes? from what i gather, that is what the 2", 3", 4" is referring to.
thanks for the reply
05 KTM 625 SMC
09 KTM 200 XCW
Antikid is offline   Reply With Quote
Old 02-27-2013, 08:02 AM   #288
Tseta OP
Lost
Tseta's Avatar
Oddometer: 672
The center-to-center distance of the holes is about 95mm (by my memory and looking through some old sketches...).
-T
Old 02-27-2013, 11:19 AM   #289
Antikid
Oddometer: 69
-T
awesome!
thanks again
05 KTM 625 SMC
09 KTM 200 XCW
Old 02-27-2013, 06:31 PM   #290
gunnerbuck
Island Hopper
gunnerbuck's Avatar
Oddometer: 4,248
-T
I slapped a tool together and your 95 MM spacing looks pretty close to what I did {94.73}...
gunnerbuck is online now   Reply With Quote
Old 02-27-2013, 10:18 PM   #291
Tonicu
Oddometer: 169
Hi there, Tseta, good to hear from you.
So you're in Siberia ... worth a visit ... maybe on a newer Ktm.
Tonicu is offline   Reply With Quote
Old 02-28-2013, 06:55 PM   #292
Tseta OP
Lost
Tseta's Avatar
Oddometer: 672
Privet Tonicu!
Siberia is definitely worth a visit. Regarding the choice of equipment and transport, I've actually been toying with the idea of buying an Ural or other similar soviet steed from here and riding it home once the time comes.
Cheers,
Tseta
Old 02-28-2013, 10:28 PM   #293
bmwktmbill
Traveler
Oddometer: 5,188
Hey Tseta,
Good idea, when I was in Siberia I swear I saw Ural and ISH parts in the food stores? Maybe also in Mongolia. I rode with a Belgian guy and his girlfriend who bought a Ural in Ulan Bator and rode it west across the Gobi, then across Russia and finially to Belgium.
They had some problems but the fixes were always easy.
bill
'02 KTM 640 Adventure-lowered
Cormack McCarthy-The Crossing
Bill Shockley
bmwktmbill screwed with this post 02-28-2013 at 10:36 PM
bmwktmbill is offline   Reply With Quote
Old 03-01-2013, 06:58 AM   #294
skibum69
slave to gravity
skibum69's Avatar
Oddometer: 5,507
Lots of little Chinese bikes all over Mongolia, moto parts are out there for them.
Beerthief
skibumsoirée2009 skibumsoiré2010
Riff Raff 2015, 2012, 2011, 2010, 2009
RIP ITsteve, ride in peace my friend
save $5 on a new smugmug account, use this coupon7frrnSRiTt9Fk
skibum69 is offline   Reply With Quote
Old 03-25-2013, 08:13 PM   #295
chasbo
chasbo's Avatar
Oddometer: 1,666
That sounds like it would be a blast! I think I would jump on an opportunity to do something like that.
As far as the rebuilds you did, I am impressed. Great work! Very inspirational.
You can outdistance that which is running after you,
but not what is running inside of you
chasbo is offline   Reply With Quote
Old 07-29-2013, 09:21 PM   #296
Queen of Spades
tall drink of water
Queen of Spades's Avatar
Oddometer: 897
Yesterday I worked on the front end of the 1998 640 LC4 Adventure. The bike is equipped with the older, right-side-up WP Extreme 50 front forks. They are quite a different animal compared to the newer 4860 MXMA's. Since there doesn't seem to be very much detailed information about these forks, here are some pictures and pointers for the regular maintenance of the forks.\
Cheers,
Tseta
Many thanks for the pics and tips. I have new springs coming in from Slavens Racing next week. Is there a common preference on oil weight on these forks? I was thinking of Torco 10wt.
'99 KTM 640 LC4 Enduro http://www.youtube.com/watch?v=fifXkDQpda4 (January 2014 snow ride)
Queen of Spades is offline   Reply With Quote
Old 07-29-2013, 09:54 PM   #297
bmwktmbill
Traveler
Oddometer: 5,188
Not 10 wt...way to heavy.
http://www.advrider.com/forums/showthread.php?t=339544
bill
Bill Shockley
Old 07-30-2013, 01:31 AM   #298
Tseta OP
Lost
Tseta's Avatar
Oddometer: 672
The OEM specification was/is SAE 5. The "factory-approved" oil supplier of that era was, if I recall correctly, Shell, with their Advace-line of motorcycle-specific lubrication products. Motorex came into play only later. Some good reading about suspension oils here - SAE 5 is not always SAE 5, surprise surprise...
-Tseta
Old 07-30-2013, 05:59 AM   #299
Queen of Spades
tall drink of water
Oddometer: 897
Originally Posted by bmwktmbill View Post
Link is for USD forks found on later model LC4s. I have WP5060 "Extreme" conventionals. Some good general advice there however - thanks.
Queen of Spades screwed with this post 07-30-2013 at 06:04 AM
Old 07-30-2013, 10:05 PM   #300
meat popsicle
Ignostic
meat popsicle's Avatar
Oddometer: 14,238
http://www.advrider.com/forums/showthread.php?t=350210
Kronreif Trunkenpolz Mattighofen LC4 640
Its not so much staying alive; its staying human that counts.
meat popsicle is offline   Reply With Quote
Times are GMT -7.   It's 06:41 AM.
