Old 03-22-2013, 09:32 AM   #1096
novaboy
novaboy's Avatar
Oddometer: 512
Big land Adventure Blog
2006 VStrom 1000, 2007 APRILLA SR50
Guinness for Strength
https://www.youtube.com/user/fundypaddlesurf/videos
novaboy is offline   Reply With Quote
Old 03-22-2013, 10:37 AM   #1097
DC,Chad
DC,Chad's Avatar
Oddometer: 322
Roadkill if its the main seal leaking , pop off the wheel and take the seal out , it could be that the bearing cage has separated and pushed the seal out , if so new bearing needed but its not that bad a job.
this was on my GS but the same applies
GS gone now on a 1990 Electraglide sport natural balance gone to Ratshit
RD03 Africa twin slowly coming together
DC,Chad is offline   Reply With Quote
Old 03-22-2013, 12:17 PM   #1098
Roadkill231
MotorMAN
Roadkill231's Avatar
Oddometer: 22
Thanks for the help folks. Doesnt appear to be leaking from the main seal/bearing, but from the top from the breather valve. And only saw it once. I'll definately look at the oil and magnetic plug for sure.
On the radio w/ cassette, I run my iphone thru it using a 3.5mm plug attached to a dummy cassette (find one in any radio accessory isle). Works fine w no issues! I'd hate to dump the factory radio if there's nothing wrong w it. I'm a fan of 'if the electrical is working, leave it alone"...
Motorcycling is not, of itself inherently dangerous. It is,however, extremely unforgiving of inattention, ignorance, incompetence, or stupidity.
Roadkill231 is offline   Reply With Quote
Old 03-22-2013, 12:58 PM   #1099
fyrfytr
B.U.F.F.
fyrfytr's Avatar
Oddometer: 2,673
If anyone needs a tutorial for replacing the bearings and seal in the FD, read this.
There's something kinda sad about, the way that things have come to be. Desensitized to everything, what became of subtlety?
fyrfytr is offline   Reply With Quote
Old 03-22-2013, 03:27 PM   #1100
bbjumper
bbjumper's Avatar
Oddometer: 184
Boy, that thing must have been making some serious noise, the bearing cage is no longer present. What forewarning did you have? Did anything show up when you changed final drive oil? The only other one I have seen like this was also on a GS , are they more prone to this?
Usually a transmission will warn you by showing garbage in, and/or discolored gear oil, just curious if the final drive is like that also.
Speed doesn't kill, It's always the sudden stop that gets ya...
1982 Suzuki GS850G The "Zook"
2000 BMW R1100RT
bbjumper is offline   Reply With Quote
Old 03-24-2013, 03:54 AM   #1101
snookers
Old Fart
snookers's Avatar
Oddometer: 8
Trackday
Original Quote from SikDMAX
Am I nuts? Anyone done it? Taking my 07 R12RTP to a trackday this Monday. Debating on tires to run - Its on Pilot Road 3s right now that are coming off, Im debating a track/race tire but not sure how the extra weight will deal with that. Any ideas or other tips anyone? Anyone else done this?
A couple of years ago I had the opportunity to run my RT on a Nascar track at Watkins Glenn in New York. My self and approx. twenty others were hell bent on thrashing each other for the win. Thing was, there was no race, just alot of testosterone. I was running with PR3's and had a great time. Opening up the beast on the straightaways was a treat, and leaning into the curves an exilarating feeling to say the least. But.....I don't ride like this as a rule, my RT is a daily driver and not a race bike, and I still had to drive it home, preferably in one peice.
If you have the chance and feel confident in your abilities, I say give it a try.
The five laps I drove was worth the price of admission...
snookers is offline   Reply With Quote
Old 03-24-2013, 06:24 AM   #1102
DC,Chad
DC,Chad's Avatar
Oddometer: 322
sounds crazy but the only warning was the oil leak the previous service showed no signs, once the cage broke up it pushed the bottom of the seal out , even in this state the wheel was running smoothly :eek
after this i made a point of buying a new seal as part of the service so i could pop it out and check rivets on the cage the cage was secure at every service
its one of the things i love about the pre 1200 bikes relatively cheap and easy to fix
Old 03-27-2013, 09:18 AM   #1103
SikDMAX
Oddometer: 719
I ran Pilot Power 2CT up front and Pilot Road 3 rear, down around 30/31 PSI hot. Tires weren't the issue, I was pretty consistently dragging the right side crashbar mainly at 100+ around Riverside sweeper at Buttonwillow, but also the left side on a couple corners and have a new scrape on the right side valve cover
Matt - SikMoto www.Facebook.com/SikMoto San Luis Obispo, CA
SikDMAX screwed with this post 03-27-2013 at 09:29 AM
SikDMAX is offline   Reply With Quote
Old 03-28-2013, 05:04 AM   #1104
djminta
Oddometer: 27
"I ran Pilot Power 2CT up front and Pilot Road 3 rear, down around 30/31 PSI hot. Tires weren't the issue, I was pretty consistently dragging the right side crashbar mainly at 100+ around Riverside sweeper at Buttonwillow, but also the left side on a couple corners and have a new scrape on the right side valve cover "
That's awesome! I was riding the GA mountains with a friend and she remarked that she's never seen someone hang off a RT. Nice to see I'm not the only one.
djminta is offline   Reply With Quote
Old 03-28-2013, 07:53 PM   #1105
HotChilliColdBeer
Human Swizzle Stick
Oddometer: 295
It's good to be king.
Charlie
HotChilliColdBeer is offline   Reply With Quote
Old 04-09-2013, 06:46 PM   #1106
JBADV
searching for sanity
JBADV's Avatar
Oddometer: 3,421
So the season is starting up !
My tires are about spent.What tires are you guys using ? I think I'm going to try the Michelin Pilot Road 3 .
Anybody have them on now ?
The older I grow,the faster life goes.
The more I learn,the less I know.
JBADV is offline   Reply With Quote
Old 04-09-2013, 07:46 PM   #1107
mwood7800
Oddometer: 612
Pilot 3 my ft tire cupped at 5000, I figure if that's all I'm getting I'm trying the z8
mwood7800 is offline   Reply With Quote
Old 04-09-2013, 10:50 PM   #1108
Shaun09
Riding the Asphalt Ribbon
Shaun09's Avatar
Oddometer: 41
Haven't tried the PR3s, but enjoy the grip of the Z8s.
Cheers!
Chris
2009 BMW R1200RT (Shaun), 2004 MINI Cooper S (Gromit), 2006 BMW X3 (Wallace)
Shaun09 is offline   Reply With Quote
Old 04-10-2013, 04:20 AM   #1109
JBADV
JBADV's Avatar
Oddometer: 3,421
Thanks for the replys .
Old 04-11-2013, 05:03 AM   #1110
Firenailer
just passin' thru
Firenailer's Avatar
Oddometer: 436
I'm thinking about going to the P3's as well. The original front Bridgestone is cupped really bad at 5500. To be honest I was never that happy with those tires anyway.
I'll check into the Z8's too, and have them swapped out at the 6000 mile service next week.
"We were leaving confusion and nonsense behind, performing the one noble function of our time...to move"
On The Road
'12 BMW R1200RT
Firenailer is offline   Reply With Quote
Times are GMT -7.   It's 04:08 AM.
